Welcome to the North American Subaru Impreza Owners Club Friday August 17, 2018
Old 03-05-2012, 10:57 PM   #1
HERSHEY
Member#: 148549
95 RHD GC V7 STi
04 WRX, Sold the BlackSTi
Default Congratulations HERSHEY and his Monster STi, Nasioc's Top Scoob 028
Not really sure where to start. I am a driving instructor with ADSI in Rhode Island, we teach State Police training, vehicle dynamics classes, cornering, car control classes and most importantly AutoX courses. This is about my 14th Subaru, I currently own 3 as you can see in my profile. I flew to Japan last year and bought a V7 STi and brought it back to rebuild my 95 impreza which is extremely fun too! I am not sponsored, and prefer to be that way since I like having zero stickers on the car! This sti though sticks to the ground with the wide setup. It handles as if it were on rails, it's a completely different level when you run 11.6" wide slicks all the way around! I really care about this car in particular and am very pleased with the way it looks and performs!
I couldn't have done this all without the help from my good friend John L, Joe P, my g/f, Wicked Innovation/Wicked Bodyworks (Matt, Tom, Jimmy, Jay), and of course Joshua Hanley photography.
Built Block:
EJ257 (703)
CP 100mm Pistons
Manley H-beam Rods
ACL HX and H mix Race bearings
STI 400 series Nitrided Crank
P&L Modified Oil Pump
Heads decked, "cleaned up" and pressure tested
ARP Head Studs
Balanced rotating assembly to 10k
APS turbo Inlet
Group N Motor mounts
Cosworth Air Pump Delete
Cosworth timing belt guide
Gates kevlar reinforced timing belt
A/C Delete
GMS 160 T-stat
NGK 1 step colder plugs
ACT 6 Puck sprung clutch and ACT Xtreme Pressure Plate
Being built by me and tuned by EFI Logics
STRI DSD Slim II Gauges 60mm
Oil Pressure
EGT
Oil Temp
ATI triple dash pod with CF face.
STRI Fuel Pressure Gauge
STRI Boost Gauge
HKS Limited Edition Oil cap
"Lots of" -an fittings, Pro-Lite 350 hose and hose finishers.
AEM 3.5 BAR MAP Sensor and Cobb MAP adaptor block.
Engine:
Perrin Garrett Rotated 35r
Perrin up-pipe
Tial 44mm V-band EWG
Prodrive EBCS
APS DR525
Perrin CAI
Perrin Turbo inlet
Perrin Downpipe
1000cc top feed fuel injectors
Perrin Top Feed fuel rails & -an fittings
Grimmspeed TGV Deletes with coated housings
Aeromotive FPR with -an fittings
Gimmick aluminum radiator
Gates Alt. Belt
Gimmick radiator hoses
HKS Carbon Ti
APS 50/50 BOV
Walbro 255lph Fuel Pump
Perrin crank pulley
Perrin coolant overflow tank
Crawford Type 2 AOS
Snow performance stage 2 progressive methanol kit
Perrin EL header (wrapped)
Optima Red Top Battery
Much heat shielding and wraps!!!
Beatrush forged pitch stop mount
Paranoid Fabrications Grounding kit
HKS "Limited" oil cap
Gallery Fresh (Sonoma Red) bolt kit
Transmission and Chassis:
Group N tranny mount
TIC Transmission Crossmember mounts
Cobb Front shifter bushings
TIC Rear shifter bushing
Cobb Short Shifter
WC Lathe Works 1lb sphere
Paranoid Fabrications 3 pc. front subframe
Cusco H-brace
Unabomber Sexy rear end kit
Whiteline Front strut tower brace
Whiteline Rear strut tower brace
JDM Lightweight front bumper beam
Beatrush aluminum pilot shaft bushings
Kartboy exhaust hangers
TiC Giuyngmyo Fender Cowl Braces
Suspension and Braking:
BC Racing Coilovers
Cobb F/R swaybars
Cobb F/R endlinks
DBA 5000 slotted front rotors
DBA 4000 slotted rear rotors
Ferrodo DS2500 F/R brake pads
Goodrich Stainless lines
Castrol Synthetic Brake fluid
Safety and Interior:
AutoPower Race Roll Bar with Cross and Harness Bars
Sparco "Ultra" race seats
Sparco harness bar
G-Force 5pt. harnesses
Back seat delete with custom aluminum pan
Red light mod to ALL switches and knobs (HVAC, Gauges, Window and Meth Switches, Radar Detector, Speaker switch, etc.
