Brakes & Suspension Forum sponsored by The Tire Rack |
04-23-2015, 05:46 PM | #101 |
Member#: 408386
Vehicle:2013 WRX Silver |
04-23-2015, 05:57 PM | #102 |
Member#: 247304
South East
Vehicle:2011 STI WR Blue |
I believe stock is 19mm frt/16mm rear.
04-24-2015, 04:23 PM | #103 |
Member#: 408386
Thanks.
04-26-2015, 10:14 PM | #104 |
Member#: 413825
Vehicle:2015 base Impreza Jasmine Green Metallic |
What OEM size front sway bar on a 2015 Impreza 2.0?
I am new here at NASIOC. This 2015 Impreza base 2.0 4-dr is my first Subaru and very recently installed a 22mm rear sway bar with adjustable links, whiteline polyurethane bushings and OE clamps. Along with 225/45-17 wrapped on 17x8 ET35 wheels ... it handles well on turns like it was on rails. I was just wondering what the OE size of the front sway bar ... for posible increase in size if it is the same or smaller than 22mm. Thank you |
05-06-2015, 11:47 PM | #105 |
Member#: 299743
Vehicle:2008 WRX Gunmetal Gray |
not going to lie... seriously one of the most informative posts i have ever come across. i learned alot and hope to use this as a indicator as to what i will be buying this summer. thank you and what is your site i would like to look at it and purchase from you.
thank you, |
05-07-2015, 01:02 PM | #106 | |
Member#: 201606
Vehicle:2013 STi Hatch PBP |
Thanks very much for the kind words. Glad you found the post helpful. I sent you a PM with our info to avoid "vending" in the tech section. Not sure if the mods would care or not if I posted the link up here, but I figured I'd play it safe. If you have any questions I'll be happy to help. Thanks, Geoff |
05-28-2015, 10:30 PM | #107 | |
Member#: 422018
Vehicle:2015 impreza sexual white |
(irrelevant-but i put a KnN air filter today after putting 1400 miles on the car and it feels like someone put lube into the engine..its so smooooth) |
05-28-2015, 10:40 PM | #108 |
Member#: 247304
South East
If you want to improve handling but not over do it I'd suggest picking up a used set of swaybars from a '15 WRX here on the site (lots of people upgrade their WRX or STI so the bars a cheap and make sure you buy their bushings too). The STI is 24mm frt and 20mm rear, not sure what the WRX runs but I think the rear is 19mm. A 21 - 22mm frt bar should be fine with a 19mm rear.
05-29-2015, 08:20 AM | #109 | |
Member#: 413825
My Parts list: 1. RSB: UMUSA ($167 delivered) manufacturer part # SB SBR R WRX STI 0815 I purchased from eBay. It was advertised for use on any 2008-15 Impreza WRX STI. It comes with all the necessary hardware and bolts needed to install but I discarded the bushing and clamp that came with the set. They looked ugly and generic so I purchased #3 & #4 on the list below 2. End links ($120/pair per kit delivered): "Whiteline" adjustable sway bar endlink Manufacturer part #KLC182 3. OEM Clamps ($5ea - 2 picked up): Subaru 20466FG000 4. Bushing ($30/pair per kit delivered): Whiteline Part# WHI KSK001-22 with grease packet Watch the install video below of 24mm FSB & RSB on an STI with before and after performance comparison: https://www.youtube.com/watch?v=vBbOmDGpYWQ Last edited by NubImpreza; 05-29-2015 at 09:32 AM. |
05-29-2015, 07:52 PM | #110 | |
Member#: 422018
OMG I. ****ING. LOVE. YOU. Thanksss!!!!!!! |
05-29-2015, 09:57 PM | #111 |
Member#: 293970
VIC
Vehicle:2007 impreza wagon black |
Suspension not loaded when sway bars installed?
In the Rallysport video above I noticed that the suspension wasn't loaded when he installed the sway bars. I thought the suspension was supposed to loaded (wheels on ground supporting the full car weight) when these bars are installed? Or am I mistaken? Just wondering cuz when I installed my WRX rear bar a few years ago I had the car on jack stands with the wheels in the air. It didnt seem to make a difference/affect anything but perhaps I was mistaken.
