11-30-2016, 03:18 PM | #27976 |
Member#: 407850
W. Canada
Vehicle:2014 Impreza 2.0i Quartz Blue Pearl |
I think you'd be fine tightening the upper portion as tight as you can with a wrench, the lower side I torqued mine but cannot remember what the torque spec was.
11-30-2016, 03:18 PM | #27977 |
Member#: 89967
NESIC
Vehicle:2020 Volvo S60 Gray |
Those who are knowledgeable, would there be any issues to running winter tires that are 225/60-16 on our cars? seems like they might be a little too big for our cars but I have no clue
11-30-2016, 03:29 PM | #27978 |
Member#: 421858
Vehicle:2012 Impreza |
225 is wayyyyy too wide for a 3000 pound car in snow. You want to dig in, not float on top of the snow.
11-30-2016, 04:04 PM | #27979 |
Member#: 89967
NESIC
11-30-2016, 04:08 PM | #27980 |
Member#: 407850
W. Canada
I'm running 205 60 16's for winters, sorry not sure if the additional width & height would work.
11-30-2016, 04:09 PM | #27981 |
Member#: 431290
NWIC
Vehicle:2013 impreza silver |
Starting my car part out.. anyone want some rallisport v2.5 headers? Anything else I have
11-30-2016, 04:20 PM | #27982 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
I just tightened mine down as much as I could when the car was up on jack stands, using a hand wrench/sockets. I can't get that much leverage which is why.
11-30-2016, 04:25 PM | #27983 | |
Member#: 301179
BAIC
http://www.willtheyfit.com/index.php...t2=48#isPage=1 http://forums.nasioc.com/forums/show...01&postcount=3 |
11-30-2016, 07:28 PM | #27984 |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
11-30-2016, 11:13 PM | #27985 |
Member#: 373741
TXIC
Vehicle:2013 Impreza Hatch ISM |
12-01-2016, 08:17 PM | #27986 |
Member#: 428886
E. Canada
Vehicle:2015 Impreza CBS |
Hey guys, have a 2015 impreza sport Canadian version and I recently had my drivers side mirror smashed to bits by an awesome cyclist that was texting and pedaling. I checked it out on Amazon and surprisingly enough they have the mirrors in stock both heated and non heated versions, none heated is actually more expensive for some reason. Anyone know if the heated version is plug and play?
12-01-2016, 09:02 PM | #27987 |
Member#: 421858
It is not.
12-02-2016, 08:43 AM | #27988 |
Member#: 421858
How far do peoples' parking brakes pull up before they're pretty much at maximum pressure? In a Crosstrek limited I rode in once, the hand brake only goes up maybe 4 inches, like 1/3 of the way to 90º. Mine goes maybe 1/2 the way (doesn't sound like much but the tip of the handle is like twice as high)
12-02-2016, 08:49 AM | #27989 |
Member#: 425248
Vehicle:2015 Impreza Prem 4d Dark Grey Metallic |
I'd say about 45 degrees on mine as well.
12-02-2016, 09:23 AM | #27990 | |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
12-02-2016, 09:36 AM | #27991 |
Member#: 310435
Vehicle:'12 Sport Limited Black - 255,685 miles |
Network problems at work so I'm on break.
Not so much the angle or height but the normal operation of the parking brake is 7 to 8 notches. I can still push my car up to the 5th notch but the 7th one holds it tight. New brake shoes are needed if your car moves past the 8th notch. |
12-02-2016, 10:57 AM | #27992 |
Member#: 421858
Doubt new shoes are needed considering I've never used them while moving before. What I think you mean is I need to adjust them near the brakes with the star adjuster thingy.
@CLL, what kind of hill are you parking on when you say 8 notches? My brake is about half engaged at 8 notches. Enough to keep it from rolling on mostly flat ground... but I live on an extremely steep hill. |
12-02-2016, 01:17 PM | #27993 | |
Member#: 301179
BAIC
12-02-2016, 01:20 PM | #27994 | |
Member#: 301179
BAIC
12-02-2016, 01:50 PM | #27995 | |
Member#: 310435
To say the brake is half engaged after the 8th notch, how many more notches can you go? On flat ground, mine holds at 8th notch and doesn't move if I put it in Drive (back end drops). If I rev the engine to almost 1500 RPM in Drive, it starts to move. The 9th notch holds it until almost 2000 RPM before it starts to move. So on a hill, I think it will hold but I will always be in Park of course. |
12-02-2016, 01:56 PM | #27996 | |
Member#: 431290
NWIC
Mine doesn't work but because I was being the next ken block... the 30 minutes of fun was well worth the broken control arm and worn out hand brake |
12-02-2016, 02:00 PM | #27997 | |
Member#: 310435
12-02-2016, 03:58 PM | #27998 |
Member#: 407850
W. Canada
12-02-2016, 06:43 PM | #27999 |
Member#: 421858
So on the 8th click the parking brake is engaged enough to keep me from rolling around on a relatively flat parking spot (of course none of them ever are, you'll usually roll quite a bit if you let go). But the 12th/13th click are needed to hold it firmly on a really freakin steep hill
12-02-2016, 07:04 PM | #28000 |
Member#: 310435
Wow, 13! Its a firm pull just to get my 9th notch. If you have to do that everyday, your cable is going to be stretched to hell. It probably already is. Is there any way you can park across the grade w/o rolling over? (i.e East-West instead of North-South)
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