JDM hazzard button
AEM wideband
Labonte methflow gauge
Prodrive floormats with aluminum heel guard on driver mat
Black WRX door panels and carpet
COBB Shift Knob (flat black)
JDM CF mirror cover
Hardwired Beltronics 995 Radar
Dash painted black (S204 style)
Dual JL Audio Separator kit for the front two speakers
10" JL Sub with custom fitted box in trunk with cleats for ease of removal for autocross, etc.
Rockford Fosgate Amp with a cutoff bypass switch and connection for ipod input.
Blacked out interior (Pillars, Trim + Headliner (all painted & dyed black))
Exterior:
Seibon Rear Carbon Fiber Diffuser
CF Rear exhaust shield
CF Front Lip with DIY lip addition
Fog light cover mod for intake
Replica Symms rear wing
NRG Carbon Fiber 1pc roof vane
Tein hood dampers wrapped in Sim...CF
Carbon Fiber B-pillar covers
Lightwerkz front headlight clearing and painting
6000K HID bulbs
JDM Yellow High beams
Carbon Fiber grille and blacked out front STI badge
Custom rear LED tails
All bulbs changed to clear,red,mirrored or LED
Hella Horns Hidden (High + Low tones)
I-badge front
Black front STI badge
Nukabe rear tow hook
Cut, rolled and sealed rear fenders
Tinted (20% front windshield with a 5% sunshade 1/3 of the way down, 5% on the remaining 5 windows)
Custom full wide fender flair kit all around (painted OBP to match)
Custom Front bumper side braces
Enkei RPF1's (Black) 18x10.5 +15mm offset
Hoosier R6's 295/30/18
Shaved + Debadged rear trunk lid
Muteki closed ended lugs
[center]
Obviously lots of sliding so I went wider...
Oh man, going to get flamed for this one...
... and since I need a video, here's an old one before the wide setup on the old horrible tune:
More pics on the next page or click:
http://forums.nasioc.com/forums/show...2&postcount=66
HERSHEY is offline   Reply With Quote
Old 03-07-2012, 10:44 AM   #2
HERSHEY
Member#: 148549
95 RHD GC V7 STi
My old 07 STi...
From only a couple months ago but have changed a few things since then... aka 35R kit
Old 03-27-2012, 02:57 PM   #3
HERSHEY
Member#: 148549
95 RHD GC V7 STi
Some extra pics...
This is from the day the video below was taken:
Spent most of the remainder sitting since it blew the fmic couplers.
Old 04-01-2012, 02:01 PM   #4
HERSHEY
Member#: 148549
95 RHD GC V7 STi
Found some random pic of my first STi when it was brand new:
I made a model of my car:
Old 04-03-2012, 02:23 PM   #5
erikm
Member#: 107019
Stg2 08 STi MBP
Franz Diebold tuned!
Congrats! LOVE the all black look!
erikm is offline   Reply With Quote
Old 04-03-2012, 02:26 PM   #6
gallandof
Member#: 285698
2013 BRZ
Galaxy Blue
grats hershey!
gallandof is offline   Reply With Quote
Old 04-03-2012, 02:26 PM   #7
subiboom
Member#: 307763
2003 WRX
The stig has gone all black!
but seriously the car looks great! I'm not exactly sure how I feel about the tail lights however.
subiboom is offline   Reply With Quote
Old 04-03-2012, 02:30 PM   #8
wrxkid157
Member#: 201046
2004 WRX
Death is the only thing that comes to mind, killing everything in it's path. Sick car man and Congrats on the WIN!
wrxkid157 is offline   Reply With Quote
Old 04-03-2012, 02:31 PM   #9
mattw278
Member#: 276165
2013 BMW 328i Sport
Awesome, awesome, car! Congrats!
mattw278 is offline   Reply With Quote
Old 04-03-2012, 02:33 PM   #10
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
TiC goodie PM sent.
Old 04-03-2012, 02:43 PM   #11
The Djrik
Member#: 215707
2003 WRX STI
Super Cool, the extra wide tires and flared arches a very bruttal looking touch!
