Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 02-14-2018, 11:59 PM   #1
WRXdFA20
Member#: 480656
Default ‘17 Base wheel fitment
Does anyone know if the 2018 19 inch STI wheels will fit on a 2017 WRX base without any problems on stock suspension? Thanks in advance.
WRXdFA20 is offline   Reply With Quote
Old 02-15-2018, 07:25 AM   #2
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
vapore0n is offline   Reply With Quote
Old 02-15-2018, 08:26 AM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Will they fit? Of course.
Your real problem is buying the correct tires to go on those wheels so they don't rub.
BTW, you would get more answers in the Wheel & Tire section.
You should ask the Mods to move this for you
Samurai Jack is offline   Reply With Quote
Old 02-15-2018, 01:01 PM   #4
IndecisiveS12
Member#: 463349
2017 WRX Sport
World Rally Blue
why wouldn't he just get the tire size that comes on the 19" wheel equipped STIs. seems like a no brainer
IndecisiveS12 is offline   Reply With Quote
Old 02-15-2018, 05:12 PM   #5
WRXdFA20
Member#: 480656
Yes, I’m talkin about the wheels and tires that come stock on oem 19” sti wheels. Would they rub?
Old 02-15-2018, 05:19 PM   #6
Mach V Dan
Member#: 12029
Why would they rub? The bodies of those cars are identical.
The only car you CAN'T put the 2018+ STI wheels on is the pre-2018 STI. The 19" wheels don't clear the four-piston Brembo brakes. Otherwise, they'll fit any 2015+ WRX just fine.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 02-15-2018, 06:31 PM   #7
Samurai Jack
Member#: 21145
2002 Enemy of Aku
I have no idea what tires he is planning to run. He never said.
Can't answer a question fully unless correct information is fully disclosed
Old 02-19-2018, 08:43 AM   #8
Big Dustin
Member#: 272271
2018 STi Sedan
We swapped out the stock 245/35/19 tires for 255/35/19s. No rubbing at all. Even lowered on swift springs.
Big Dustin is offline   Reply With Quote
