01-28-2017, 08:31 AM | #601 |
Member#: 462055
BAIC
Vehicle:2017 WRX stage 2 |
stage 2 question
I have a question about stage 2 & cobb AP OTS stage 2:
I have a '17 WRX, with Cobb SF intake + AP (ots stage 1 tune) If I install a ETS turboback (jpipe+catback), will Cobb AP OTS Stage 2 still work without issues? Or is Cobb's turboback required to run the OTS stage 2?
01-28-2017, 12:29 PM | #602 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
Read the map notes it is very clear on what you can and cant use
https://cobbtuning.atlassian.net/wik...for+VA+WRX+6MT Yes it will work if its catted. |
02-04-2017, 02:07 AM | #603 |
Member#: 462387
New 2016 STI Owner here
Hi Everyone,
I recently purchased a pre-owned 2016 STI Lmtd. It is my first Subbie. My car prior to this was a 2008 Lexus GS 460, prior to that was a 2003 M3, and then a S2000, and a couple of Preludes. I had gotten bored of the 460 and wanted to get back to something that was "raw" and fun. So after some thinking ... along came the STI And a fact ... the interior space of the STI is similar to the GS460. The vehicle is, however, shorter. So now that I've had the car for a short while I would like to, like most other people here, make it more fun. I don't know if I want to change the Turbo and all - right now I'd incline to say no - and just stick with bolt-ons. The Cobb Stage 2 Power Package @ $2400 seems popular (+ installation fees). I called around and was suggested an alternative to the Cobb Solution which includes the AEM CAI, Cobb BCS Kit, Invidia down pipe catted, heatshield, ets catback exhaust, titanium exhaust wrap for downpipe. The alternative to the Cobb Stage 2 Power Package is about $500 more expensive and the shop claims that it should produce 20-40 more HP than the Cobb Stage 2. Anyone here with any experience that can help to suggest if this claim is likely to be true and whether the extra cost of $500 is worth it? |
02-04-2017, 05:47 PM | #604 |
Member#: 462387
Hey Everyone,
I'm deciding on my first set of bolt ons to my STI. I'm leaning to with the following :AP, AEM CAI, BCS Kit, Invidia Catted Down Pipe, and a 93 Tune. What I've removed from the list is the Catback exhaust system which saves me $$$ for now. Plus the shop said that that could be done later with future changes and for now it wouldn't offer much in terms of power gains. And is it was the most expensive thing on the list it came off and will be done in the future. Does anyone have a similar set up? Or can speak to it? I'd love to hear insights, experiences so that I know what to expect and whether its worth getting the exhaust now with the tune vs. later in the future. |
02-04-2017, 05:57 PM | #605 |
Member#: 460907
RMIC
If it's the same parts (dp, bcs, CAI) then it's really doubtful whether a different company's parts will net you greater hp or tq over another if your tuner is competent. 20-40bhp is the difference between dynos and is probably going to be unnoticeable. If he wants you to spend $500 for 40 hp (brake or wheel?) then he's probably making a profit in that somewhere down the line.
But, some tuner's don't like certain companies or products from certain companies, so find out if that plays a part. You can almost always source different manufacturer parts cheaper then buying a stage package. |
02-04-2017, 08:55 PM | #606 |
Member#: 462387
Also I came across this thread which was the same question. So sharing here Incase it helps others https://forums.nasioc.com/forums/sho....php?t=2798407
08-15-2017, 01:21 PM | #607 |
Member#: 472899
Vehicle:2005 LGT |
since I'm about to dyno tune my car, let's see how accurate we can try to be:
05' LegacyGT EJ255 5EAT 5280' elevation 91octane mishimoto TMIC catless up-pipe Cobb catted DP borla catback exhaust 195k miles stock vf40 (currently at 15.2psi), stock fuel, stock airbox and filter mustang MD-500 Dyno at Cyrotune Performance. Last edited by JazzAvi8r; 09-29-2017 at 10:28 AM. |
08-15-2017, 02:25 PM | #608 |
Member#: 178426
Vehicle:2010 S4 Gray |
Ooooo I'll bite. 240whp. When are you getting tuned?
08-17-2017, 02:14 PM | #609 |
Member#: 472899
Vehicle:2005 LGT |
08-22-2017, 04:12 PM | #610 |
Member#: 472899
Vehicle:2005 LGT |
got a gently used v2 AP, a stock STi catless UP, and ordered the grimmspeed metal gaskets. just need to find a catless DP and a wideband and I'll be ready for tuning!
