Welcome to the North American Subaru Impreza Owners Club Monday January 20, 2020
Old 02-03-2014, 05:58 PM   #26
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Anyone in this thread installed a set of these yet? If so, what are you gapping the rings at. I just bought a set and gapped the rings using their sheet (Medium boost 15-30lb = .022-.024") and have not installed the pistons yet.
I question this because they are Total Seal rings that come with them and Total Seal's website for the same application (Medium boost 15-30lb) is Bore x .007" which brings it to .027".
yamahaSHO is offline   Reply With Quote
Old 02-03-2014, 09:52 PM   #27
boostkreeep
Member#: 209880
2006 STI
white
I have installed them I gapped mine to .024 per the instruction for the top two rings. I havent had any problems
boostkreeep is offline   Reply With Quote
Old 02-03-2014, 10:09 PM   #28
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I have mine gapped at .022" per the instructions. I cross-referenced Total Seal's page and by their math, they say it should be .027". Just curious. If it's working, it's working.
Old 02-03-2014, 10:18 PM   #29
boostkreeep
Member#: 209880
2006 STI
white
Yeah I would say its working, have about 3700 miles on the motor no oil consumption that I notice. Just got off the dyno this weekend and made 400 whp.
Old 02-03-2014, 10:22 PM   #30
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Nice, what turbo? I just posted my pre-forged piston motor in the "power bragging" section. I am going to try to keep the power where it currently is.
Old 02-04-2014, 10:40 AM   #31
daslog
Member#: 314410
2004 WRX
Does anyone know why ring gap is set by boost levels? I've never heard of that before and I'm very curious about the engineering behind it.
daslog is offline   Reply With Quote
Old 02-04-2014, 11:20 AM   #32
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
They are probably assuming the more boost you run, the more power/heat you will create. More heat will bring those rind ends closer together.
Old 02-04-2014, 11:53 AM   #33
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
anyone measure PTW clearance with these?
Old 02-04-2014, 12:03 PM   #34
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I would if I had the tools to measure it, but all I have are some digital calipers that likely aren't long enough to get around the piston far enough to measure the barrel.
Old 02-04-2014, 12:31 PM   #35
Paul
Member#: 56203
00 RSTI Coupe
you'd need a 3-4in mic and a decent bore gauge to check. I know they are made to be dropped into new blocks but I would still check just incase
Old 02-04-2014, 12:54 PM   #36
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I know what is needed to measure properly, however, I bought these so that I wouldn't need to do some of the additional work. After seeing how dirty the OEM block is put together from the factory, I don't think I'm making anything worse without measuring.
Old 02-04-2014, 12:58 PM   #37
smoky
Member#: 221439
2004 STI
Ship me a set and and a block and I'll measure them
smoky is offline   Reply With Quote
Old 02-04-2014, 01:00 PM   #38
smoky
Member#: 221439
2004 STI
One thing to consider is that by dropping them in, you get the same result as a block that is bore without torque plate. Many people get good result without torque plate, not trying to restart the debate in the thread.
Old 02-04-2014, 01:00 PM   #39
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Sure, just pay for shipping. Factor in customs... $3500.
Old 02-04-2014, 01:10 PM   #40
gamebred1
Member#: 379450
This might be a good option for me. I just got my brand new case BB/BB. I had planned to bring it down to the machine shop to have it measured but bad weather/work got in the way of that. I was gonna have either JE make custom pistons to bore, or the other way around. This has me interested though. Just received the Manley "H-tuff" rods yesterday. Thanks for posting, I'll be following this thread.
gamebred1 is offline   Reply With Quote
Old 02-04-2014, 01:30 PM   #41
daslog
Member#: 314410
2004 WRX
I'm doing a Hybrid build with these right now with a new Shortblock all B sized. I'll let you know how it goes
Old 02-04-2014, 02:39 PM   #42
gamebred1
Member#: 379450
^^ Thanks. I look forward to the results. Good luck.
Old 02-04-2014, 05:19 PM   #43
reid-o
Member#: 103631
2004 STI
Gray
Crystals data suggests that it depends on the clamping force of the fasteners more distortion with more clamping force. I think it was negligible with stock fasteners and stock torque values.
reid-o is offline   Reply With Quote
Old 02-04-2014, 06:56 PM   #44
nomoreshanks
Member#: 369799
2010 997 Turbo
Carrera White
I too am doing a build with these. New STi SB, BBBB. I have mics and a bore gauge so Ill take some measurements.
nomoreshanks is offline   Reply With Quote
Old 02-04-2014, 07:06 PM   #45
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Everyone seems to be getting BBBB's. My buddy just put in a new block after spinning a bearing and got BBBB, which is what I was hoping for. I got ABAB.
Old 02-16-2014, 09:03 PM   #46
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Working on my motor with these pistons right now. They look like they'll be noisy at startup. The forged pistons I put in my SHO fit much tighter.
I currently just have two pistons installed. Got someone coming over to help me position the block off the stand to take off the access covers for the rear pistons.
Checking the ring gap after some grinding and filing.
Using Total Seal Quick Seat for the walls/rings. It's a powder you rub in after cleaning the walls and putting a thin coat of WD-40 on. It will also turn black if the walls are not completely clean; green if clean (hard to see in the pic).
Old 02-16-2014, 09:51 PM   #47
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Wow great pictures man. I've never seen pictures taken on how to measure ring gap. Often wondered but never knew exactly how to do it.
So, thanks!
What do you have to get repositioned? Don't have a table you can set it on?
Layvon is online now   Reply With Quote
Old 02-16-2014, 10:19 PM   #48
ALOKIN
Member#: 348177
2002 Bugeye
Haltech GTX3584RS
Any idea what your PTW is?
ALOKIN is offline   Reply With Quote
Old 02-16-2014, 10:24 PM   #49
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Someone said it a few posts back.
Edit. . . Didn't read your post for comprehension. They were aiming for this:
Originally Posted by Crystal_Imprezav View Post
They are 2618. I haven't handled a set in person but I am sure they are aimed at a .003-.0035 PTW based on the corresponding sizes.
Old 02-16-2014, 10:42 PM   #50
ALOKIN
Member#: 348177
2002 Bugeye
Haltech GTX3584RS
I know.
I was wondering if he measured his....
