08-16-2008, 01:04 AM | #1 |
Member#: 118236
TXIC
Vehicle:2020 STI Series. White |
Reverse Lights Don't Work
I'm having a problem. I recently installed my Kartboy shifter in my 06 STi and noticed that after a while my reverse lights stop activating when shifting it into reverse. To activating them I have to practically push it into 6th (so I just back up without lights often).
Anyway, if anyone knows what I should do about this, please let me know.
08-16-2008, 02:10 AM | #2 |
Member#: 145069
W. Canada
Vehicle:Keep It Sleazy |
are your lights burnt out? lol
hmm thats weird maybe the throw isnt enough for the sensor to pick up that the car is engaged in reverse.... i couldnt see that though. sorry...no help from me but a free bump haha |
08-16-2008, 03:19 AM | #3 |
Member#: 186149
Vehicle:2005 STi WFC #144 OBP |
Having the same problem with my 03.
08-18-2008, 03:33 PM | #4 |
Member#: 118236
TXIC
As I stated before the lights do work at a very specific point, but it is close to when I would have to pop in in neutral that it's just not a good idea.
ANYONE know what's wrong here? |
08-19-2008, 11:49 AM | #5 |
Member#: 36215
SCIC
Vehicle:2002 impreza outback dented to hell |
well my guess is that there is a sensor in the trans that will turn your reverse lights on when you put the shifter into reverse, and somehow the design of the shifter doesn't quite match oem. i think there's probably nothing you can do about it aside from switching back to stock.
08-19-2008, 04:35 PM | #6 | |
Member#: 118236
TXIC
08-19-2008, 07:29 PM | #7 |
Member#: 43720
SCIC
Vehicle:2002 mbp WRX 97 Ford Ranger on Bags |
i had the same issue (minus the kartboy)
you need to replace the reverse light sensor... it's under the car on the tranny you should be good after that |
08-19-2008, 08:15 PM | #8 |
Member#: 118236
TXIC
Crap. What's that gonna cost me.
08-19-2008, 08:16 PM | #9 |
Member#: 133584
NWIC
Vehicle:2003 Honda S2000 |
shouldnt be too expensive
08-19-2008, 08:31 PM | #10 |
Member#: 118236
TXIC
Where'd you buy it? Dealership?
06-08-2011, 11:32 AM | #11 |
Member#: 279899
South East
Vehicle:2010 Mazda MX-5 Silver |
Holy thread resurrection Batman!
My girlfriend owns a 2005 STI and I was hoping someone could help me out. Her reverse lights have stopped working. We've checked bulbs, fuse, etc. Pretty sure its the switch, as playing with the shifter would turn the lights on. My question is, can the switch be changed without removing the transmission (6sp)? The workshop manual seems to state that the entire transmission needs to be removed just to replace the switch. If anyone has any tips or knows for sure how to replace this switch I'd appreciate it! |
06-08-2011, 12:55 PM | #12 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
Switch (purchase at any dealership) is connected to part of the wiring harness on the transmission.
You may be able to access it without completely dropping the trans, but you will likely have to at least remove the transmission crossmember. If you remove the x-member and still cannot access it then yes, you will probably have to drop the trans a bit to gain access. I swapped out my Neutral pos. switch without dropping the x-member or the transmission.... I've not yet had to swap out the back up switch so I am not 100% sure what you're options are going to be. |
06-08-2011, 05:33 PM | #13 |
Member#: 279899
South East
Thanks for the reply, I think I'll try getting under the car this weekend to see if I can reach the switch. Was hoping it would be clearly accessible, but I guess it's worth a look.
Cheers! |
11-03-2015, 10:04 PM | #14 |
Member#: 412290
South East
Vehicle:2015 WRX Limited DGM |
I am having the exact same issue after installing my Boomba short shifter adapter on my 2015 wrx!
11-09-2015, 10:26 AM | #15 |
Member#: 412290
South East
Can anyone verify that changing the switch fixed this issue?
11-09-2015, 10:08 PM | #16 |
Member#: 33850
NESIC
Vehicle:2006 WRX Wagon WRC Blue |
4 years since the last reply...
11-09-2015, 11:16 PM | #17 |
Member#: 412290
South East
Haha yeah, one can only hope though. Can't find info on this anywhere else!
02-13-2016, 01:36 AM | #18 |
Member#: 97983
BAIC
Vehicle:2017 STi Silver |
Did an engine rebuild. Have this issue. Bump city!
03-02-2016, 06:35 PM | #19 |
Member#: 412290
South East
I changed the sensor and everything appears to be working normal now!
09-26-2016, 04:08 PM | #20 |
Member#: 337778
NWIC
Vehicle:2002 WRX Wagon Silver |
02-19-2018, 04:48 PM | #21 |
Member#: 482320
Bump.
Reverse lights don't always go on... | Cliff Ditchhanger | Transmission (AT/MT) & Driveline | 7 | 05-24-2010 11:59 AM |
Reverse lights don't work | b0dh1 | Electrical & Lighting | 7 | 03-01-2009 06:49 PM |
Reverse light dont work and CEL's | Twiztidunreal | Electrical & Lighting | 1 | 08-06-2008 12:50 PM |
Reverse Lights don't work after wing theft | kickitjp | Electrical & Lighting | 1 | 11-10-2006 09:59 PM |
reverse lights don't work | nomadtw | Transmission (AT/MT) & Driveline | 4 | 09-13-2006 10:35 PM |
