Welcome to the North American Subaru Impreza Owners Club Wednesday December 12, 2018
Old 01-25-2012, 12:52 PM   #226
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
I wouldn't try that..lol
Old 01-25-2012, 12:56 PM   #227
HoboBob
Member#: 253560
'83 Subaru GL Wagon
Wow much cleaner then my install. +1 for neatness
HoboBob is offline   Reply With Quote
Old 01-25-2012, 02:04 PM   #228
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Originally Posted by O.C.D.
I am thinking about cracking open my Defi and swapping to white needles?!
Just have to get the nerve to ruin a high$ gauge.
This would be a very good write up haha. Do the red needles bother you that bad though?
Gregor91 is offline   Reply With Quote
Old 01-31-2012, 03:41 PM   #229
jroa82
Member#: 305426
2012 WRX
Hey guys I just finish installing my Defi racer Gauges in my '12 WRX and everything is working fine but I think that my gauges are too dim.
This is how I have my fuses connected:
1) constant 12v-fuse #3 (red cables)
2) swiched 12v-fuse#4 IG2(orange cables)
3) Ilumination-fuse #16 ILM
Do you guys have any Ideas if this is a issue or something I may have done wrong? if is an issue, do you guys have any ideas how to fix it ?
Thanks for all the help in anticipation
jroa82 is offline   Reply With Quote
Old 01-31-2012, 03:45 PM   #230
Celery GT-5
Member#: 98210
2002 WRX SRP
ah just reminded me to install that last fuse tap...lol
Old 01-31-2012, 03:59 PM   #231
jroa82
Member#: 305426
2012 WRX
LOL... I have double and triple check everything over and over and believe when I tell you I have not forgot to install a fuse tap.
Old 01-31-2012, 04:48 PM   #232
olazy
Member#: 263322
2011 WRX Limited
WRBP
were you following the step provided in this thread? i'm pretty sure you're taping the wrong switched fuse
O.C.D.
Constant 12v - Fuse # 3 - DOOR LOCK
Switched 12v - Fuse # 26 - IG2
Illumination/Dimmer - Fuse # 16 - ILLUMINATION
or you could also try
CTSPARKY (STI)
http://forums.nasioc.com/forums/show...1&postcount=80
Orange # 4
Red #24
White #14
both should yeld the same results, i believe i'm using the fuses O.C.D. suggested.
olazy is offline   Reply With Quote
Old 01-31-2012, 04:56 PM   #233
Celery GT-5
Member#: 98210
2002 WRX SRP
I've had the white wire sharing a fuse for months...lol forgot about it
just fixed it
Old 01-31-2012, 05:52 PM   #234
jroa82
Member#: 305426
2012 WRX
CTSPARKY (STI)
[url
http://forums.nasioc.com/forums/showpost.php?p=34777441&postcount=80[/url]
Orange # 4
Red #24
White #14
Thanks a lot man I just try this and its working fine thanks you so much, you rock.
Old 01-31-2012, 05:55 PM   #235
olazy
Member#: 263322
2011 WRX Limited
WRBP
NP, glad it worked.
Old 01-31-2012, 07:20 PM   #236
jroa82
Member#: 305426
2012 WRX
Originally Posted by olazy View Post
NP, glad it worked.
Actually I will take that back, its not working. Here is the thing I disconnect the White cables (Ilumination) from the Fuse tap and started working fine so I cant understand how the gauges are working fine if the White cables are not connected at all to the fuse tap.
Tomorrow I will re-wire all the cables again and replace all the fuse taps and try your sugestions, thanks a lot man I really apreciated.
Old 01-31-2012, 07:56 PM   #237
cliff_11WRX
Member#: 275586
2011 WRX Sedan
290whp 340wtq Cali 91oct
O.C.D.
CTSPARKY (STI)
Orange # 4
Red #24
White #14
I'm looking at those fuses but for the switched 12v- Fuse #26 says IG1 on the fuse box. Is that right?
cliff_11WRX is offline   Reply With Quote
Old 01-31-2012, 08:54 PM   #238
jroa82
Member#: 305426
2012 WRX
Yes, My fuse #26 is IG1 and my Fuse #4 is the IG2.
