Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 04-24-2019, 01:00 PM   #2826
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Dusty
Why aren't you commanding higher WGDC down low to bring boost up quicker?
subydude is offline   Reply With Quote
Old 04-24-2019, 01:21 PM   #2827
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I've been asked that in this thread already... Because it doesn't help on my car.
It's an .85 hot side on a 6758 at 9k ft ASL.
Below is 1,000 ft ASL:
yamahaSHO is offline   Reply With Quote
Old 04-24-2019, 02:25 PM   #2828
PDXREALTOR
Member#: 468393
2017 STI
Perrin sells an oil line with a banjo fitting on the block side.
They also have restrictors.....
PDXREALTOR is offline   Reply With Quote
Old 04-24-2019, 03:42 PM   #2829
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Old 05-11-2019, 02:17 PM   #2830
brecks
Member#: 435142
2004 STi
Java Black Pearl
For those tuners out there, what kind of AVCS are you using? I have mine set at Cobb's stage 2 values right now, but am interested in what others have done
brecks is offline   Reply With Quote
Old 05-11-2019, 03:20 PM   #2831
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
What turbo/hot side are you using?
Old 05-11-2019, 03:25 PM   #2832
brecks
Member#: 435142
2004 STi
Java Black Pearl
EFR 7163 with the 0.85 ar. Iíve been reading up on how AVCS is measured in crank degrees, not cam degrees, and that we have about 25 cam degrees to play with. Cobbís stage 2 map doesnít go anywhere above 25 crank degrees. Iím sure this has to do with valve to piston contact
Old 05-11-2019, 03:44 PM   #2833
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
You should not be able to advance it to a point of contact. I ramp mine in harder than 25 and once the turbo is making boost, I slowly taper it down to nothing. I can't recall where I have it goes zero without my map in front of me.
Old 05-11-2019, 04:15 PM   #2834
brecks
Member#: 435142
2004 STi
Java Black Pearl
Something along these lines but more aggressive?
https://i.imgur.com/N7HaDZG.png
Old 05-14-2019, 06:08 PM   #2835
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Anyone here try adding a restrictor? I've made my AOS/PCV far more effective and I still have a hint of oil smell out the exhaust after a hard run. I know this was discussed earlier, but don't remember where it went.
Old 05-14-2019, 06:12 PM   #2836
PDXREALTOR
Member#: 468393
2017 STI
I have one in mine, at the turbo. Perrin highly suggests two of their restrictors - one at the block end, and one at the turbo end.
Old 05-14-2019, 06:36 PM   #2837
Waddlz
Member#: 395275
2012 STi
I've been meaning to see how much oil pressure I have at the turbo. I have a mechanical oil pressure gauge and just need a 4AN to 4AN fitting with a 1/8 NPT hole for the gauge.
Waddlz is offline   Reply With Quote
Old 05-14-2019, 07:12 PM   #2838
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Got a link for the Perrin recommendation?
Old 05-14-2019, 09:59 PM   #2839
PDXREALTOR
Member#: 468393
2017 STI
Perrin.com
Call and talk to them
Old 05-14-2019, 10:08 PM   #2840
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Eh... I'll just continue with my plan to install a separate restrictor.
Old 05-15-2019, 01:48 PM   #2841
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I just ordered two different in-line sizes and will try them. It'd be nice to no longer have any faint, burnt oil smells again.
I also added one more mm of preload on my 2-port actuator (+8mm total) and put my AOS venting to test. The car is pretty fun, even at high altitude.
Old 05-17-2019, 08:50 PM   #2842
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Got a 1.6mm restrictor in now... Now I need to go see what it does.
EDIT: That seems to have worked on the first drive. I will continue to monitor.
Old 06-02-2019, 11:11 PM   #2843
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Finally made a drag strip pass with this 6758, running 23-24 PSI. DA for Bandimere was 8,700 ft. Waddlz also came out with his 7163, however, I am still waiting to get it on a dyno to turn it up, so the cars were pretty close. We both really came to do the roll racing portion, but made a few passes from a dig. I think we only really went after a decent time on the last pass, where I got a 12.4 @ 111 and he got a 12.9 @109.
I might turn up the boost and go on a cooler night and see if I can't pull off an 11 second pass.
Here are the 2 passes Waddlz and I made next to each other. He goofed on the first pass and I had launch control set too low and missed 5th gear. The second pass was decent for both of us.
I also did some roll racing against a 500whp SHO that I tune.
Old 06-03-2019, 12:33 PM   #2844
Waddlz
Member#: 395275
2012 STi
man that was fun.
Old 06-04-2019, 01:14 PM   #2845
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I will be purchasing a 4-port EBCS. I am out of WGDC when slamming through gears.
Old 06-04-2019, 01:36 PM   #2846
TDagen
Member#: 163648
V9 6mt R180 Brembos
That SHO is awesome! We had that style Taurus growing up. My step dad talked about always wishing it was a SHO, LOL!
Looks like your only hitting your target boost in 5th and all gears are 100% wgdc LOL!
TDagen is offline   Reply With Quote
Old 06-04-2019, 02:12 PM   #2847
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I've got it limited at 95%. If I do a single 4th gear pull, it can ramp up and follow target, but once you start running through gears, it just can't keep up. 5th gear on this year STi is such a huge gap from 4th, so the load on the motor goes way up!
That SHO has a stock motor with a Vortech S-trim and E85. I gained 25 mph in the back half, he gained 30 mph! I just had him swap from ID1000's to ID1300's, so I'm hoping he'll upgrade to a blower from this generation and maybe shoot for 600whp.
Old 06-04-2019, 04:31 PM   #2848
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
What is the throttle position in reference to this chart?
Scuby04STi is offline   Reply With Quote
Old 06-04-2019, 04:33 PM   #2849
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
It was a drag race, so lots of WOT.
Low launch control, and WOT through 5th gear (hit the rev limiter in 4th and missed 5th gear).
Old 06-04-2019, 05:29 PM   #2850
Scuby04STi
Member#: 328635
2004 STi GTX3076R
Rally Blue
But was it actually at 100% on the tps? I know most people have a hard time actually keeping the right foot pegged to the floor even on a drag race the whole time (shifting to be specific) I think its a mental thing. If there was any slight lift that would be something to try and avoid if your goal is to keep the car in boost the whole run.
