Welcome to the North American Subaru Impreza Owners Club Tuesday January 21, 2020
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 04-02-2015, 11:39 AM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default 2015 WRX and Forester XT DUAL OIL SENDER ADAPTER
The Killer B Motorsport Dual Oil Sender Adapter is a great addition to our growing line of Oil Sender Adapter Products.
This particular product was designed for the NEW 2015 WRX and 2014-2015 Forester XT models that use the latest FA20 engine.
Product Features:
- Allows the use of TWO Pressure Sensors in ONE Location
- Easy Access on the front of the engine
- One Male port and Two Female ports
- 1/8 PT threads to work with most popular Oil Pressure Senders.
- Solid Billet 300 series Stainless Steel for Corrosion Free and Forever Reliability
- Made in the U.S.A.
These are available as of today. MSRP is $34.83
Send us a PM if you'd like to place an order or have questions.
Thanks!
Here's a few of them just hanging out...
Installed awaiting SMY Performance Dual Gauge Bezel and Oil Pressure Gauge!
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is offline   Reply With Quote
Old 04-02-2015, 12:31 PM   #2
Boggie1688
Member Sales Rating: (5)
Member#: 165955
2015 WRX Base
AWWW SHIIIEEEEEEET.
I've been waiting for MONTHS!!! BEGGING n BEGGING n BEGGING....FINALLY
Thank you thank you thank you thank you thank you.
A company that understands what my heart desires.
Boggie1688 is offline   Reply With Quote
Old 04-02-2015, 03:57 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
You welcome!!!
__________________
vs.
Old 04-02-2015, 10:20 PM   #4
wlctl
Member#: 94623
2015 Wrx Limited
GBP
Can I get a idea on what this item is for? thanks
wlctl is offline   Reply With Quote
Old 04-03-2015, 07:12 AM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sure. On the new FA20 engines there are no extra oil passage ports on the top of the engine, for installing an oil pressure sender, like on the EJ engines. There is however one single port on the front of the engine that is used with an OEM pressure sender. So our adapter allows the use of two pressure senders (OEM and an aftermarket, for oil pressure gauge) into the single port.
__________________
vs.
Old 04-03-2015, 09:50 AM   #6
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Bump!
__________________
vs.
Old 04-03-2015, 12:20 PM   #7
joker_man
Member#: 317461
'15 WRX Limited
ISM
The FA20 has a stock oil pressure sender? For what? I wish you could see the oil pressure on the triple meter, but it's not available.
joker_man is offline   Reply With Quote
Old 04-03-2015, 01:40 PM   #8
Boggie1688
Member#: 165955
2015 WRX Base
Probably the check light.
Old 04-03-2015, 10:38 PM   #9
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yes, it has an oil pressure light, just like the older EJs. Lets you know when the engine has blown
__________________
vs.
Old 05-16-2015, 12:27 AM   #10
Boggie1688
Member#: 165955
2015 WRX Base
Nvm Figured it out.
FYI deep socket 24mm to remove the stock sender.
Old 05-18-2015, 09:54 AM   #11
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Good call
__________________
vs.
Old 05-18-2015, 12:04 PM   #12
Boggie1688
Member#: 165955
2015 WRX Base
Everything is in and I'm very happy with the piece. Quality!!!
Thanks again KB!!
BTW what sealant did you guys apply on the piece from factory?
Old 05-18-2015, 12:55 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ No problem!
If I remember correctly we used the black ThreeBond on the OEM sensor.
__________________
vs.
Old 06-01-2015, 03:13 PM   #14
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
UPDATE...
Finally got around to installing our SMY Dual Gauge pod. For anyone considering adding additional gauges I highly recommend this product. OEM fit and finish and very functional.
And here is the little gem that makes it possible to retain the OEM oil pressure sensor and add an oil pressure gauge into the same port.
__________________
vs.
Old 06-01-2015, 09:44 PM   #15
WeAreThe416
Member#: 389122
2015 WRX Sport
World Rally Blue
What's the other gauge you put in and what gauge manufacturer are you using?
WeAreThe416 is offline   Reply With Quote
Old 06-02-2015, 08:38 AM   #16
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The two gauges are Oil Temp and Oil Pressure. They are STRi Gauges. We've been using STRi gauges since ~2007 I believe, and use them in all of our shop cars. I like them because they match the OEM lighting very well and don't have a big logo on them. They also have settable warning lights and highest value recall. The accuracy is probably not as good as the higher end gauges, but if you need more accurate that that you should probably be running a calibrated mechanical gauge or dedicated datalogging.
__________________
vs.
Old 09-16-2015, 12:19 PM   #17
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Just an FYI for those that may be interested...
We installed a sump oil temperature gauge and compared it to the OEM oil temp gauge on the factory display. When the engine is cold and getting up to temperature, there is ~20 temperature lag. Likely due to the oil being cooled somewhat as it's draining back into the pan, before the engine, in its entirety, is fully and completely up to temperature. After ~15 minutes of additional driving the entire engine and oil temps reach thermal equilibrium, and read the same.
__________________
vs.
Old 09-16-2015, 12:41 PM   #18
Boggie1688
Member#: 165955
2015 WRX Base
Wait KB...
Please clarify, where is the lag?
Is your aftermarket sump temp lagging with regards to the OEM temp? Or is the OEM temp lagging with regards to the aftermarket temp?
I always wait til 185F on the factory display, but your making me worried.
Old 09-16-2015, 01:27 PM   #19
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
The sump lags OEM. For example if the OEM reads 200, what's in the sump (going into the engine) is 180.
At 185 you could go wither way. I wouldn't loose sleep over it.
__________________
vs.
Old 09-16-2015, 07:55 PM   #20
shadow_772
Member#: 287701
2015 WRX
PMing you with a quick question!
shadow_772 is offline   Reply With Quote
Old 04-17-2016, 03:26 AM   #21
clark4131
Member#: 432452
2016 WRX MT Premium
Sorry for the dead thread resurrection, but I'm about to install an oil pressure gauge, and I'm curious if I need an adapter to install the OEM sender into the Killer B dual adapter? The male threads on the Killer B piece that go into the port on the engine are different than the dual female threads. So, it stands to reason the OEM sender unit will require an adapter, correct? The pics in this thread however, seem to show the OEM send mounted directly without an additional adapter. The sender for my gauge definitely requires an adapter, as it does not have tapered threads. Any clarification would be much appreciated!...SC
clark4131 is offline   Reply With Quote
Old 04-17-2016, 10:21 PM   #22
WeAreThe416
Member#: 389122
2015 WRX Sport
World Rally Blue
You do not need an adapter for the OEM sender. The dual female threads are 1/8 BSPT (sometimes stated as just PT) which is the same as in the block. I know this because I ran into an issue with a 1/8 NPT male end on a third party sender and had to buy an adapter to make that work.
Old 04-18-2016, 07:20 AM   #23
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
^ Correct!
All treads on our Dual Adapter are 1/8PT. Formally called 1/8BSPT
__________________
vs.
Old 11-07-2017, 07:25 PM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Can be used on any FA engine and we've even had a few brave souls test them out on the EJ engines running an aftermarket sensor with the OEM dummy light.
__________________
vs.
Old 11-16-2019, 11:02 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Forgot to mention, BRZ fitment as well.
__________________
vs.
