Welcome to the North American Subaru Impreza Owners Club Monday January 20, 2020
Old 11-18-2019, 05:42 AM   #1
subi-T
Member#: 348082
2006 impreza
SGM
Default 06 WRX Misfire help
Hello, I have a 2006 WRX and I am having issues with a misfire on cylinder 4 only. But the thing is, it only misfires while the vehicle is Neutral only. When I pop it in first while idling it stops misfiring, I have a video that shows Roughness cylinder 4 on the access port.
I also just changed the seals on my fuel injector and changed my plugs and gapped them according to my tuners specifications which is 25 thousands of an inch.
Mods are:
Flex fuel Kit
BPT 18GXT turbo
Typhoon K&N intake
NGK Step colder plugs
invidia TBE
COBB EBCS
Silicon turbo inlet tube
Samco Intercooler hoses
Big TMIC
Grimmspeed Splitter
COBB V3 AP
Turbo XS BOV
Mishimoto Rad and Fans
Also, a cam seal just went out as well and Ill be tell that this weekend.
subi-T is offline   Reply With Quote
Old 11-21-2019, 02:38 PM   #2
StarkWRX
Member#: 473969
2006 WRX
World Rally Blue
First, read this post https://forums.nasioc.com/forums/sho...d.php?t=844298
Second, if you are using iridium plugs they are very delicate and not easy to gap since you can break the iridium tip off very easily.
Next, if your CEL isn’t flashing like crazy, everything is normal. It seems some “roughness” at idle is perfectly normal.
You could try flashing another map and seeing if it experiences the same behavior.
StarkWRX is offline   Reply With Quote
Old 11-29-2019, 08:35 PM   #3
subi-T
Member#: 348082
2006 impreza
SGM
I just a did a compression test on cylinder 1 and 3.. Im going to do the other side tomorrow afternoon.
Car is a 2006 Subaru Impreza WRX
Are these normal numbers?
Old 11-30-2019, 12:21 AM   #4
Zmanwrx23
Member#: 438620
2006 WRX Sedan
CGM
did you test on a warm or cold engine?
Zmanwrx23 is offline   Reply With Quote
Old 11-30-2019, 04:06 AM   #5
subi-T
Member#: 348082
2006 impreza
SGM
It was warm, I let it cool for about 20 mins. The valve covers were still hot. Gonna just do a leak down test. Im hoping it may be the valves leaking 🤞
Old 12-02-2019, 10:20 AM   #6
StarkWRX
Member#: 473969
2006 WRX
World Rally Blue
My last compression test showed 145-150 psi with a warm-ish engine and 10-30% leak down which is coming from the oil pan (oil filler tube). At 140k miles I’m not surprised the rings are worn and especially since it overheated when my OEM piece-o-s*** radiator cracked.
Your compression seems really low and you might have valves that aren’t sealing.
Old 12-02-2019, 10:26 AM   #7
MBP03
Member#: 466101
2003 WRX
MBP
I see youre using a Harbor Freight compression tester. Those things are junk. I used one on my 03 WRX and was seeing 80-90psi on all cylinders. Switched to a better compression tester and saw ~160psi on all cylinders. I love Harbor Freight, but this is one of their tools I would avoid.
MBP03 is offline   Reply With Quote
Old 12-02-2019, 04:35 PM   #8
subi-T
Member#: 348082
2006 impreza
SGM
Originally Posted by StarkWRX View Post
My last compression test showed 145-150 psi with a warm-ish engine and 10-30% leak down which is coming from the oil pan (oil filler tube). At 140k miles Im not surprised the rings are worn and especially since it overheated when my OEM piece-o-s*** radiator cracked.
Your compression seems really low and you might have valves that arent sealing.
Thanks man, I hope you got your baby running like normal again.
Im hoping its the valves but I know Im going g to need a built block soon.
Old 12-02-2019, 04:36 PM   #9
subi-T
Member#: 348082
2006 impreza
SGM
Yeah I was thinking the same. The harbor freight stuff does suck and I read the reviews on HF site and they said it was junk. I ordered a new leak tester and Autozone has the compression test as a loaner tool.
Old 12-09-2019, 09:19 PM   #10
StarkWRX
Member#: 473969
2006 WRX
World Rally Blue
My compression tester is a Craftsman, before they went out of business.
Those HF tools are hit or miss, but I would never buy a precision instrument from them.
Get a reliable one, otherwise its pretty much like not measuring at all.
