Welcome to the North American Subaru Impreza Owners Club Saturday January 25, 2020
Old 08-14-2003, 02:22 AM   #1
BADWRX
Member#: 3792
2002 6MT almost GDB
Default How difficult to change from jdm 6th gear ratio to JDM?
I have a JDM Sure-Trac. My 6th gear is just too low for my likeing. I would like to run the USDM 6th gear.
What would this encompass. I would imagine that it is the drive and driven gears that need to be swapped? Niether of these are part of the shafts are they? Would I be able to swap the 2 gears only?
I really want to have a highway gear. I like the rest of the gears, but I want a higher 6th for fuel economy and engine life.
Thanks, I appreciate the help,
Andy
BADWRX is offline   Reply With Quote
Old 08-14-2003, 09:41 PM   #2
raazin
Member#: 22918
2002 wrx wagon
sedona red
i have the same problem iwant more of a top end. at 65mph 3krpm and i hate that and at 135mph in 6gear i am all most at redline cheers
raazin is offline   Reply With Quote
Old 08-15-2003, 09:13 PM   #3
BADWRX
Member#: 3792
2002 6MT almost GDB
I have the manual, and it would only require 4 parts. 5th and 6th drive, and 5th and 6th driven. it is actually only 3 parts because on either the drive or driven side, 5th & 6th are actually on the same piece.
Labor is now my only concern. For one, you have to find a mechanich good enough to do the work properly. I don't trust too many people working on my FIVE THOUSAND DOLLAR TRANSMISSION!!!
If you know what I am saying.
Any more advice?
Thanks,
Andy
Old 08-16-2003, 12:02 PM   #4
scuzzy
Member#: 29214
05 WRX Wag (Work)
91 Legacy Wag (Play)
this is why you make mechanics sign contracts before you allow
them to work on your car.
the contract must state that the transmission and car is in
perfect working condition, minus whatever isn't in working
condition; also that the mechanic agrees to replace or refund
any money or parts that become damaged and/or missing as a result of working on said transmission; that you only allow said
mechanic to preform said work (replacing 6th gear and associated
required shafts) with new parts, any extra work preformed is
considered free regardless of cause. also that the mechanic
must provide a reasonable turn-around time for the car.
look, find a lawyer to draft you up a contract, take your car to
mechanic shops and have the owner of the shop and the
mechanic who will be working on your car SIGN IT. the contract
needs to state that if multiple mechanics work on your car,
then anything that is damaged/missing would be a liability of
the shop or owner of the shop.
anytime you take your car to a shop to have work done, play it
smart, make them sign a contract. it's the best way to keep from
getting screwed. if they don't want to sign a piece of paper that
protects you, what makes you think they give a **** about you or
your car to begin with?
I've seen people been screwed out of tens of thousands of dollars
and had **** stolen off their car because they didn't protect
themselves in court
get an estimate, and put it on the contract that there should be
no more than a 15% variation in the estimate price on the bill
of sale, put the estimate value on the contract.
for work like this, if they estimate $1500 for the entire job $1800
should be the most they can jack the price up to.
I was quoted $125 for a new water pump and labor on my 94
ford taurus; it blew. what did the bill come out to? $179, he
replaced the pump, pump outlet hose and serpentine belt and
charged me a ****load extra.
protect yourself, if one shop won't sign the contract, another will.
if it's a valid contract and has been notarized, you can **** them
over in court if they try to **** you over in the shop.
scuzzy is offline   Reply With Quote
Old 08-16-2003, 12:46 PM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
http://www.spdusa.com/sti_gearbox.htm
well mike says its "simple" but then again hes been said to bealbe to drop a motor in less then an hour...
Changing over all WRX gear ratio? makofoto Transmission (AT/MT) & Driveline 12 09-14-2015 04:12 AM
Final Drive ratio & 6th gear ratio? scuzzy Transmission (AT/MT) & Driveline 1 11-09-2013 11:54 AM
how to change from MAF to MAP? STi-Spec C Normally Aspirated Powertrain 11 05-27-2005 01:24 PM
6th gear UTEC to ECU transition knock ... Need Help WRX-Blue-Mica Engine Management & Tuning 7 12-21-2004 11:25 AM
How difficult would it be to change all the dash/radio bulbs to a blue color? Jasno999 Interior & Exterior Modification 61 06-12-2002 07:45 PM
