Welcome to the North American Subaru Impreza Owners Club Monday October 22, 2018
Old 07-11-2017, 08:14 PM   #2351
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Yes, I have completely removed and blocked off the stock valve on my TMIC. I utilized every built-in option the EFR has for simplicity.
yamahaSHO is offline   Reply With Quote
Old 07-11-2017, 09:30 PM   #2352
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Originally Posted by Silversurfer594 View Post
my question is this, once converting to speed density, I guess the recirc valve(not the one built into the turbo) becomes a BOV. I'd like to hang on to this feature. That being said, can one just block off the built in recirc valve on this turbo(7163)?... my interpretation is that it wouldn't detrimentally affect the performance of the turbo if one indeed could bypass/cut it out of the equation. Any help would be awesome! Thank you.
You are correct, the installer can block off the valve on the TMIC -or- block off the valve on the turbo. I typically prefer to utilize the valve on the turbo because it is so simple and redirects the vented-charge-air to the compressor inlet. but your call entirely.
Here are some photos from this thread of our kit with TMIC valve blocked off:
Full-Race Geoff is offline   Reply With Quote
Old 07-12-2017, 12:15 AM   #2353
Silversurfer594
Member#: 408184
2011 WRX
Geoff, I've stopped by your shop before(I live locally) and although I didn't get to talk to you directly, the staff was great there. Do you guys install the kits as well? Probably a silly question but I don't want to assume anything. I'm conflicted on the stock location vs. twin scroll/rotated configuration. I'm not sure how much modification is necessary to do the twinscroll configuration but was curious to see if you guys will do the work(when I'm ready).
Thanks.
Silversurfer594 is offline   Reply With Quote
Old 07-12-2017, 01:38 PM   #2354
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
Thanks.
hey thanks for stopping by Full-Race and checking us out. The choice between twinscroll and stock location really depends on what are your longer term goals? Will the motor stay stock or will it get built? Will you run mostly pump gas or mostly Ethanol?
We originally thought the stock location kits would be more popular than twinscroll -- Stock location is an easier installation, its RHD compatible and allows for most existing modifications to remain unchanged (TMIC, intake, etc). Surprisingly Twinscroll has been more popular... Twinscroll kits are more work to install, but still fairly straightforward and similar to most other rotated kits - requiring a PS hose modification. Typically we do not offer installation services. However since youre local, I might be willing to make an exception. email to [email protected] and [email protected] when you are ready and we can either give you a green light or refer you to someone else. thanks -Geoff
Old 07-22-2017, 04:16 PM   #2355
sergey2007
Member#: 304910
2004 LGT ej207 7163
Please share opinions on the oil drain. Does not quite follow the instructions. But at the same time, the length of the oil drain is small and the cross-section of the tube is sufficient. Will it work correctly on EFR 7163? I also assume that the oil flow through the ball-bearing turbine should not be greater.
Thank you in advance for your advice.
sergey2007 is offline   Reply With Quote
Old 07-22-2017, 08:00 PM   #2356
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
it could have problems due to the welded 90 degree bend. it might work, the test is to roll a 1/2" ball bearing through the tube. if it doesnt get stuck you will probably be fine
Old 07-23-2017, 04:03 AM   #2357
sergey2007
Member#: 304910
2004 LGT ej207 7163
Thank you very much for your answer. The ball rolls, but I also do not like the welded turn. Made from the fact that it was available, but apparently need to find a smooth turn and remake ...
Old 07-30-2017, 01:00 AM   #2358
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Since I had to get the IWG actuator out of the way to replace an oil feed adapter, I added more preload when I put it back on. I am up to 7mm preload now... Before driving, I went in and made a new map to lower the WGDC and I got pretty close on the first try. The difference is pretty nice. It'll now hold like 22ish PSI at redline, but I am overshooting by a PSI'ish. I have 3 logs; 2nd gear, 3rd gear, and 4th gears (below):
This is about 6,000 ft above sea level on a .85 housing.
2nd Gear
3rd Gear
4th Gear
4th Gear with Target Boost and WGDC (not sure why Target Boost is jagged in the beginning as the map is not)
Old 07-30-2017, 02:47 PM   #2359
Th3Franz
Member#: 37146
2005 Legacy GT
Stage tree fitty
Thanks for sharing, yamaha. I'm about to add more preload to my IWG actuator also. How much have you scaled your turbo dynamics? I had to drop my proportional and integral TD tables down by A LOT with the dual port IWG actuator.
Any reason you start below 50% WGDC before boost threshold RPM is reached?
