Welcome to the North American Subaru Impreza Owners Club Wednesday January 29, 2020
Vancouver Impreza Club
Old 04-23-2010, 12:03 PM   #26
mcwc
Member#: 196262
1999 RSTi, Silver
1990 240DL, Gold
Originally Posted by Loomin View Post
yep we just covered that bit. actually a tune will not solve the issues. 5 pins on the ECU have been swapped to prevent easy changing of the ECU. i doubt a simple tune could correct wiring of:
Vehicle speed sensor
A/C switch
Ignition switch
Test mode connector and most of all,
the fuel pump controller.
directly swapping an 04 ECU into an 05 will certainly cause it not to start.
And I thought it was just swapping the pins around. GL with tracking down an 04 STI ECU.
you might be able to send the ecu to cobb to have it unmarried. alot easier than tracking down whoever has the handheld.
And whoever bought that COBB Accessport would have had to get COBB to unmarry it, so you'll eventually have to send it back to COBB.
mcwc is offline   Reply With Quote
Old 04-23-2010, 12:15 PM   #27
STiGuy23
Member#: 215108
02 rex sti and jdm
flat black stealth mode
well i have a question now. im going to be doing the same thing here in a couple months and i already have all the parts. 05 sti harness and steering column into my bugeye with an 04 sti ecu. so once i bolt everything up and drop the harness in and get everything connected, what happens to the immobilizer wiring on the 05 harness? does the 04 ecu simply have "dead pins" in place of immobilizer pins form an 05+ ecu? also i have the steering column too from the 05 and idk if it is necessary to swap being that i havnt even started this project yet and havnt compared it to my bugeye column, but im noticing the immobilizer box mounted to it. do i just plug it in to the corresponding plugs on the 05 harness and let it fly or will any of this immobilizer wiring/box cause any issues with the 04 ecu?
^^^^other than this, im set thanks
STiGuy23 is offline   Reply With Quote
Old 04-23-2010, 02:45 PM   #28
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Ideally we'll like to use a clean 04 STi just to keep the options open
minifreak is offline   Reply With Quote
Old 04-23-2010, 03:06 PM   #29
Drakar
Member#: 68402
2016 WRX
if the 04 ecu has ecutek, you can have subaru flash over it, itll wipe the license off it and back to stock full access if you wanted to do open source.
I think cobb ap can also do the same thing as well.
Drakar is offline   Reply With Quote
Old 04-23-2010, 03:16 PM   #30
milkface
Member#: 143742
2004 STi wagon
2008 WRB Forester XT
Trying to get in contact with RR this morning, but I get their answering machine.
Will try the junkyard to see aswell.
If all else fails today.....
IHT - perhaps I'll take you up on your offer of borrowing your ecu so we can test/fire up the car till I can get my own.... Mainly, we just want to see if the car will start... For tuning, ecutek/Cobb, I won't be ripping it till it's proper
thanks!
milkface is offline   Reply With Quote
Old 04-23-2010, 03:41 PM   #31
milkface
Member#: 143742
2004 STi wagon
So yeh, I just finish talking to Steve at RR. super friendly and helpful, unfortunately, they don't have one that they can sell...
So it looks like Aldergrove junkyard is the next try to get one for the weekend.....Minifreak is calling them now.
Another option that kinda popped up and might be worth trying is an 04 Forrester XT...2.5L turbo ECU. it should work too, but there are differences that I don't want to mess with...I rather find the 04 Sti ECU instead.
fingers crossed here that Aldergrove has one and won't make me pay up the arse for it. :P
Old 04-23-2010, 04:02 PM   #32
wrxinsquish
Member#: 186676
2006 STI
Undecided...
Charles...
#'s on the 04 FXT MT Turbo ECU (the AT ECU is different again, so be careful here)
22611AJ470
22611AJ471
22611AJ472
Price is about the same as the one I quoted you.
Steve
wrxinsquish is offline   Reply With Quote
Old 04-23-2010, 05:58 PM   #33
milkface
Member#: 143742
2004 STi wagon
thanks steve.
here's what i read the difference being from a forester XT...
You could even use a Forester XT ECU with the only major difference being the gear determination thresholds having only five slots instead of six.
not sure exactly what that means...is he referring to a 5MT to a 6MT difference?
If it's no biggy of a difference, (since I see lots of wrx guys running 6MT on their wrx ecu's)
did you happen to have an used 04 FXT MT turbo ECU at the shop for sale?
Or did you mean "Price is about the same as the one I quoted you" as in at Stealership and their crazy prices?
thanks again,
-C
Old 04-23-2010, 05:59 PM   #34
milkface
Member#: 143742
2004 STi wagon
whoops double post.
Old 04-23-2010, 07:17 PM   #35
wrxinsquish
Member#: 186676
2006 STI
Undecided...
Sorry for the confusion on my earlier post. I don't have any FXT ECU's for sale, but if you were to find one, dealership or otherwise, the "new" price is about the same as the 04 STI one we talked about on the phone.
As for ECU compatability (WRX, STI, FXT, or otherwise), I'm personally not knowledgable enough on all the differences between them to offer ideas or suggestions.
Steve
Old 04-23-2010, 08:14 PM   #36
wrxinsquish
Member#: 186676
2006 STI
Undecided...
Charles... check your PM.
Old 04-23-2010, 08:16 PM   #37
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Originally Posted by milkface View Post
thanks steve.
thanks again,
-C
The Gear Determination threshold is not an issue, I looked at the WRX VS STi maps and the tables are the same size but the values are different.
Old 10-26-2019, 10:20 PM   #38
Ajzride
Member#: 507776
2006 818 with EJ25T
Primer
Default STI and WRX Are Sometimes Different
I know this thread is ten years old, but I read it a dozen times trying to solve my an issue I was working through, so I thought it might be fruitful to someone in the future to know what I learned.
I was trying to get a 2006 WRX 2.5Turbo working in my Factory Five 818 without the immobilizer. I bought a 2004 Forrester XT Turbo MT ECU hoping to move the few pins necessary and get things up and running. After getting the 2004 ECU in hand I started working through the wiring diagrams to figure how which 5 or 6 pins I needed to move, and found that only 5 or 6 pins lined up. It took another day or two of research to figure out that the 2006 WRX Turbo wiring harness is completely different from the 2006 STi wiring harness. The 2004 FXT ECU would work for me, but I would have to heavily modify my engine harness.
Hopefully I can save someone else from buying the wrong ECU down the road.
Ajzride is offline   Reply With Quote
05 STI swap into 04 WRX Wagon. HELP! pismobeachrider25 Built Motor Discussion 6 04-12-2010 10:58 AM
HELP 06-05 STI swap Springs zapjacks Brakes, Steering & Suspension 2 10-19-2009 05:33 PM
05 sti swap got stuck at front hubs! HELP! PICS! snowcrzy Transmission (AT/MT) & Driveline 11 10-10-2006 06:24 PM
Help! My 05 STi has no bump stops Jitenshakun Brakes, Steering & Suspension 6 01-28-2006 03:33 PM
Lil help please 05 STI Hevvyn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-08-2005 09:36 PM
