Welcome to the North American Subaru Impreza Owners Club Wednesday November 21, 2018
Old 05-16-2010, 02:57 PM   #1
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Default Oil Filter Test Study
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
I've always known fram filters were garbage and i cringe when i see someone running one... especially on a built motor.
Fram filters also have the lowest amount of filter media which means less surface area for filtration.
I have always run purolators
All4bSpinnin is offline   Reply With Quote
Old 05-16-2010, 03:27 PM   #2
only1agam
Member#: 56183
purolator pure ones.... are amazing
only1agam is offline   Reply With Quote
Old 05-16-2010, 08:56 PM   #3
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
maybe a mod could sticky this test ?
Old 05-16-2010, 09:05 PM   #4
rolzrex
Member#: 85790
07 FXT 6-speed
Rally Blue
the link's not working for me
rolzrex is offline   Reply With Quote
Old 05-16-2010, 09:38 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
This page was written and is maintained by Russ W. Knize and was last updated 06/20/00
Good luck with that 10 year old info....
munkis is offline   Reply With Quote
Old 05-16-2010, 09:39 PM   #6
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
That link has been in the Oil FAQ since you were in high school.
Old 05-16-2010, 09:47 PM   #7
scoobynewbie1
Member#: 150406
2006 wrx wgn
wrb
this is probably weird but i actually use a honda filter on my subby.
scoobynewbie1 is offline   Reply With Quote
Old 05-17-2010, 03:01 AM   #8
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
durr thanks unabomber... my mistake... "READ THE FAQ's ALL4... you loser!"
sadly... i really do not think that much has changed... i would like to see the k&n filters opened up myself...
Old 05-18-2010, 10:56 PM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
http://www.bescaredracing.com/sti/oil/filters/kn/
DrD is offline   Reply With Quote
Old 05-18-2010, 11:13 PM   #10
MRF582
Member#: 48219
. Always drive
the race line .
Yup. Same here. PL14610 made for a Honda S2000.
MRF582 is offline   Reply With Quote
Old 05-19-2010, 06:34 AM   #11
Gunner
Member#: 36540
04 GGA
Cobb Stage 1 EQ Tuned
Look for river_rat's study on BITOG. Very interesting.
Gunner is offline   Reply With Quote
Old 05-19-2010, 09:29 AM   #12
Ernest
Member#: 45076
2004 Stg 2 wagon AT
16 BRZ. Both silver
I agree that Fram are the worst and I would not use one on my subie. My father and I have used regular old orange Frams on multiplte N/A cars with 3K OCI for over 150K some upto 200K miles. So for as bad as they are with regular maintenance they worked.
Ernest is offline   Reply With Quote
Old 05-19-2010, 10:53 AM   #13
JPM Coachworks
Member#: 190108
2008 WRX STI
LR
I'll have to try that when I run out the H6's. I just started using them after my black sti ones ran out
JPM Coachworks is offline   Reply With Quote
Old 05-19-2010, 11:03 AM   #14
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
PL14610 is speced for every honda engine (d, b, f, j, k) since 1988 . The OEM filter for the S2000 has a slightly higher bypass setting than the 'regular' Honda filter. Purolator says that the 14459 filter is for the S2000 and that actually has LESS bypass pressure setting than the 14610 so if you do have an S2000, do not use what Purolator tells you too. At least use the 14610, but I'd just get the real S2000 filter from the dealer.
The 14610 is exactly the same filter as the 14612 (which is what Purolator specs for Subarus....still lower bypass pressure than what Subaru's want) except it is about 3/4" longer...more oil means slightly lower oil temps (though in this case, it's likely negligible), but you will have to put a bit more oil in the car to get it to the full mark.
09rexwagon is offline   Reply With Quote
My own humble Subaru oil filter study armand1 Service & Maintenance 38 08-02-2010 10:14 AM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 09:25 AM
Cool little study I found about different brands of oil filters LinuxGuy Service & Maintenance 2 12-31-2002 04:21 PM
Oil filter study, Help!? WRXDAN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-18-2001 05:32 AM
Oil and oil filter? Spark plugs and air filter? TimCat General Forum Archive 5 01-19-2001 12:27 AM
