Welcome to the North American Subaru Impreza Owners Club Monday January 27, 2020
North West Impreza Club
Go Back   NASIOC > NASIOC Chapters > North West Impreza Club Forum -- NWIC
Old 09-07-2019, 08:24 PM   #1
monSTIr
Member#: 420698
2011 STI
Default Air pump switching Valve 2 (LH) stuck closed
Seems to be a common problem. Has anybody done the delete themselves or can recommend a shop that will do it? Dealer is trying gouge, obviously.
monSTIr is offline   Reply With Quote
Old 09-07-2019, 08:25 PM   #2
monSTIr
Member#: 420698
2011 STI
Edit: Iím in Snohomish county
Old 09-15-2019, 02:28 PM   #3
snwbrder206
Member#: 9817
1995 ImprezaJDM EJ20
2007 Forester XT CGM
Default InFront
Had it done on our 07 FXT a few years back by InFront Automotive in Auburn (I realize not ideal location for being north). They had it done quickly and as we have an Accessport able to clear the code.
You Could reach out to Drive Autosports as they are in Woodinville and I hear good things. Canít confirm they offer this service though.
snwbrder206 is offline   Reply With Quote
Old 10-01-2019, 09:00 PM   #4
SkylaneRG
Member#: 461781
2012 WRX Hatch
Iím in the midst of deleting it on my Ď12 WRX.
Easy to pull the pump and kill the codes. If you want to delete all the tubing and other bits, it gets progressively harder. The hardest on mine will be the passenger side tube as itís behind the upipe with limited access.
For now, I just pulled the pump and covered the tube. No problems thus far.
Iíll second the plug for Drive Autosports in woodinville. Theyíve been awesome to work with.
Theyíll be doing my flex fuel tune, so I put a deposit down and they helped kill the codes within 2 hours of calling.
SkylaneRG is offline   Reply With Quote
Old 11-14-2019, 10:22 PM   #5
Paulsforester
Member#: 508334
Default partswap
Hi
Would you know if a 98 impreza window motor fits a forester of the same year?
Paulsforester is offline   Reply With Quote
Old 12-08-2019, 03:59 AM   #6
supermarkus
Member#: 6971
2008 WRX STi
SSM
Default Another plug for Drive
I had Drive in Everett delete my whole secondary air injection system and kill the CELs with my Accessport. They even updated the maps to get rid of the extra fuel dump that happens when the SAI system is supposed to be active during startup. No sense dumping extra fuel on the cats when the air injection isn't there. They have been great to work with. They're my go-to shop for anything I can't do myself or that needs a lift.
supermarkus is offline   Reply With Quote
