Welcome to the North American Subaru Impreza Owners Club Wednesday January 29, 2020
Old 12-28-2010, 11:12 PM   #426
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
i need the part # for the MAF sensor on a 1998 v4 ej20k sti sedan.
i found this number (22680AA271) in one of the first posts, i looked it up on genuinesubaruparts.com/subarupart.com, they both have it but its expensive and i want to verify its the right number before i drop $300 and get the wrong part.
thanks!
route69wrx is offline   Reply With Quote
Old 12-29-2010, 03:45 AM   #427
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Yes is correct for all EJ20K engines (orange sticker). The contemporary EJ20G engines use the AA280 (purple sticker). All pre-1997 EJ20G engines use the AA160 (green sticker).
Marnix is offline   Reply With Quote
Old 12-29-2010, 12:10 PM   #428
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
Thumbs up
thanks for the speedy reply. im going to order one right now, i keep throwing maf codes for my 20k and the car wont run right now!
Old 12-29-2010, 01:09 PM   #429
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
Thumbs up
part ordered from subarugenuineparts, eta 10 days. (stupid snowstorm on the east coast)
apparently there are only 6 5, in the entire USA, so if anybody with a 20k needs a maf, you better get one before they're all gone...
Old 12-30-2010, 09:11 AM   #430
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
They can order from Japan as long as the parts are in production, EJ20K parts *should* be available until 2018!
Old 01-02-2011, 03:34 AM   #431
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
i like to hear that
elislider is offline   Reply With Quote
Old 01-17-2011, 12:18 PM   #432
onurba32
Member#: 203150
1996 gf8
red
I will buy a jdm v4 sti cylinder heads but how can I understand its a real jdm v4 sti heads?
I need a part number or code? ı dont know
thanks
onurba32 is offline   Reply With Quote
Old 01-17-2011, 03:02 PM   #433
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Open them up and check that the valve buckets are under bucket shim and that the cams have the correct markings.
Old 01-18-2011, 02:53 PM   #434
mad max (ii)
Member#: 266550
1998 Impreza WRX RA
these are the numbers that were provided
V4 WRX
EJ 20K
piston rings: 92mm 12033AA730
valve seals: intake 13207AA120 exhaust 13211AA110
head gasket: 11044AA355
main bearings
-(#3 thrust bearing) 12209AA000
rod bearings: 12108AA290
rings: 12033AA730
rear main seal: 806786040
mad max (ii) is offline   Reply With Quote
Old 02-02-2011, 03:47 AM   #435
SubiePrez
Member#: 259757
2000 Subaru Impreza
White/Gray
Default MAF Sensor
Hi, I aslo need a MAF sensor for my EJ20K Ver 3.
Trans# 9R-TY752VBCAA and I'm using
ECU# 6S 2261 AD170 /A18-000-D35.
I just want to make sure this part# 22680AA271 is what I need. They sell this part at Chaplins Subaru Genuine Parts here in Bellevue WA for $237.70.
Thank you!!!
SubiePrez is offline   Reply With Quote
Old 02-02-2011, 06:13 AM   #436
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Yes it is.
By the way, the head gasket for the EJ20K is 11044AA463, not available in the US. You can use the 11044AA355 though, smae thickness but composite instead of MLS so not as strong.
Old 02-04-2011, 03:23 AM   #437
SubiePrez
Member#: 259757
2000 Subaru Impreza
White/Gray
Thank you Marnix!!!
Old 02-06-2011, 11:43 AM   #438
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
Hey Marnix I am looking for sodium filled 20K valves. Are these the correct part numbers??
Intake-13201AA340
Exhaust-13202AA350
The prices on these above are Intake-$10.94 Exhaust-$14.60. At that price I figured that was low and wanted to make sure they weren't 25D valves.
AWD P & A is offline   Reply With Quote
Old 02-11-2011, 10:05 AM   #439
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
The numbers above are for the EJ20G and indeed EJ25D. They are not hollow (intakes) or sodium filled (exhausts).
The ones you need are 13201AA320 for intakes and 13202AA330 for exhausts.
Old 02-11-2011, 04:56 PM   #440
elislider
Member#: 133923
03 Legacy GT wagon
Yes it is.
alternatively you can do Cometic C4261-051 (x2) they are MLS equivalent to the JDM hg's and only around $90-$100 for a pair
Old 02-12-2011, 03:17 AM   #441
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
But not nearly as good...
Old 02-12-2011, 11:38 AM   #442
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
+1, oem mls are the best IMO. I've had both in my hands
2slofouru is offline   Reply With Quote
Old 02-13-2011, 03:30 AM   #443
elislider
Member#: 133923
03 Legacy GT wagon
true but t he JDM ones are just harder to find, especially quickly or cheaply. i cometic ones are least better than composite
Old 02-18-2011, 05:27 PM   #444
jstbstn
Member#: 35020
02 WRX - Stage WTF
04 WRX Wide Wagon - Stg 3
92 JDM WRX GC8A EJ20G
Threw 2 CEL's this AM 12(starter circuit) and 21(coolant temp sensor/circuit)
Looking for help finding the correct parts to fix the issues.
Thanks in advance!
jstbstn is offline   Reply With Quote
Old 02-18-2011, 10:16 PM   #445
elislider
Member#: 133923
03 Legacy GT wagon
Thanks in advance!
check your grounds in the engine bay and your fuses!
Old 02-18-2011, 11:09 PM   #446
jstbstn
Member#: 35020
02 WRX - Stage WTF
Fuses are fine and I can't see any grounding issues. An ECU reset got rid of the codes and they haven't returned yet so I don't think a fuse issue would allow this. It was a much colder morning today than it had been for weeks and it was at least 10 degrees warmer when i did the reset. I'll see what tomorrow morning brings.
Why did those codes make you think grounding issue? Maybe it's worth doing some extra grounding considering the age of the car?
Old 02-23-2011, 05:19 PM   #447
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
EJ20G: 10105AA120
EJ20K: 10105AA380
Sorry for the delay.
The EJ20G head gasket part number is not in the system. I'm about to buy a 95 EJ20G WRX shortblock to mate up with my 97 Forester EJ20G/K heads. I need the EJ20G head gaskets right?
Is there a working part number for them?
kimokalihi is offline   Reply With Quote
Old 02-24-2011, 01:42 AM   #448
mike-tracy
Member#: 135290
2000 Impreza
BRP
Man, what a noob. 11044AA355 (that's for 1)
mike-tracy is offline   Reply With Quote
Old 02-24-2011, 03:20 AM   #449
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Those 10105AA numbers I quoted are not for head gaskets but for complete gasket and seal kits. Keep paying attention
Old 02-24-2011, 03:40 AM   #450
kimokalihi
Member#: 186972
91 Legacy SS EJ20G
Pearl White
Oh I was talking about this one 10105AA120.
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 08:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 11:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-30-2003 12:23 AM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 10:21 AM
