Welcome to the North American Subaru Impreza Owners Club Friday January 17, 2020
Old 06-09-2010, 07:31 PM   #1
While At Rome
Member#: 247550
09 STI
Default 02 wrx - only putting out 7 psi boost
UPDATE: see last page
BACKGROUND: I just picked up an 02 WRX last week and i have been replacing **** on it that was broken. The latest thing was a replacement aftermarket up-pipe and a boost gauge.
PROBLEM: I read about 20 vacuum at idle, and when i get on the gas i hit 7 psi, in all gears. I disconnected the battery to install a head unit and ran it for about 30 miles before i did the up pipe.
I know a lot about hondas as i have had 4 integras/civics swapped them, and then turbo'd them.
I was looking at it today and im guessing the boost control soleniod is the blue peice off to the passenger side of the car w/ the WG and inlet vac lines going to it. I dont know if it works, but it is hooked up.
I was poking around in the bay and found an HKS T line off the BOV, and it was leading up into the clock area. I disconnected it and it seemed to have no effect on how it ran. Possibly lead to an aftermarket boost controller that had since been removed or is still in? maybe a boost gauge?
While At Rome is offline   Reply With Quote
Old 06-09-2010, 08:36 PM   #2
SHARP_DAL
Member#: 183247
2005 WRX
- Yes, its the bcs if there are no leaks and everything seems connected you should be okay.
- Yes, thats the tap for the boost gauge with that open (leaking air) your going to have a boost leak which is probably causing your low boost pressure. Close that off and try again.. if its still running low boost change out the bcs and check your vacuum lines.
SHARP_DAL is offline   Reply With Quote
Old 06-09-2010, 08:57 PM   #3
While At Rome
Member#: 247550
09 STI
I actually ran my Boost gauge off that T that i found and its only reading 7 psi still with that leak sealed off.
We are testing the BCS according to the service manual at the moment.
Old 06-09-2010, 09:14 PM   #4
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
7psi? Wastegate pressure?
fellstar is offline   Reply With Quote
Old 06-09-2010, 09:15 PM   #5
SHARP_DAL
Member#: 183247
2005 WRX
whiles your thre check to see if your lines from the bcs to the turbo are routed probably and not leaking it sounds like your running on spring pressure and your bcs is dead..
Old 06-09-2010, 09:29 PM   #6
While At Rome
Member#: 247550
09 STI
Everything about the BCS troubleshooting says that the ECM needs replaced. I looked at the ECM and it looks like some of the plugs have been taken out.
Is it possible that the vac line i found was an electronic boost controller and the ECU is tuned to disable the BCS?
Old 06-09-2010, 09:41 PM   #7
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Yup. There's a few reasons you could be seeing WGP, some have already been mentioned. 20inHg is fine... Sometimes you will audibly hear a boost leak, but I don't think a leak is the issue. Signs pointing toward BCS sound fruitful.
OrbitalEllipses is offline   Reply With Quote
Old 06-10-2010, 01:00 AM   #8
2LFTMFW
Member#: 249040
02 Wrx
Wrb
Prolly has lines hooked up incorrectly. Check the wastegate vacumn lines and compressor housing lines
2LFTMFW is offline   Reply With Quote
Old 06-10-2010, 01:38 AM   #9
While At Rome
Member#: 247550
09 STI
I doubt that it is a leak, if it was a leak i doubt id be seeing 20 @ idle. Also the boost levels dont really change from 7 psi like a leak. I had an interally gated 48 trim t3 on an older car and it acted the same way. I dont think the BCS is engaging at all, now whether it is the ECU or the BCS is what im trying to figure out. Ill look at my BCS vac lines tomorrow perhaps they are swapped, but all of my other lines are hooked up correctly that was the first thing i checked. Going to call and get a price on a new BCS tomorrow anyways.
Old 06-10-2010, 02:32 AM   #10
van_dutch
Member#: 198633
2004 WRX
Make sure you have the infamous pill in there, assuming the lines are connected correctly.
van_dutch is offline   Reply With Quote
Old 06-10-2010, 03:55 AM   #11
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
May as well spring for a good EBCS or MBC (just make sure you know about PTFB etc..).
Old 06-10-2010, 10:56 AM   #12
While At Rome
Member#: 247550
09 STI
ok after some searching i think i have figured it out.
i know that the T isnt OEM i had to replace it because it was broken... could this be the source?
Old 06-10-2010, 11:21 AM   #13
WhyHelloOfficer
Member#: 193989
2007 Stormy Blue
Blown Roadster
I can't view Photobucket pics at work. However, It sounds like your boost control system is a hackjob that was returned to stock. Take a look at this article to get a little more insight on the Subaru boost control system.
