04-22-2014, 03:53 PM | #4226 | |
Member#: 64289
Vehicle:2004 wrx wagon wrb |
The punch series woofers aren't an IB woofer - in fact these 8's are the opposite - they are intended for extremely small enclosures (0.23 cu/ft sealed, according to their spec sheet) - the main reason for this being their limited free-air suspension/ excusrion (an IB sub will have a heftier surround which supports the weight and motion, while non IB suited subs actually use the compression stroke to help re-center themselves, for fast action/ accuracy. Now, with all of that said - these are 8" subs, so they are going to rebound pretty quick anyways. They likely sound good in a vehicle application, and give the guy better low-end than he previously had.. and cost him nothing since he had the subs. (a vehicle is far from an audiophile's dream environment - especially the noisy wrx) Anyways - The only thing i'd watch out for is pre-mature surround wear in an IB application. Alternatively, you can add 2x small sealed enclosures on the back of your baffle board there, - 1/2" mdf, 10x10x6 (od) will get you spot on to the requirements... see how they sound then... you can always remove it.
04-22-2014, 10:43 PM | #4227 |
Member#: 388226
Has anyone constructed a short ram intake box from scratch? Was looking into making a custom plexiglass one in the near future.
04-22-2014, 10:57 PM | #4228 |
Member#: 355299
South East
Vehicle:2002 impreza wrx silver |
That would be awesome
04-22-2014, 11:05 PM | #4229 | |
Member#: 383262
Vehicle:2004 WRX Wagon Silver |
04-23-2014, 08:35 AM | #4230 |
Member#: 269543
Vehicle:2002 2.5RS BRP 2004 WRX WRB |
Making Boxes on the underside will be impossible without cutting out most the metal structure under the window. Plus, that would defeat the point of me putting the subs there in the first place, trunk space. I wasn't about to do that if it worked the way it is.. which it does..
04-24-2014, 12:20 PM | #4231 | |
Member#: 64289
hence my last paragraph.. if they work, they work.. and you had them on hand. If running them infinite baffle makes them tear at the surrounds over time - you can explore some IB subs at that point. |
04-24-2014, 01:17 PM | #4232 | |
Member#: 70710
Vehicle:2002 04STi Swaped RS w/PPGS & 02 Wagon w/PPGs |
04-24-2014, 02:11 PM | #4233 |
Member#: 269543
04-24-2014, 04:13 PM | #4234 |
Member#: 64289
like any other sub, they can sound different depending on set up... they generally need more power to produce proper punch, - the mid bass region an 8" loves, compared to a vented or sealed setup - but in return provide much greater low frequency response. an 8" ib will roll off the lower frequencies much more smoothly.. With enough power - they move air like a vented unit, but aren't peaky like one - having a very smooth frequency roll off, like a sealed sub... hard to explain without listening side by side... Compared to the fosgates, you'll likely have to feed them more power to get the same mid-bass feel, but you'll gain a lot of low and very low frequency with a smooth transition between octaves... 8" is a tough choice for open air though - not a lot of variety compared to say..10"+
04-24-2014, 06:23 PM | #4235 |
Member#: 166324
NESIC
04-24-2014, 08:44 PM | #4236 |
Member#: 173734
South East
Vehicle:2007 STi WRB |
04-25-2014, 10:25 AM | #4237 |
Member#: 269543
Thanks man. I have a tear in my steering wheel, its way more annoying than I ever thought it would be!
I have been thinking about pulling off the torn leather and suede flocking the steering wheel. I know it will wear off eventually, but for a short term fix until I feel like spending the money on a new/used one. |
04-30-2014, 10:40 AM | #4238 |
Member#: 79643
NESIC
Vehicle:2021 STI TE Terminal black pearl |
http://www.subimods.com/hella-supertone-horn-kit.html
http://www.importimageracing.com/hel...300-500hz.html Nope. Isn't unique. Or custom. |
04-30-2014, 11:14 AM | #4239 |
Member#: 99206
W. Canada
Vehicle:2007 WRX STi wagon Ducati Hyperstrada, WR450 |
Here's my current custom DIY modifications on my 07 WRX wagon.. Alcantara wrapped upper dash & upper door panels, 05 Impreza door inserts, Subigal 52mm pod modified to fit 60mm gauge then wrapped to match dash, and last but not least a painted DAMD wheel covers and wrapped Pioneer deck to remove the logo's on it for a more OEM fit.
Combine that with an older DIY mod of installing EvoX seats with a 05 Impreza rear seat covers. |
04-30-2014, 11:28 AM | #4240 |
Member#: 260395
NWIC
Vehicle:2004 Impreza 2.5 RS Blue |
^ that all looks very clean, well done.
04-30-2014, 11:36 AM | #4241 |
Member#: 389201
NESIC
Vehicle:2002 Impreza WRX Black |
04-30-2014, 01:24 PM | #4242 |
Member#: 31016
NWIC
Vehicle:2016 Focus RS (blue) 2005 WRX Wagon (white) |
I have Evo 8 seats in my '05 Wagon |
04-30-2014, 08:54 PM | #4243 |
Member#: 363892
BAIC
Vehicle:2013 WRX Hatch Prem SWP |
05-01-2014, 07:35 AM | #4244 |
Member#: 386929
Vehicle:04 sti |
05-01-2014, 05:12 PM | #4245 |
Member#: 284753
Vehicle:2004 WRX STI World Rally Blue |
If that box is not sealed, I hope you used a free air sub. Otherwise you'll be blowing those very shortly.
05-01-2014, 05:18 PM | #4246 |
Member#: 79643
NESIC
05-01-2014, 07:15 PM | #4247 |
Member#: 371737
Vehicle:2003 **** Your Fake Parts |
Deleted
05-02-2014, 10:26 AM | #4248 |
Member#: 177880
South East
Vehicle:2002 Wrx Wagon 6sp Where can I get some cake |
05-02-2014, 06:03 PM | #4249 |
Member#: 387223
NESIC
Vehicle:2016 WRX Lapis Blue |
05-02-2014, 07:04 PM | #4250 |
Member#: 378818
Show us your unique modifications | lancewr1 | Interior & Exterior Modification | 7214 | 01-10-2012 12:09 PM |
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods | bluerex79 | Member's Car Gallery | 6 | 05-02-2011 09:02 PM |
Calling all Graphix......Show Us Your Stuff... | grnlantern1 | Member's Car Gallery | 37 | 07-16-2002 01:25 AM |
show us your wrx gauge installs. | lstepnio | Member's Car Gallery | 51 | 05-22-2002 03:43 AM |
Show us your T's (OZ Super T's that is) | Who flung dung | General Forum Archive | 11 | 02-12-2001 07:46 PM |
