Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 05-31-2010, 02:59 AM   #1
nyr13sti
Member Sales Rating: (4)
Member#: 151198
2005 STi
Exclamation Turbo XS UTEC w/ stock ECU Flashed
I have for sale a Turbo XS UTEC with stock ECU flashed...Was in car for only about 6 months...I have more information and pictures for serious buyers, condition is basically brand new...Asking $750 or B/O...Also open to trade depending on what you have, looking for a carbon fiber trunk, PERRIN inter-cooler pipes (black)...
Information on the UTEC...
# PLUG & PLAY: Installs in minutes on top of the factory computer using all the factory connections.
# Drag racing launch control (secondary rev limit used during launch).
# 5 MAP MEMORY: 5 maps can be stored at a time, and using the remote map selector, you can quickly switch into valet mode, stock mode, nitrous, or race fuel maps with the click of a switch.
# ON-BOARD DATA LOGGING: Displays all necessary data required for tuning, including wideband AFR when used in conjunction with the Turbo XS Tuner.
# CLOSED LOOP BOOST CONTROL: Programmable via throttle Position and RPM. No more re-adjusting the boost controller due to changes in temperature or altitude. Keeps boost low while in closed loop fuel mode for reliability.
# KNOCK CONTROL: Automatically retards timing when the knock is detected safeguarding against engine damage. Adjustable knock threshold, timing correction, and duration.
# FUEL, TIMING, AND BOOST ARE USER-PROGRAMMABLE: in 250rpm increments up to 9000rpm over 10 load sites.
# BUILT-IN PROGRAMMABLE SOLENOID CONTROLLER: Control nitrous, water injection, intercooler water spray or any other solenoid device.
# PRE-PROGRAMMED BASE MAPS: Standardized maps are available for common setups (i.e. turboback exhaust, upgraded intercooler, bigger turbo & injectors, etc.) Maps can be uploaded and downloaded easily.
# FUEL CONTROL: Controlled via MAF sensor signal offset, tune stock and larger than stock injectors; pre-set injector correction (just type in the size!).
Nick Cukier
[email protected]
Monster Race Team
Last edited by nyr13sti; 06-02-2010 at 02:47 AM. Reason: Included price and more info on UTEC...
nyr13sti is offline   Reply With Quote
FS : Turbo XS UTEC w/ stock ECU Flashed nyr13sti Engine/Power/Exhaust 0 06-05-2010 03:56 AM
FS/FT : Turbo XS UTEC w/ stock ECU Flashed nyr13sti Engine/Power/Exhaust 0 06-04-2010 12:20 AM
FS: NJ: Turbo XS Utec piggy-back ECU pistolpen31 Engine/Power/Exhaust 4 01-26-2010 11:49 PM
FS: Turbo XS Utec piggy-back ECU pistolpen31 Tri-State Area Private Classifieds 1 01-10-2010 09:29 PM
FS: 02 WRX ECU W/Turbo XS UTEC + Other Stock and Aftermarket Parts SlammedREX Engine/Power/Exhaust 13 04-07-2009 11:24 AM
