Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 02-03-2004, 01:16 AM   #1
Azjon
Member#: 28284
2003 Impreza WRX
Metallic Silver
Default Help on UTEC and Boost Controller
I'm buying a UTEC from a friend and he's giving me the Standard Boost Controller along with the map switch. I already bought a Dual Stage Boost Controller from TurboXS and I know how that switches the boost on the turbo because it has two manual controllers on it. He's giving me the Standard, which is a single manual boost controller, and he told me I should just go sell my dual stage because with the map switch the UTEC could change the boost on its own. The thing I need help on is that I dont see how it does that with just a single manual boost controller on it. Could someone please explain this plz? I hope this wasn't confusing.
Azjon is offline   Reply With Quote
Old 02-03-2004, 01:17 PM   #2
InfamousDX
Member#: 25413
I'm a noobie to UTEC but it can adjust your boost levels per RPM so you have full control over boost.
Old 02-03-2004, 03:04 PM   #3
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The boost controller that comes with the Utec is used in conjunction with the factory boost controller (FBC). It simply bleeds a little air from the system so that the FBC can produce more boost.
Your friend was a little deceiving/confusing (not in a mean way though). You can only have 1 boost setting per map. Mean like map 1 run 16 psi max with 13 psi at redline. Then map 2 could run 17 psi max with 15 psi at redline. It doesn't work the same way as your DSBC does. You can switch maps on the fly (with the remote map selector), but the car needs to be below 1500(ish) rpm before the map will switch. Therefore you can run a daily driver map and then also a racing map.
I would suggest reading the Utec owners manual, and this http://forums.nasioc.com/forums/show...hreadid=466979
The Utec gives you lots of tuning capabilities, but that also means you can blow your car up if your not careful.
mbiker97 is offline   Reply With Quote
STI UTEC with boost control valve, box, manual and map switch syoung0298 Engine/Power/Exhaust 3 12-08-2007 01:52 AM
question on AP and boost controller eKxR Western Canada 5 08-01-2006 04:34 AM
help for downpipe and boost controller haroman1188 Newbies & FAQs 6 04-10-2006 06:07 PM
Need your help fellas on a good boost controller... BlackSun Engine Management & Tuning 10 12-01-2005 03:22 PM
Question about utec and boost controler Stiturbos Engine Management & Tuning 11 02-24-2005 04:55 AM
