Welcome to the North American Subaru Impreza Owners Club Sunday January 19, 2020
Old 07-07-2014, 06:59 AM   #2376
Spec C
Member#: 77737
2003 spec C
Originally Posted by Seraphinwolf View Post
I feel the EZ is tighter tolerance that allow you to push the EZ faster than the EG. The EG NA is more the "big block" and best for NA high power but just not gonna be able to get things "tight" in the EG without all custom stuff. It does allow boring and such a little where the EZ's walls won't.
For NA I should think EZ by far the best especially EZ36, the factory clearances are “minimal” the factory piston to wall clearance on my engine was less than a thou
Spec C is offline   Reply With Quote
Old 07-07-2014, 09:06 AM   #2377
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
I don't trust the 3.6... Being at the limits of the block before adding anything to it leads me to feel it will be destroyed too easily with even bolt ons. We've already seen it can't handle any boost because of forcing the stroke and everything.
Seraphinwolf is offline   Reply With Quote
Old 07-07-2014, 09:13 AM   #2378
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Did workz last night bored at my parents' taking care of their dog.
Old 07-07-2014, 12:04 PM   #2379
vicious_fishes
Member#: 158864
2003 SOHC destroker
ez30 is more practical. otherwise eg33 is better. uses ej22 pistons etc.
vicious_fishes is offline   Reply With Quote
Old 07-07-2014, 12:37 PM   #2380
Seraphinwolf
Member#: 150922
97 OBS EZ30R
EG33 uses it's own pistons that are the same bore as the 2.2, but are not the 2.2 pistons.
Old 07-08-2014, 03:48 AM   #2381
vicious_fishes
Member#: 158864
2003 SOHC destroker
i was under the impression you can use 22 pistons, get a rod to suit... done?
Old 07-08-2014, 05:52 AM   #2382
AgentJ17
Member#: 306411
1995 STi RA
very eg33 such braap
A rod to suit the EG33 is the majority of Subaru rods on the market. Almost any EJ rod is interchangeable with EG33 rods.
I understand that you can use EJ22 pistons, they're just completely not optimum for the EG's combustion chamber.
AgentJ17 is offline   Reply With Quote
Old 07-08-2014, 07:02 AM   #2383
Seraphinwolf
Member#: 150922
97 OBS EZ30R
^This.
While the work, it does not mean they match or any specific EJ22, of which there are a few, uses the same piston. Hell the EJ255 and EJ257 are nearly identical until you get to small details like the combustion chamber volume in the head and the pistons' dish volume.
Old 07-08-2014, 02:28 PM   #2384
vicious_fishes
Member#: 158864
2003 SOHC destroker
fair enough guys. i've seen plenty of pretty mean eg33's with them so they can't be too sub-optimal...
http://www.raptorsc.com.au/subaru9.html
4psi/no intercooler made 290whp. 51% power increase.
Old 07-08-2014, 05:00 PM   #2385
Seraphinwolf
Member#: 150922
97 OBS EZ30R
No intercooler because you don't need one really on a pro charger. Interesting how Paul chose to mount the belts... Hmmm...
Old 07-09-2014, 09:51 AM   #2386
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Where have we seen that?
You can't see any of the numbers on the Y-axis on that horrible screen capture, but just looking at the spacing of the curves, there's not a 51% gain there. The website you linked to claims significantly less wheel HP with double the boost, so something doesn't add up.
Old 07-09-2014, 10:19 AM   #2387
Seraphinwolf
Member#: 150922
97 OBS EZ30R
It's at ECS so likely there or local. You are based out of CT after all. And yeah I've seen a LOT of reputable places say you need to spend like $3k on a custom crank to hold up. Could be on race gas or something but I don't trust it
Old 07-09-2014, 12:24 PM   #2388
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'd imagine it's 51% max gain over stock. obviously marketing...
point was though that they handle boost.
Old 07-09-2014, 12:35 PM   #2389
Seraphinwolf
Member#: 150922
97 OBS EZ30R
The point was made by MUCH bigger and frankly better reputable COBB , that it can't.
Old 07-09-2014, 08:11 PM   #2390
thejameshimself
Member#: 379868
05 9-2X Linear
Midnight Black Mica
50% gains. Wait, that sounds fake... 51% gains
thejameshimself is offline   Reply With Quote
Old 07-12-2014, 02:26 PM   #2391
vicious_fishes
Member#: 158864
2003 SOHC destroker
i've got in contact and i'll see what reply i get back guys. stay tuned.
