Welcome to the North American Subaru Impreza Owners Club Sunday February 25, 2018
Old 02-21-2002, 03:56 PM   #1
SpooledRex
Member#: 10216
2002 WRX - WR Blue
Default Gauge wiring question
What wire off of the clock harness do I tap into for power to a guage?
Bat, Lig, or Acc
Chris
SpooledRex is offline   Reply With Quote
Old 02-21-2002, 04:20 PM   #2
freq
Member#: 14091
71 dime
03 TDI
i'm doing my gauges this weekend.
quoting a thread i'm too lazy to lookup: i'm looking into this solution.
use the harness on the stereo!
You can get the connector from Pep Boys - Part# 85194 "Hitachi Clutch Coil Socket". I think it was 2 or 3 bucks. That plug allows you to plug into the back of the stereo harness and will provide power to the gauge. It adjusts along with your dimmer as well. When you pull the stereo out there is an unused connector that is taped to the rest of the stereo harness. Plug that connector there and run wire to your gauge. It doesn't matter which way you hook the wires up to the gauge.
but provided i can't get the harness: i have 4 wires on my greddy gauges:
12v = Red
12v Ignition = Orange
12v Lighting = White
Ground = Black
okay... where the heck do i hook these puppies? the red is easy, the black is easy, the ignition and lighting are a mystery... i'm guessing the lighting is for the dimmer.. where do i hook this up?
um thats it
-Brandon
freq is offline   Reply With Quote
Old 02-21-2002, 04:32 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I think others have just used the clock harness. Depending on where you are installing the gauges. That's the logical choice if you are putting in a pod to replace the clock. The clock has 12v constant/ignition/illumination/ground on the harness. Here is a recent thread that documented what is where (or you could search for other threads that also document things)
http://www.i-club.com/forums/showthr...harness+gauges
I'm not sure anyone has bothered making the dimmer work. Illumination just means when the lights are on the gauge lights are on too. Ignition is when you turn the key the gauge will go to 0 or do whatever.
Old 02-21-2002, 04:52 PM   #4
SFastWRX
Member#: 13379
I am Oz
FWIW, on my digital guages, the dash illumination dims mine so they aren't so bright at night (they reduce intensity when they sense 12v power to the "dim" connectors). I left it off, since I like full brightness all the time.
SFastWRX is offline   Reply With Quote
Old 02-21-2002, 06:23 PM   #5
jclick
Member#: 4525
2002 WRX Wagon
Does anyone know where to get the wiring harness for the clock? Part Number? So I can wire my gauges nice and clean. I asked the dealer but they did not help much.
jclick is offline   Reply With Quote
EGT Gauge wiring question EJ205rulezall Electrical & Lighting 5 01-13-2004 01:36 PM
New Gauges Wiring Question For 03 Wrx leepym3 Electrical & Lighting 1 04-02-2003 07:09 PM
Help: Foglight and Gauge Wiring Questions Bankheist Electrical & Lighting 9 02-19-2003 11:25 PM
gauge wiring question dark knight Car Audio, Video & Security 2 10-14-2002 08:22 PM
Greddy Boost Gauge wiring question tymbrwolff Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-25-2002 10:04 PM
