Welcome to the North American Subaru Impreza Owners Club Tuesday January 15, 2019
Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum > Western Canada
Old 07-30-2006, 07:52 PM   #1
eKxR
Member#: 121567
02 WRX
Default question on AP and boost controller
Hi there im new to the forums from calgary and i was reading some posts on the COBB AP
I was wondering since it runs different boosts in different gears would a boost controller control that?
I just picked up my 02 wrx last week so i have no idea what i wanna do first
Thx
eKxR is offline   Reply With Quote
Old 07-30-2006, 09:24 PM   #2
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Now with more clunks!
Is your WRX bone-stock or was it modded by the previous owner?
Anyways, there are 2 very basic parts that are all you need to gain about 50hp. First is a downpipe. Second is engine management - a Cobb AccessPort for example. There are other EM systems but Cobb seems to be the most popular and n00b-friendly as well as very effective.
The downpipe can be had for between $200-800 depending on used/new and brand. The DP just needs to eliminate the cat directly after the turbo. With that done, you can flash a 'stage 2' map to your ECU from the AP. Bam = 50 horses, no CELs, better fuel economy, smoother power delivery. The AP should be about $650.
You don't need a BOV or an intake for WRXs. The stock BOV (actually BPV) and intake are superior the every aftermarket replacement until you get to a VERY high level of modification.
As well, if you're doing stage 2 (like most people will recommend) you should replace your uppipe with a cat-less one. You can gut the OEM cat, use an STi uppipe, or go aftermarket.
Once you go stage 2, you won't need a boost controller as your EM will control that.
Enjoy your car!
Here's a link to the best info threads on NASIOC. It might take a week, but read every topic, follow all the links, understand what's going on...You'll be waaaaay more informed when you're done! The answers to your next 10 questions are in here somewhere!
http://forums.nasioc.com/forums/showthread.php?t=533787
02WHITEDUB is offline   Reply With Quote
Old 07-31-2006, 12:59 AM   #3
eKxR
Member#: 121567
02 WRX
Thx for your reply 02dub
Yes my car is completely stock
Also another question would a aftermarket DP make the car ALOT louder or would u guys knw which one is the quietest
Old 07-31-2006, 01:14 AM   #4
02WHITEDUB
Member#: 96793
02 ProTuned TD04
Quietest would be one that has a cat in it. Some 'shorty' DPs use the OEM 3rd cat. Long DPs replace both post-turbo OEM cats with either one high-flow cat or none at all.
The other factor in DP noise would be the inlet. A cast DP inlet will mask more noises than a bent tubular construction.
Your exhaust tone and volume is 80% dependent on the axleback or 'muffler' section you choose though, not too much on UP, DP etc.
I've got a Cobb catted DP. Cast inlet + cat = quiet, especially mated to an STi catback section.
Old 08-01-2006, 04:04 AM   #5
eKxR
Member#: 121567
02 WRX
just went to speedtech today and they told me they dont carry COBB stuff. Where should I get this stuff?
a NASIOC vendor?
Old 08-01-2006, 04:34 AM   #6
Blaine B.
Member#: 113050
93 TSi AWD
White/Black
just went to speedtech today and Will told me they dont carry COBB stuff. Where should I get this stuff?
a NASIOC vendor?
I can probably help you out.
Blaine B. is offline   Reply With Quote
Stock Boost and Boost controller question benibarra23 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-15-2010 10:13 PM
AP and Boost Controller Boxer112 Engine Management & Tuning 16 01-17-2006 10:17 AM
Question about utec and boost controler Stiturbos Engine Management & Tuning 11 02-24-2005 04:55 AM
Help on UTEC and Boost Controller Azjon Newbies & FAQs 2 02-03-2004 03:04 PM
Newbie Question re: TurboXS and Boost Control.... Brian Broz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-29-2002 12:23 PM
