Welcome to the North American Subaru Impreza Owners Club Monday January 20, 2020
Old 08-26-2006, 08:50 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Default evo seats to wrx install with detailed instructions
For the people interested in this here is a few tips.
the slider on the evo seats has a 5mm allen. just realize it likely wont come out with simply using the allen wrench. The bolts on them have blue thread lock on them. The bolt is about an inch long. I had to cut the rail off with a sawzall. Than peal back the sides. Cut the sides off to get on the button head allen bolt with vice grips after machining the bolt. I had no idea it was going to be this hard when I started. So sawzall and dreamal tool are your freinds. This process may take several hours per seat. I am going to try heat on this next one as thread lock will break down after a few hundred degrees. I will let you know how that goes.
desided heat was not such a good idea as the allen heads were already striped out so there would be no point. Been using Rodman sawzall blade. It cuts it pretty quick but my blade is nearly gone. here hacksaw blade is pretty good.
Aftrer making my cuts. I took the dremal and cut the top and bottom of the allen head and removed them with vice grips. This proved to work rather well.
Nearly ready to install my drivers seat bracket and test fit it to the car with my wedge seat adaptor. Oh that is after a quick trip to the hardware store for new hardware to replace the allen head. I think bolts will work this time.
Old 08-26-2006, 10:31 PM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
added more info about the rails and the fun I have been having
Old 08-26-2006, 10:32 PM   #3
stentorian
Member#: 12959
2017 Focus RS
Pics? I could search but too lazy as I am already typing here
-Joe
edit: WOAH, I also have a 02 wrx wagon in PSM w/ VF30!!!
stentorian is offline   Reply With Quote
Old 08-26-2006, 10:34 PM   #4
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
ok later when I am test fiting I will add plenty of pics. I still have another whole seat to slice and dice or heat as the case might be.
Old 08-27-2006, 12:06 AM   #5
veightkiller
Member#: 78967
2011 335i
+1 on the pic's!
veightkiller is offline   Reply With Quote
Old 08-27-2006, 01:10 AM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
seems I am stuck for the moment as the seller of the bracket likely ground them down in the front. not allowing for height adjustment at all. So I pmed him see what his responce is. not very happy right now. As this causes problem with moving these seats forward and backwards. of coarse he never mentioned this when I bought it. Then found the problem when I went looking at what the bracket is suppose to look like. So looks like I will be contacting wedge this next week. As this simply wont work.
Anyone know where I can find the pic of what a standard recaro bottom of the seat looks like. I am wondering if I will have to trim some spacers off.
Old 10-26-2006, 01:31 AM   #7
ASpec818
Member#: 37059
03 WRX
World Rally Blue
any update on this?
ASpec818 is offline   Reply With Quote
Old 10-26-2006, 09:56 PM   #8
DocWyte
Member#: 1840
2002 M3
Oxford Green
Just look up my thread on this. I used the sparco seat bracket and I was able to use the stock Evo recaro sliders.
DocWyte is offline   Reply With Quote
Old 10-26-2006, 11:25 PM   #9
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
oh sorry. basically all you need is the bracket like wedge or sparco. adaptors and install with a 3 ohm resister.
Old 10-27-2006, 12:20 AM   #10
ASpec818
Member#: 37059
03 WRX
World Rally Blue
did you guys use the Recaro seatbelt buckles or did you reuse your stock impreza buckles?
Old 10-27-2006, 01:03 AM   #11
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
reuse oem wrx. they bolt right in
Old 10-27-2006, 02:26 AM   #12
sti04j
Member#: 124433
2004 STI
wrb
any pics on this?
sti04j is offline   Reply With Quote
Old 10-27-2006, 03:07 AM   #13
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
driver seat needs the bracket still.
Old 10-27-2006, 06:18 PM   #14
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
I have heard sparco rails fit these seats and bolt right into the wrx.
D Money is offline   Reply With Quote
Old 10-27-2006, 06:33 PM   #15
SubaruDriver502
Member#: 114182
2003 toyota corolla
RIP wrx, damn u bambi!
Steering wheel is dirty Those seats are sexy
SubaruDriver502 is offline   Reply With Quote
Old 10-27-2006, 07:47 PM   #16
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
ya I drive more then I clean what can I say
Old 10-27-2006, 11:54 PM   #17
DocWyte
Member#: 1840
2002 M3
Oxford Green
I posted a thread with all sorts of pics etc in this forum. Use the "search" function.
Old 10-28-2006, 12:03 AM   #18
THE-95-STi
Member#: 113734
2015 Vdub Golf R
Subaruless
or YOU COULD NOT BE LAZY AND POST THE LINK, here lemme do it for you GOD!!
http://forums.nasioc.com/forums/show....php?t=1108742
THE-95-STi is offline   Reply With Quote
Old 10-28-2006, 12:09 AM   #19
DocWyte
Member#: 1840
2002 M3
Oxford Green
Who pissed in your f'ing wheaties?! Who's being lazy by not taking 2 seconds to search under my user name?
Old 10-28-2006, 02:52 AM   #20
ASpec818
Member#: 37059
03 WRX
World Rally Blue
hey hybrid gti 2, im actually in the process of installing some evo seats into my car right now and I'm having trouble with the passenger seat, rear inner bolt that connects the wedge bracket to the car. The bolt seems to be too short to bolt the bracket down to the car because the adapter is 1) thicker, and 2) sticks out a bit. Did you reuse all your stock bolts or did you have to replace that bolt that I'm referring to? The other bolts fit into the other 3 holes fine.
Old 10-28-2006, 03:35 AM   #21
ASpec818
Member#: 37059
03 WRX
World Rally Blue
and did you guys bolt on the bracket to the chassis first? and then bolt on the seat/sliders onto the bracket? will this be easier?
I have the seats/sliders/brackets all bolted together already. can this cause install problems?
Old 10-28-2006, 06:07 AM   #22
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
I had the same problem with the bolt. loosen the other bolts and try again.
Old 10-28-2006, 09:01 PM   #23
ASpec818
Member#: 37059
03 WRX
World Rally Blue
well i had to replace the passenger seat rear inner bolt because the bracket wasn't a good fit. i got a longer hex bolt from home depot and it went in. the driver's side bracket was a better fit and i was able tor euse the stock bolt.
Question, were you guys able to cover the rear bolts in the seats? I don't think I can reuse the stock plastic pieces that used to cover the two rear bolts on each seat. looks kinda funky with golden/silver bolts showing.
Old 10-28-2006, 09:03 PM   #24
ASpec818
Member#: 37059
03 WRX
World Rally Blue
oh and another thing, what is that wire/plug that connects to the seat belt buckle on both the evo seats and the wrx driver seats? I assume it was important so i took out the whole cable/plug from the stock wrx seats and reused it on the evo seats. However, I couldn't figure out how to remove the plug from the evo seats so I just cut the two wires. Figured Id just splice em back in if I wanted to sell the seats.
BRIDE Seats - 03 WRX Install info. skimobile Interior & Exterior Modification 10 12-03-2019 03:59 AM
To WRX owners with their stock tranny.. Rayme Transmission (AT/MT) & Driveline 55 12-21-2007 05:34 AM
SEAT to Expand Range with NEW B-Segment Model NYCshopper Non-Subaru News & Rumors 0 05-30-2007 01:54 PM
OEM keyless & alarm install with no instructions kingsubi Electrical & Lighting 2 10-14-2004 11:15 PM
EVO seats in WRX? ChrisF Interior & Exterior Modification 16 02-01-2004 10:53 PM