The Djrik is offline   Reply With Quote
Old 04-03-2012, 03:20 PM   #12
LeggySpecB
Member#: 212569
07 Fozzy XT LTD
Thanks for the inspiration...Guess i need to black out my Fozzy
Congrats!
LeggySpecB is offline   Reply With Quote
Old 04-03-2012, 03:21 PM   #13
RRPLGT22
Member#: 312471
2009 Legacy GT
that thing looks awsome....are the pics with the tinted windsheild legit, or photoshop?
RRPLGT22 is offline   Reply With Quote
Old 04-03-2012, 03:22 PM   #14
starlightluvsu
Member#: 238682
07 BBLGUN STI
EJ207 V9 swapped
Im not surprised you dominated all 3 rounds!! Congrats!! <3
Originally Posted by RRPLGT22 View Post
that thing looks awsome....why did you photoshop tint on the windsheild though?
LOL he didnt. Its tinted.
starlightluvsu is offline   Reply With Quote
Old 04-03-2012, 03:25 PM   #15
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
I love this car, I need some flares like that!!!
06HAWKMAN is offline   Reply With Quote
Old 04-03-2012, 03:33 PM   #16
brutnus
Member#: 257195
2004 WRX
2.1L
Love it
brutnus is offline   Reply With Quote
Old 04-03-2012, 03:41 PM   #17
iwantmyWRX
Member#: 154286
2006 CGM WRX
Dust Collector
Amazing car! Loved seeing all the Subaru's you had when I was at URI
iwantmyWRX is offline   Reply With Quote
Old 04-03-2012, 03:46 PM   #18
cmarin21
Member#: 189747
2002 Wrx PSM
VF48 EWG EJ257 Hybrid
I also love the flares on the car. Congrats
cmarin21 is offline   Reply With Quote
Old 04-03-2012, 03:52 PM   #19
1PearlyWhite1
Member#: 314976
2011 STi 4dr
those tires are MEATLY! love it! so stealth and so burly!
1PearlyWhite1 is offline   Reply With Quote
Old 04-03-2012, 03:54 PM   #20
woody06967
Member#: 110330
2004 996TT
2016 Golf R
I like everything you've done with it, and that mod list is ridiculous. Classy yet menacing.
woody06967 is offline   Reply With Quote
Old 04-03-2012, 03:57 PM   #21
Tao_Shi
Member#: 211715
2008 STI - Stage 3
Silver Metallic
Grats, man. Nicely done.
Tao_Shi is offline   Reply With Quote
Old 04-03-2012, 03:58 PM   #22
Deuce Cam
Member#: 130444
'85 AE86 GTS
It's rare to see an over fender setup as clean as that. It almost looks seamless in some of the pics.
Deuce Cam is offline   Reply With Quote
Old 04-03-2012, 04:28 PM   #23
Scholtzy
Member#: 306894
03 WRX wagon
Well done, beautiful car
Scholtzy is offline   Reply With Quote
Old 04-03-2012, 05:00 PM   #24
blazeandboost
Member#: 293386
2006 wrx
21 months blaze free
can I please ride shotgun in that thing...looks so sick
blazeandboost is offline   Reply With Quote
Old 04-03-2012, 05:02 PM   #25
cargasmic
Member#: 118538
2015 STi LE
Super cool setup, and I love the black Stig.
cargasmic is offline   Reply With Quote
Congratulations preacher#1 and his Fozz Invasion, Nasioc's Top Scoob 022 preacher#1 Member's Car Gallery 142 07-10-2018 12:33 PM
Congratulations to old_duwel and his '94 JDM STi, Nasioc's Top Scoob 015 old_duwel Member's Car Gallery 175 04-29-2013 01:02 AM
Congratulations to L-SCHLEGS and his 2008 STi, Nasioc's Top Scoob 014 L-SCHLEGS Member's Car Gallery 166 01-01-2013 09:22 AM
Stone cone killers! Nasioc's Top Scoob 028 Auto-X Poll starlightluvsu New England Impreza Club Forum -- NESIC 37 03-08-2012 06:04 PM
Congratulations to kaeo_15 and his Bugeye Royale, Nasioc's Top Scoob 021 kaeo_15 Member's Car Gallery 186 04-08-2011 01:34 PM