Old 07-12-2014, 03:02 PM   #2392
Seraphinwolf
Member#: 150922
97 OBS EZ30R
With who? ECS? You won't find me ever doing business with them again.
http://forums.nasioc.com/forums/show....php?t=1285411
Looking for other links that I've come across over time.
Old 07-12-2014, 03:13 PM   #2393
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Old 07-12-2014, 04:40 PM   #2394
vicious_fishes
Member#: 158864
2003 SOHC destroker
here's the boosted ez36 owners thread guys:
http://legacygt.com/forums/showthrea....html?t=227730
turns out he had an exhaust on it, which makes a MASSIVE difference to sc'd engines.
Old 07-12-2014, 06:24 PM   #2395
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Exhaust makes a difference on every car... That's not exactly some kinda big news. Also doesn't prove it can really handle boost. Just that some light boost can be applied. Now an EJ222 can handle boost in stock form VERY well! If we can see a 10+ lb regular use or even rare track day or autocross 3.6 surviving that will be news. I'm still wondering though why the new FA's are handling boost where the EZ36 that their tech was originally tested on aren't. Specifically the crank and rod configuration combo.
With the talk of bringing back the SVX for 2017 and that it will have an assumed new 3.3 flat six with very tempting numbers! Now THAT motor I would love! Mostly cause of the final addition of DPFI! Even more expensive to work on, but SO WORTH IT!!!
Old 07-12-2014, 07:16 PM   #2396
vicious_fishes
Member#: 158864
2003 SOHC destroker
my point was that the exhaust shows the gains aren't quite what we thought they would be.
also found a decent turbo to maybe buy. unsure how to run the oil line though. sammich plate/T line from the oil cooler? nfi about what oil pressure should be in the turbo.
Old 07-14-2014, 10:57 PM   #2397
phil.greiner11
Member#: 388081
2004 H6 STI
hey guys,
I have been pretty busy so I haven't been able to get on here much. Not to take you away from the 3.6L discussion, but i figured i'd let you know that I pretty much finished my swap. Still messing with the tune to get all the kinks out, but as of yesterday I am dailying it. It runs nice and has a bunch of torque. Really fun to drive around town. I'm only running 5psi right now but I'm gonna bump it up soon.
To answer your questions from before vicious_fishes I did something very similar to cardoc to get the wrx injectors to fit. They were 5mm shorter than the stock ones so I cut the rail mounts down 6mm just to make sure I got a good seal. Then I took the weird tips off the stock ones and put them on the wrx ones. That part was very easy. Both injectors have the same head once you remove the weird tip the stock ones have. I just moved the o-ring and tip over to the new ones. to get the seal for the vac/boost line running through there I made a collar the same as the stock injectors out of delrin on the lathe and jb welded it to the new injector in the right spot. I would put some pictures up but am still figuring out how to do that ha.
Anyway just thought I should tell you there is a running boosted EZ30 STI in New Jersey as of yesterday!
phil.greiner11 is offline   Reply With Quote
Old 07-14-2014, 11:19 PM   #2398
vicious_fishes
Member#: 158864
2003 SOHC destroker
phil - if you email them to me i can put them up for you. my address is throwaway3053 and a gmail address. i'd be VERY interested to see how you did it and/or if you could make me a set?
for everyone else as well: got in contact with PAR about a group buy of rods. also asked them if they could make some 9:1 pistons for us. waiting to hear back.
Old 07-15-2014, 12:01 AM   #2399
jdogma
Member#: 242350
2013 Carma Wolf EZ30
black
Who is ECS?
jdogma is offline   Reply With Quote
Old 07-15-2014, 12:19 AM   #2400
EVL RS-T
Member#: 30071
2001 RS-T
2015 XT
Originally Posted by jdogma View Post
Who is ECS?
East coast swappers.
EVL RS-T is offline   Reply With Quote
Vag-Com cable resource thread cooleys04 Open Source Reflashes 283 04-03-2018 02:04 PM
The Impreza @$$ Thread - The Beautiful Impreza Backside! PICS! Upscale_Automotive Member's Car Gallery 8 10-03-2007 05:56 AM
The 2008 Impreza Photoshop thread...post them here adizon Member's Car Gallery 307 09-20-2007 12:36 AM
The 2006 Impreza/Impreza WRX/Impreza WRX-STi thread (merged thread) wrxpeed News & Rumors 938 05-17-2005 12:11 AM
Photo - Anders "loving on" the H6 Impreza Fred South East Region Forum 8 02-23-2004 06:04 PM