Th3Franz is offline   Reply With Quote
Old 07-30-2017, 03:16 PM   #2360
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I don't get any better spool with more WGDC and I don't want to deal with spikes, so that's where WGDC sits.
I haven't adjusted TD in a long time, but I think I've taken around 30% out across the board.
Old 11-17-2017, 05:39 PM   #2361
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
how do I take turbosmart 2 port apart? need to see what spring I have installed in there
Hyper is online now   Reply With Quote
Old 11-17-2017, 07:53 PM   #2362
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Get one of these and a quick grip clamp.
https://www.amazon.com/dp/B004PPYWNW/ref=pe_385040_128020140_TE_3p_dp_1
Old 11-18-2017, 12:15 AM   #2363
Nick411
Member#: 362723
2002 WRX w/ V7 EJ207
You will also need to load the actuator up in a press or vice to take the spring load off the threads so you don't destroy them removing the ring. I found with mine that if you do that you can actually loosen and tighten the ring by hand and no tool is needed as all of the load on the ring is from the spring.
Nick411 is offline   Reply With Quote
Old 11-18-2017, 06:06 AM   #2364
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
its hard to put it in vice with all the things sticking out of the bottom
but I'll give it a shot
and a special tool?? man, turbosmart is a real extortioner
Old 11-18-2017, 10:57 AM   #2365
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I use these on this actuator as well as when I had a TiAL EWG....
You don't absolutely need the special tool, but it makes it easier. My collar did not just come off by clamping the halves together.
Old 11-18-2017, 11:17 AM   #2366
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
ended up using wise grips and put two pieces of wood to protect the actuator, the collar was tight so I used adjustment wrench from my coilovers
purple and pink... according to the manual it would only give me 14 psi
the table is confusing with the mix and matching, I want to run 2 bar peak and be able to drop to 1 bar for failsafe map
My recommendation is the turbosmart 21psi spring. It will put you around 16psi base with 30psi around 80% duty give or take, depending on setup and preload
however I don't see a single 21psi spring in the chart
Old 11-18-2017, 11:20 AM   #2367
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
So leave the 14 PSI springs in... It is the boost controller that allows you to get higher than spring pressure.
I'd also go to 8-10mm of preload to make it work like it should.
Old 11-18-2017, 12:01 PM   #2368
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
I don't think I have enough thread to allow that much preload, possibly the actuator is meant for another frame
Old 02-07-2018, 12:15 PM   #2369
Subi114
Member#: 48401
2015 EFR7163 STI
Dark Grey Metallic
so I'm wondering if anyone here is actually running the 7163 stock location on their STI?
I have it on my 2015 and I've noticed slight smoking coming from my exhaust after warm up. But once the car is in motion it goes away and only comes back if I'm sitting at the light for an extended period of time. Any feedback would be great.
Subi114 is offline   Reply With Quote
Old 02-07-2018, 12:23 PM   #2370
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Do you have a AOS?
Fierysun is offline   Reply With Quote
Old 02-07-2018, 12:26 PM   #2371
Subi114
Member#: 48401
2015 EFR7163 STI
Dark Grey Metallic
Originally Posted by Fierysun View Post
Do you have a AOS?
Yes I have an IAG AOS..
Old 02-07-2018, 12:41 PM   #2372
Full-Race Geoff
Member#: 133386
13 F150
ecoboost
there are two possible causes of this in my experience:
Inspect oil drain hose: are there any kinks or restriction in the oil drain line? if its too long or crooked it can cause this
Consider an oil restrictor feed fitting: Its not often but we do have a few instances (only subaru) which had this resolve with a 1.5mm - 1.6mm oil feed restrictor fitting. i am making a batch of these in a couple weeks
Old 02-07-2018, 01:42 PM   #2373
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
Check the oil feed adapter. I can't get mine to stop leaking. I've ordered a replacement and it did not work either. Basically it is too deep to seal on the flare. I am going to order another and shave it down before installing.
It's been irritating, to say the least.
Old 02-07-2018, 01:44 PM   #2374
Subi114
Member#: 48401
2015 EFR7163 STI
Dark Grey Metallic
Thanks Geoff, I'll check that. Also I'd like to get one of these fittings I PM'ed you and let me know how I can acquire the restrictor fittings. Thanks
Old 02-07-2018, 01:45 PM   #2375
Subi114
Member#: 48401
2015 EFR7163 STI
Dark Grey Metallic
Thanks, I'll look into that as well. I'm gonna see about getting her up on a lift tonight and do a complete look over thanks.