Subaru Boost Control Explained V1.09
http://www.cobbtuning.com/info/?ID=3482
As it was mentioned earlier, make sure that you've got the correct restrictor pill in the correct lines. 7psi is definitely wastegate boost. With you having proper vacuum at idle, I'm going to chalk it up to lines not being hooked up correctly.
WhyHelloOfficer is offline   Reply With Quote
Old 06-10-2010, 06:24 PM   #14
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
im having the same exact problem man. i went on alldata and it says the reason for a p0246 code is a faulty/bad ecm and a faulty bcs. i swapped a different motor and my 18g wasnt making any boost AT ALL. installed a DOM 3 last night.. NO BOOST AT ALL. i dont know what the heck it is, but i used to hear clicking from my passenger side when i was on the throttle going into boost, i no longer hear that. so i am also wondering if its the bcs or ecm. or both. now heres the OTHER thing... im running a manual boost controller and an external wastegate...which shouldnt use an EBCS in the first place.
SikSilvrSuby is offline   Reply With Quote
Old 06-10-2010, 10:06 PM   #15
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Parallel EBCS with MBC is a pretty solid solution. EBCS controls part throttle and IWG, and the MBC contolls WOT and EWG. There's a thread around here somewhere with all the info on it.
Old 06-10-2010, 10:28 PM   #16
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
that was what i had before, only there was no IWG. so i dont know exactly what the ebcs was doing.. maybe just recieving a signal from the EMS and fooling it, to allowing boost to build, and then the boost was actually controlled manually (MBC,EWG).. would a re-tune or re-flash cure the EMS or would i need a new one no matter what because of the previous catastrophic engine failure..
Old 06-11-2010, 12:40 PM   #17
02blueru
Member#: 80012
04 BMW M3
Ducati 620 Dark / 08' 848
Has the turbo been replaced? If so and it was from a 2006+ model you probably have the wrong wastegate. Swap it out for the original.
02blueru is offline   Reply With Quote
Old 06-11-2010, 12:52 PM   #18
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Brace the waste gate arm so it will not open up. Go for a spin around the block and roll up into boost very slowly. If you can get above 7psi its a 99.9% chance your boost controller is bad. I'd just put a manual BC on it and call it a day.
dangerousatom is offline   Reply With Quote
Old 06-11-2010, 01:27 PM   #19
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Have you considered that the boost solenoid is dead and needs replacement. As 7psi is common with this problem.
Old 06-13-2010, 02:34 AM   #20
While At Rome
Member#: 247550
09 STI
i think the restrictor pill is missing. I briefly attempted to feel it after driving the other day and was unable to find it. I will be looking at it more closely tomorrow. Just drove from PA to Salt Lake City.
Old 06-13-2010, 01:00 PM   #21
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
Subaru Stars
Im new to this site and well, I purchased my Subie 1 year ago and its always been a bit slugish. Its always pushed around 7pis boost and I know it has alot more potential! Ive read over all the info on here and it sounds like my turbo is ghetto rigged! I looked at the pics from cobbtuning.com it looks like my car is missing the t fitting and the waste gate solenoid? Was wondering where it is on my car. Pls help...
Jerembo47 is offline   Reply With Quote
Old 06-13-2010, 01:04 PM   #22
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
pics need the "img"
Old 06-13-2010, 01:07 PM   #23
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Where is your boost controller?
Old 06-13-2010, 01:09 PM   #24
Jerembo47
Member#: 249219
2007 WRX TR
World Rally Blue
I dont know? Is a boost controller a stock piece? Im a newby sorry if I ask alot of dumb questions.
Old 06-13-2010, 02:59 PM   #25
While At Rome
Member#: 247550
09 STI
well thanks for jacking my thread. Jer;embo go read up so u know what parts are supposed to be there
I am missing the restrictor pill in my inlet-to-T vac line. is there a part no i can get from autozone or do i need to get that from the dealer??? If that doesnt fix it, new boost control it will be.
There are a few yards around here, is the vac line/pill the same for 02-05, or even more cars?
Thanks, Bill
Stage 2 WRX Only Puts Down 214 hp? Is This True? Turbo20VJetta Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 11-02-2005 09:38 PM
alternator only putting out 12.4 volts yellowscooby New England Impreza Club Forum -- NESIC 1 06-06-2005 03:27 PM
Only 7 PSI boost with STi Tanman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-03-2004 12:26 PM
How Many CFM's of air does the stock WRX turbo put out? BrysImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-02-2002 07:55 PM
Help! My WRX is Only Putting Out .5 bar (7psi) of Boost clsmooth71 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-01-2002 10:49 AM