09-13-2017, 04:32 PM | #611 |
Member#: 472899
Vehicle:2005 LGT |
UPDATE: I ended up buying a new Cobb catted downpipe. all else remains the same. Appointment for the Dyno is on the 28th. Going for a conservative and safe tune. just trying to smooth out the curves and make it a bit more responsive. I think 240 is a realistic goal at this point, but likely going to be closer to the 225 mark. it's all arm-chair speculation at this point, but we shall see!
09-29-2017, 10:27 AM | #612 |
Member#: 472899
Vehicle:2005 LGT |
well, the first pull was 226.7/288.4 which was just the baseline run to even start tuning.
...and then the transmission threw the dreaded P0700. so, I need to source out a 5EAT before I can take it back and really find out what I've got. |
11-13-2017, 12:34 PM | #613 |
Member#: 295970
Vehicle:2019 STI CWP |
I'm new to the forums. Not looking to get a crazy amount of power. Probably just 300 Crank, i do not want to go pro tune or dyno. Is there anyway i can minimal mods and get up to 250-3whp? I was thinking catback, AP, and J Pipe. I run 93 octane, and am not looking to change intercooler anytime soon. I would rather just do simple bolt ons.
I have a 2018 WRX, no mods currently, sitting at 600 miles. (This is for the future, not anytime soon) |
11-14-2017, 04:06 PM | #614 | |
Member#: 430019
Vehicle:2004 Sti blue |
11-14-2017, 07:43 PM | #615 |
Member#: 295970
11-15-2017, 04:11 PM | #616 |
Member#: 474796
Vehicle:2016 WRX WRB |
that's because the vendors that sell OTS tunes, have their own intakes, and they're selling you a "package"
11-16-2017, 12:42 PM | #617 |
Member#: 295970
11-16-2017, 12:54 PM | #618 | |
Member#: 474796
I'm just saying that both MAP and COBB have OTS Stage 2 tunes, and they also both have their own intake; they're just selling it as a "package." They're trying to make money. you don't need an intake until you get to the point where you're making serious power. I don't need the headache. i tend to only buy what i need and what will actually make a change. spending $350+ on a noise maker that could potentially turn into a HUGE PITA just isn't worth it for me. there are better ways to spend your money. like an e-tune/pro-tune. i also don't want to have to keep my AP plugged in and have to watch it 24/7 to make sure my motor doesn't nuke itself. Last edited by PizzaBoyX; 11-16-2017 at 01:05 PM. |
11-28-2017, 03:43 PM | #619 |
Member#: 478407
Gorgeous post ***128514;
12-17-2017, 10:26 AM | #620 |
Member#: 479320
Me
02-15-2018, 05:27 PM | #621 |
Member#: 482163
I can remember reading this before I actually made an account. awesome info!
05-07-2018, 03:21 PM | #622 |
Member#: 351570
Looking to make around 280 whp on my 2017 WRX. So far I haven't done any power mods, and it is my daily driver so I don't want to do anything crazy. Here's what I'm thinking:
Cobb Accessport TGV/EGR deletes Grimmspeed EBCS Process West Khanacooler intercooler Grimmspeed charge pipe Invidia Q300 cat back exhaust |
05-07-2018, 04:33 PM | #623 | |
Member#: 295970
https://forums.nasioc.com/forums/sho....php?t=2667243 |
05-12-2018, 02:35 PM | #624 |
Member#: 482725
RMIC
Vehicle:2004 Impreza Wrx Silver |
I recently got a tune and was wondering, do I go by the "WCF" numbers? Maximum power is 235.1and WCF its 301.0
Can't post pictures but here's some background 04 wrx, Mustang dyno @5250 Built transmission RA gears 1-4 2.5 shortblock 2.0 heads Vf39 turbo 1000IDs Sti top mount Bmp turboback exhaust Cobb bov E-85 |
05-13-2018, 10:27 PM | #625 |
Member#: 178426
Altitude kills power. You can go by either number, it's actually 235whp, wcf would be what it would make at sea level and standardized temp. That way you can compare it to other similar setups.
Similar Threads | ||||
what do I need to hit 250whp? | juvenescence | Newbies & FAQs | 29 | 01-15-2019 02:38 PM |
What do I need to hit 350-375 HP? | pipchick | Newbies & FAQs | 60 | 01-15-2019 02:38 PM |
I’m flying to Orlando. What do I need to do in the airport and what to bring home? | KingGalantVr4 | Off-Topic | 37 | 01-14-2010 11:49 PM |
I want to do my own 30,000 mile service, what do I need to do? | Drav | Service & Maintenance | 12 | 06-20-2005 06:43 AM |
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! | SuBaRu-ImPrEzA_RS | Impreza Forum | 2 | 06-03-2001 10:11 PM |