If anybody can educate me, that would be much appreciated! |
05-29-2015, 10:11 PM | #112 | |
Member#: 413825
Here's a more detailed video of a RSB install by another Subaru expert/mechanic Subispeed: https://www.youtube.com/watch?v=sSgOTlJT7jY |
05-30-2015, 12:03 AM | #113 |
Member#: 247304
South East
It is absolutely true that if you're "free length" unloaded drop on both sides is equal to the loaded height then there isn't an issue. In my experience I've never had a car that was the same height difference on both sides when loaded. If you've dropped the height, added springs or coil overs 99% likelihood they're different.
06-03-2015, 09:48 PM | #114 |
Member#: 391084
So I currently have a 2011 wrx with cobb springs stock shocks n struts. I read through your post thoroughly and find that alot is all preference. I'm planning on swapping the suspension out for the tein basic street set up and was wondering what's your opinion for sways front rear and endlinks with the option of a track day here and there...thanks in advance
P.s. primarily will be street driven. I live in pa and roads here aren't all that great but there's alot of mountains and I like to run through em and push the limits... |
06-04-2015, 10:13 AM | #115 |
Member#: 404504
I have a 2011 Hatch STI and i wanna upgrade and improve the suspension before going for HP.
This is what i have for starters, tell me if there is any issues or better options but explain why they are better. 24mm Heavy Duty whiteline adjustable sway bar front and rear. Pair of Whiteline rear endlinks Pair of Kartboy front endlinks |
06-22-2015, 09:42 PM | #116 |
Member#: 406715
Vehicle:2013 WRX WR Blue |
Swaybars & Endlinks - Impreza/WRX/STi Version
So for me who is 90% daily driver and at the track a couple times a month... It sounds like I should go 22 mm front with 20mm back?
2013 WRX hatch |
06-23-2015, 06:22 AM | #117 |
Member#: 247304
South East
That's a nice setup and will work well.
06-27-2015, 05:36 PM | #118 |
Member#: 378358
Vehicle:2014 WRX hatch DGM |
A quick question regarding front sway bar installation on a 2014.
I installed a rear sway bar a few months ago and had absolutely no issues. However, I've finally decided to tackle the front bar and found myself struggling with six out of the ten bolts holding the cross brace in place. I've let 'em soak for a bit, but they just won't budge. Should I try a breaker bar? I'm obviously concerned about shearing one of the damn things off. Any thoughts would be appreciated. |
06-27-2015, 06:28 PM | #119 | |
Member#: 413825
I have a 2015 slow 2.0 with MT. I recently installed a 22mm RSB and I couldn't be happier ... what a difference: it's like night and day. From a scary "I'm headed for the guardrail" understeer to a little touch of confidence boosting oversteer which is perfect for my occasional spirited cornering. If I am not mistaken (from other informative member's posts) the fronts are factory 22mm. So knowing what an excellent transformation 22mm rear has already done for my slow 2.0 ... a 22mm rear would be my choice for a faster car ... just my 0.02 ... if ... I had a WRX. |
06-27-2015, 10:26 PM | #120 |
Member#: 378358
I bought both front and rear for my 2014 hatch and have, so far, only installed the 22mm rear. I love it! I still want to try out adding the front as well, but the rear alone (on stock end links) has been quite enjoyable.
06-27-2015, 11:35 PM | #121 | |
Member#: 413825
I try to follow the same path of my turns as though I was cornering with my crotch rocket ... and the 22mm RSB delivers as expected. Last edited by NubImpreza; 06-28-2015 at 08:46 AM. |
06-29-2015, 10:00 AM | #122 |
Member#: 406715
Thanks guys! Very excited
06-29-2015, 10:02 AM | #123 |
Member#: 406715
Duplicate
07-07-2015, 12:22 AM | #124 |
Member#: 424060
Vehicle:2015 WRX crystal white |
Anyone have any recommendations for sway bar an front strut bars set up on a 15 wrx I'm curious being new to the Subaru game what people like and are putting on and best set up is? I go track it maybe at most twice a year so very curious!
07-29-2015, 12:55 AM | #125 |
Member#: 426000
Hello all.. Been doin research on swaybars.. Got the 2011 wrx in Australia... Was wondering what brand and size sway bar i could run on mine while maintaining stock components .. Not tracking just daily drives.. Tryna minimise body roll without too much suspension work if thats possible.. Just want a comfy ride.. Thanks
