Welcome to the North American Subaru Impreza Owners Club Saturday January 25, 2020
Old 11-04-2018, 07:31 PM   #2676
T-37
Member#: 175624
0304 WRX WRX
SY WRB
It would be great if they filled the gaps between
T-37 is offline   Reply With Quote
Old 11-05-2018, 08:41 AM   #2677
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
Originally Posted by Fierysun View Post
What kind of built 4EAT issues is he having and was the tranny done by IPT?
He's down in Australia. I think it was Rigoli or whoever did their tans.
Old 11-05-2018, 08:42 AM   #2678
Homemade WRX
Member#: 33782
96 in the garage
They're not close enough already? 6758 and 7163...
Old 11-05-2018, 12:27 PM   #2679
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
I think they're close enough, but still wish they did a .64 hotside 7163. We're really a niche for BW though with our relatively unique turbo location. On my inline 4's with very short runners there's very little difference in spool time between the two. When you've got 3 feet of piping it is more pronounced though.
subydude is offline   Reply With Quote
Old 11-05-2018, 12:27 PM   #2680
subaru_gc8
Member#: 29292
2004 WRX wagon
They have a 7064
subaru_gc8 is offline   Reply With Quote
Old 11-05-2018, 04:05 PM   #2681
subydude
Member#: 80649
Dusty
Originally Posted by subaru_gc8 View Post
They have a 7064
Not really comparable since it's the B2 frame vs the B1 so the hotsides and wheel aero are different. The data I saw on the 7064 put it slower spooling than the 7163 with roughly the same output. The steps are really 6758, 7163, 7670.
Old 11-05-2018, 04:12 PM   #2682
Waddlz
Member#: 395275
2012 STi
I know the 7163 came out after the 7064, but I have no reason why anyone would want it over the 7163. Personally
Waddlz is offline   Reply With Quote
Old 11-05-2018, 04:13 PM   #2683
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
In my case, the 7064 is a better match over the 7163 for my S2000.
yamahaSHO is offline   Reply With Quote
Old 11-07-2018, 08:37 PM   #2684
brecks
Member#: 435142
2004 STi
Java Black Pearl
To the guys running 7163s at high boost: are you using the stiffer spring in the EFR bpv?
brecks is offline   Reply With Quote
Old 11-07-2018, 09:13 PM   #2685
subaru_gc8
Member#: 29292
2004 WRX wagon
honestly it has a bigger inlet so you dont need as big of an ar to compensate for the lack of exhaust flow
Old 11-07-2018, 09:35 PM   #2686
Waddlz
Member#: 395275
2012 STi
I didn't, ran the oem one with no issues up to 27 psi. I swapped to a Forge unit later
Old 11-26-2018, 11:58 AM   #2687
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Delete
Old 12-05-2018, 01:41 AM   #2688
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
Those of you running 7163's on e85- what are your idc's at?
I was running id1000's and an AEM 320 with my dom1.5 and never went past 95%. Once I switched over to the 7163 I was hitting 130% which just doesnt seem right. I upped my injectors to 1300's and swapped in a walbro 450 pump. I am now at 103 idc on a 3rd gear pull. Is this normal or could there be something else causing these high idc's?
pearson222 is offline   Reply With Quote
Old 12-05-2018, 02:11 AM   #2689
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Did you change boost levels?
silversurfer05 is offline   Reply With Quote
Old 12-05-2018, 02:23 AM   #2690
PDXREALTOR
Member#: 468393
2017 STI
I am. What do you want to know?
PDXREALTOR is offline   Reply With Quote
Old 12-05-2018, 04:48 AM   #2691
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, UGM
Rotated EFR 6758
I'm still waiting for the 58xx they were talking about. I would be down with a smaller compressor but higher PSI map, would be great for tight courses or TT setups on the EZ motors.
Krang is offline   Reply With Quote
Old 12-05-2018, 07:39 AM   #2692
1qukSti07
Member#: 326585
2007 STi
I'm on 1300cc injectors and a 450 pump, my IDCs are around 95% at 28psi. I also went from 1100cc injectors on a dom 1.5, to the 7163. My tuner and I didn't realize how well this turbo flows (.85 EWG hotside), he said there's more left in it. I'll need to step up to 1700cc injectors to max the turbo out. My base fuel pressure is set at a modest 42psi with the vacuum line off.
1qukSti07 is offline   Reply With Quote
Old 12-06-2018, 02:44 PM   #2693
Waddlz
Member#: 395275
2012 STi
mine are mid 70s at 27 psi on E85. stock lines, ID1300s and walbro 450. however I am at altitude. My base pressure is 50 psi though.
edit* Actually just looked at my last datalog for 27 psi on E85. IDC was 77%.
Old 12-06-2018, 02:47 PM   #2694
subydude
Member#: 80649
Dusty
On ID2000's I see roughly 65% IDC on a 6758 using E85 and 33 psi.
Old 12-06-2018, 04:19 PM   #2695
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
I am running 1300's with a hardwired 450 on e85. On a 3rd gear wot pull idc is 68 @ peak boost 23psi/4600rpm. From 4650-6500rpm idc climbs to 97 as boost tapers to 20psi. My idc's were topping out at 103 on the 450 pump when it was still running off the oem fpc. Seems like I should have seen a more substantial drop in idc after hardwiring the pump.
Anyone have any thoughts?
Old 12-06-2018, 04:25 PM   #2696
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
Forgot to add that I am running the prototype 7163 (2013 pre-release) if it makes any difference.
Old 12-06-2018, 04:30 PM   #2697
Waddlz
Member#: 395275
2012 STi
you on stock rails?
whats your AFR? is it smooth through the pull?
Old 12-06-2018, 04:34 PM   #2698
pearson222
Member#: 393782
2004 WRX EWG E85
2006 RPW STi
you on stock rails?
IAG V3 rails
Redhorse Performance 6AN PTFE lines
Fuelab FPR @ 50psi
Old 12-06-2018, 04:40 PM   #2699
Waddlz
Member#: 395275
2012 STi
you positive you hardwired your FP right? The GD's are different than my GR but I believe my tuner had to set it to be 100% in the tune all the time.
Old 12-06-2018, 04:41 PM   #2700
1qukSti07
Member#: 326585
2007 STi
Do you use the factory bulkhead fitting to send the power to the pump?
I saw a large jump in amperage when I added a separate bulkhead fitting to run 10G wiring directly to the pump.