Old 02-07-2012, 10:51 PM   #239
kevosti
Member#: 269463
2012 WRX STi Sedan
If you guys are having a hard time finding a 12V switched source, use the Cigar fuse. It is also a switched 12V source with the ignition.
kevosti is offline   Reply With Quote
Old 02-24-2012, 05:28 PM   #240
cavSuba
Member#: 287746
2012 WRX Limited
OCD thanks for an awesome write up! Followed your directions and I didn't even need the instructions from DEFI.
cavSuba is offline   Reply With Quote
Old 03-02-2012, 12:08 PM   #241
foolycooly
Member#: 260545
2011 WRX Limited 4dr
I think i've read this thread like 20 times and still haven't pulled the trigger on the cluster/gauges.
What's the deal with Defi being so much more expensive? Is it more accurate? Is the color matching better? Is it manufactured with higher quality parts/longer life?
I'm just trying to wrap my head around why they would be so much more expensive than the prosport white needles.
foolycooly is offline   Reply With Quote
Old 03-02-2012, 12:23 PM   #242
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah I have a defi boost gauge and I'm still trying to wrap my head around why I didn't buy 2 prosport or rallitek gauges and an SMY cluster for close to the same price as the one defi gauge.
It is very nice though, obviously well made and very responsive. Seriously though if I get a defi oil pressure gauge and the cluster that will be something like $650-$700 in gauges and pods where as prosport with white needles would be under $350, even less with red needles
Old 03-02-2012, 12:44 PM   #243
Ziggyrama
Member#: 53665
2011 STI Stg2 w/ ELH
Focal 2way Active w/ DSP
Because you opted for quality? Prosport gauge is not even close to the quality of Defi gauge. I've owned prosports before and they're not bad exterior wise. It's the hit or miss reliability. I am currently using MadDad gauges and they're very nice. The adjustable day and night time intensity is what makes them really cool. I can match the illumination brightness to my interior setting. Defi is yet another step up from that. Your logic is flawed because you're assuming that you'd get an equivalent from pro sport that you have now from Defi and that is not true.
Ziggyrama is offline   Reply With Quote
Old 03-02-2012, 12:49 PM   #244
Celery GT-5
Member#: 98210
2002 WRX SRP
I suppose so
Old 03-02-2012, 01:28 PM   #245
foolycooly
Member#: 260545
Again...this doesn't really answer the question of why Defi is far and away superior.
Celery--when you say responsive, are you suggesting that the prosports would show some "lag" when giving readouts?
It seems to come down to a reliability/QC issue...are there instances of cheaper gauges just straight up failing?
The defi gauges look sick, but I think it's because of xluben's excellent photography. I'd like to see a nice HDR pic of the prosports both lit and unlit.
Old 03-02-2012, 01:52 PM   #246
Celery GT-5
Member#: 98210
2002 WRX SRP
I'm just saying my defi is just very responsive, just reacts to every little throttle input.
watch some videos
Old 03-15-2012, 08:55 PM   #247
O.C.D.
Member#: 19640
2003 WRX Sedan
you always get what you pay for in life, nuff said - DEFI.
O.C.D. is offline   Reply With Quote
Old 03-24-2012, 12:07 PM   #248
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 440whp 420wtq
I have this exact same setup thanks for the right up made the install way easier, what did you do with your other sensor in place of where your oil pressure is now?
freddy121389 is offline   Reply With Quote
Old 04-03-2012, 01:15 AM   #249
gdiarte02
Member#: 312630
2002 WRX Wagon
awesome write-up, thanks for the photos.
gdiarte02 is offline   Reply With Quote
Old 04-03-2012, 01:29 AM   #250
microsnook
Member#: 313952
2006 STi
SGM DOM 3xt-r
Nice write up and install! Looks really clean!
microsnook is offline   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 07:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 08:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 05:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 04:15 AM
