#276 |
Member#: 317521
Vehicle:2015 WRX Blue |
![]() hi
any idea where to install the nozle of an AEM kit meth stock intercooler and stock Throttle Body Hose Thank you
#277 |
Member#: 437670
Vehicle:2005 2.5 SC OB |
![]() Personally I would buy a little nozzle insert that fits after the IC before the TB.
#278 |
Member#: 508188
![]() Hello everyone,,
Denatured alcohol is NOT methanol, it's ethanol that has been denatured with things such as Bitrex and Methanol. Isopropyl IS NOT methanol. snaptube.cam/ syncnet.onl/telegram-web/ https://9apps.cam/ I would be careful just dumping anything labeled "alcohol" into my injection system. Last edited by Maddy77; 11-26-2019 at 12:12 AM. |
#279 |
Member#: 437670
![]() Hey guys. I noticed that washer fluid msds is measured methanol by weight not by volume. -25F is usually around 34%. So my question is what VOLUME of pure methanol does it take to get it to 50% by weight? Assuming boost juice is 50% by weight not volume. Meth is about 6 lb per gallon and water is more like 8. I was thinking adding 24 oz of pure methanol per gallon(removing 24 oz of wiper fluid from the bottle first) would be roughly the right spot but that is going by volume. Doesn’t need to be perfect but I need significantly more knock resistance than wiper fluid is giving me.
#280 |
Member#: 437670
![]() So I weighed a gallon of -25F wiper fluid and it is 8# per gallon (actual weight of fluid excluding the container).
If we believe the MSDS is around 33% then it is ~50 oz of meth per 128oz of wiper fluid which is 33.65% by WEIGHT and is 39% by VOLUME. My plan is to displace 24 oz of wiper fluid with 24 oz of HEET which will get me 57.8% by VOLUME or 52% by WEIGHT. These are rough calcs but I believe they should be about right. Cost about $7/gal which is $3 less than buying boost juice. Last edited by pcampbell; 12-02-2019 at 01:59 PM. |
#281 |
Member#: 437670
![]() 2.28 gallons of straight meth(6x 4 packs of 12oz yellow Heet). was $35 shipped from Walmart. Yes significantly more expensive than M1 but individual measured containers and sealed containers is key for me.
#282 |
Member#: 437670
![]() ![]() To get roughly 50-50 water meth. Remove wiper fluid to slightly above the lip in the bottle (105 oz mark). Add 24 oz of heet (2 bottles). |
water / methanol injection kit -new or used | blazin sti | Private 'Wanted' Classifieds | 3 | 05-27-2006 09:01 PM |
Water/Methanol Injection or Race Fuel or Both | ejh25 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 03-28-2005 07:35 PM |
Derek Devises Water/Methanol Injection | mistaboosta | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-01-2004 06:52 PM |
Derek Devises Water/Methanol Injection | mistaboosta | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-01-2004 05:51 PM |
