Welcome to the North American Subaru Impreza Owners Club Thursday January 24, 2019
Old 06-28-2006, 01:43 AM   #1
benibarra23
Member#: 90230
Default Stock Boost and Boost controller question
What is the max boost a 02 WRX should build? IM currently building 15psi and im having some problems so I plan on upgrading stuff if it needs to be fixed. My buddy has a boost controller that he wants to try out on my car but since its stock is that a bad idea? What does a boost controller do exactly besides the obvious and control boost.
benibarra23 is offline   Reply With Quote
Old 06-28-2006, 02:06 AM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
A manual boost controler controls boost... At what ever boost level you set it at. Problem is it will always allow the boost up to that level even at part throttle and the ECU doesn't know it's 15 PSi and is expecting 8 PSi so it only puts in enough fuel for 8 PSi not 15 PSi so that's not a good thing. It also doesn't lower boost at higher RPMs so that's not too good for the engine either. But anyways you "can" get away with 16 PSi if you can control your driving style...Not many people can, so they end up with major engine failures, So beware.! Edit: Oh and stock boost is only 13.5 PSi.
wrxdrvr is offline   Reply With Quote
Old 06-28-2006, 10:44 AM   #3
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
An EGT gauge with a warning light and audible alarm solves any partial throttle boost issues. if you get lazy and forget, the light and buzzer warn you.
Also you can run a MBC/EBC with a reflash. I have a Protune and run a MBC at the track. The OL/CL delay is less and it is moved down to like 15-20% TPS.
Valhakar is offline   Reply With Quote
Old 06-28-2006, 05:15 PM   #4
benibarra23
Member#: 90230
Do you guys know how much PSI the stock injectors push? And what size they are?
Old 06-28-2006, 05:57 PM   #5
23b_Rex
Member#: 79394
02 gda
wrb
on an 02.. ol/cl delay isn't an issue
on the stock turbo, untuned, 16psi is about the max you wanna push
23b_Rex is offline   Reply With Quote
Old 06-28-2006, 07:58 PM   #6
BoostAWD
Member#: 99108
2007 Impreza WRX LTD
Satin White Pearl
Would an electronic boost controller eliminate some of these issues?
BoostAWD is offline   Reply With Quote
Old 06-28-2006, 08:34 PM   #7
hondaeater69
Member#: 60324
1998 RS
15#'s on a completely stock car? What are these problems you speak of? and what kind of BC? An MBC bypasses the stock BC and may not be a good idea if you don't know what you're doing
Old 06-28-2006, 08:39 PM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I've no idea... you already have one stock. I would rather get a protune if you want to up your boost. It would be the way to go after getting some EM.
Old 06-28-2006, 09:39 PM   #9
benibarra23
Member#: 90230
Problems I am having are that im peaking at 15 and then droping down imediatly to about 13 then again peaking at 15 sometimes 16 psi.
Old 06-28-2006, 09:48 PM   #10
benibarra23
Member#: 90230
Oh yeah one more question, what kind of turbo does the 02 WRX have? Someone asked me if it was the Mitsubishi Turbo or something else and I had no clue
Old 06-28-2006, 10:53 PM   #11
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Sounds like you are over boosting and the ECU is cuting back boost but then it goes too low, So it's hunting for the proper level 13.5 PSi. When I did the 3/16 mod that is what happened to my car Something is not right with your vacume hoses, T connector , inline connector to boost control solenoid.
Old 06-29-2006, 02:32 AM   #12
Hallis
Member#: 94141
Platinum Silver Metallic
hmmm,, i think my car only makes 10-12psi at WOT. Ive ran it all the way up to 6000rpm in 3'rd and that's about as good as she gets. Car has 88k on it so maybe it's time to start replacing components and hoses.
Shane
Hallis is offline   Reply With Quote
Old 06-15-2010, 02:42 PM   #13
xSTI GUYx
Member#: 249246
2005 20G STi
wrb
i got crazy boost spike at low rpm. when i punch it, it goes to rev limiter. then when i switch gears theyll drop. if im at 2500 in 4th and i stomp it, itll go til rev limiter then ill shift to 5th when i hit fifth its at 3000. wtf? any ideas
xSTI GUYx is offline   Reply With Quote
Old 06-15-2010, 06:19 PM   #14
jondoe12
Member#: 249496
2004 Impreza Wrx
WRC blue or Rally blue
what is a manual boost controller actually doing? i know it limits the psi but how? and than a computer just sets a map so when your at x rpm's you have a set psi? and why should you have a lower rpm at redline?
jondoe12 is offline   Reply With Quote
Old 06-15-2010, 07:46 PM   #15
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
An MBC is not a "fix" for a problem and is more likely to cause other problems without a tune than anything. You need to get your car looked at by someone who knows how to diagnose properly. Then you should get the issue fixed based on the diagnosis. You won't be able to do that over the internet...
In point of fact the peak/hold boost called for in the stock ECU mapping is 13.6-13.8 psi. Keep your buddy away from your car if you want it to stay in running condition...
Also sounds like you have an IMMENSE amount of learning to do. Answers to the questions you are asking can be found in the stickies and threads of note. It is better for you to ask or take action based on the information you find there.
Unabomber is coming...
-soobaviator
soobaviator is offline   Reply With Quote
Old 06-15-2010, 09:15 PM   #16
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Wow, this thread...so full of fail. Thank you soob.
A stock 2002 comes from the factory pushing 13.5 PSI max of boost. It uses a 2 port solenoid, not really the optimal setup. The stock WRX injectors for that year are 420-440cc IIRC. As soob said, this information is ALL in the stickies.
Oh, and it's a Mitsubishi Heavy Industries TD04H-13L.
OrbitalEllipses is offline   Reply With Quote
Old 06-15-2010, 09:26 PM   #17
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
You mean -13T...
Old 06-15-2010, 09:35 PM   #18
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Yeah that.
Old 06-15-2010, 09:51 PM   #19
quazimoto
Member#: 70395
Its a TD04L-13T
quazimoto is offline   Reply With Quote
Old 06-15-2010, 09:56 PM   #20
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
You're going to fault me over one letter, when there's multiple posts of ignorant information? Woohoo NASIOC.
Old 06-15-2010, 10:04 PM   #21
soobaviator
Member#: 115070
2009 DGM LGT Spec.B
08 Audi Q7 4.2 PRM
If we are going to go straight dork about it a TD04H is a different turbine than a TD04L or TD04HL... Ain't NASIOC cool!
Old 06-15-2010, 10:13 PM   #22
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
I'm all jumbled because of the 19T upgrade thread, I swear!!
Stock snorkel and boost problems... Brady12 UTEC 4 08-01-2006 03:19 PM
Apexi boost and fuel controllers in AZ bobturismo Private 'For Sale' Classifieds 7 04-23-2004 09:15 AM
autometer boost and oil temp questions voam Electrical & Lighting 2 09-11-2003 10:52 AM
VF-29 or VF-24 on stock fuel and boost?? mrtrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-27-2002 11:52 AM
Max boost and boost valve question Xlrate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-27-2002 09:44 AM
