Welcome to the North American Subaru Impreza Owners Club Wednesday January 22, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 11-24-2019, 05:32 PM   #1
dogsfoot68
Member#: 497351
Default high vacuum when oil cap removed
I have noticed that when I remove the oil cap when at idle that there seems to be a lot of vacuum and the revs drop quite a bit. I also have a catch can on the PCV with a dip stick, same thing when I remove the dip stick there is a lot of vacuum and engine drops revs.
Is this normal behavior or is there something going on.
car seems to run fine but does have a surging feel when pushing it.
Mods are, TGV, EGR deletes, EBSC, charge pipe.
Also have occasional blue smoke at start up, could this be due to the high vacuum and turbo seal
dogsfoot68 is offline   Reply With Quote
Old 11-25-2019, 09:24 AM   #2
dpetro1
Member#: 487500
2018 WRX
My guess is that the pcv is pulling vacuum on the crankcase so by opening the oil cap you have effectively created a leak?
I don't think you have a problem.
Side note: why would you remove the oil cap with the car running?
dpetro1 is offline   Reply With Quote
Old 11-25-2019, 10:13 AM   #3
scubaboo
Member#: 464859
I had those exact symptoms, plus increased oil consumption, in another car. The PCV valve was clogged and had to be replaced.
scubaboo is offline   Reply With Quote
Old 11-26-2019, 06:14 PM   #4
dogsfoot68
Member#: 497351
why wouldn`t you ? To check the health of the engine i guess....
Old 12-03-2019, 03:01 PM   #5
3eyesraver
Member#: 504042
2018 WRX
ISM
Isn't it the car a closed pressurized loop while running? My dad told me not to open the oil cap when the car is still hot.
3eyesraver is online now   Reply With Quote
Old 12-03-2019, 07:02 PM   #6
dpetro1
Member#: 487500
2018 WRX
The crankcase (oil fill) is not pressurized with oil so you can open it while running/hot.
Radiator cap is a different story though...
