Welcome to the North American Subaru Impreza Owners Club Thursday July 18, 2019
Old 06-12-2019, 10:46 PM   #1
08SpecB_DE
Member#: 470981
2008 Legacy GT spec
Default Odd starting issue
Hey guys,
Long story short, every year when it starts to get warm, my car has a hard time starting. Let's say its 60 in the morning, car fires up fine. At the end of a work day its 85 and the car will crank and crank. I've primed the pump thinking it or an injector was leaking down, that didn't help. The only thing that does help is holding the gas pedal down just a little bit. Now that it has been consistently warm, it starts every time no matter the conditions.*
I have a fpr sitting on my toolbox but I dont want to put it on if it's something silly like the ots tune adjusting to temperature fluctuation. Perhaps I should start with cleaning the*throttle*body? I'm a little nervous about cleaning the maf, I've seen them get ruined even when using maf cleaner. Should I try anyways?
08SpecB_DE is offline   Reply With Quote
Old 06-13-2019, 07:28 AM   #2
Jay11STI
Member#: 492422
Yeah i wouldnt recommend cleaning the MAF, i think its a bunch of nonsense and usually leads to them failing. I would recommend replacing the MAF and see if anything changes.
What kind of car do you have? Modds? Maintenance? Mileage?
Jay11STI is online now   Reply With Quote
Old 06-13-2019, 08:42 PM   #3
08SpecB_DE
Member#: 470981
2008 Legacy GT spec
2008 LGT spec B ~120k miles
Cobb ots stage 2 93 octane
Invidia catted downpipe with magnaflow cat-back
AEM dryflow air filter
GFB hybrid bov set on full recirc
The car runs good otherwise. I bought it almost 7 years ago with 60k on the odometer. I did the t-belt at 98k in 2015 and new ngk o.e. plugs about 15k miles ago. Everything else is original...maf, af/o2's, turbo, fuel pump, etc. I have a new vf52 and gs intercooler waiting for me to install, I just need the time and the hassle of getting it to a dyno or e-tune is prolonging the process. I burn maybe a quart every 4k miles.
Old 06-13-2019, 08:52 PM   #4
Suryank
Member#: 500698
+1
Suryank is offline   Reply With Quote
Old 06-14-2019, 07:19 AM   #5
Jay11STI
Member#: 492422
At 120K yeah id say its time to start with a MAF and oxygen sensors. Especially if they are all originals.
Old 06-14-2019, 09:24 AM   #6
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Huh? If done correctly cleaning the MAF can fix issues IF it's dirty.
Scorpius is offline   Reply With Quote
Old 06-15-2019, 08:32 PM   #7
08SpecB_DE
Member#: 470981
2008 Legacy GT spec
I see folks have good luck with Denso 197-6040 maf sensor. Do you guys think I can get away with NTK af/o2's? O.E. maf is around 150 and same for the front 02. I'm not opposed to going o.e. as I'm very familiar with aftermarket parts and how ****ty they can be but every now and then you get lucky and are able to save a little going aftermarket.
Old 06-17-2019, 07:45 PM   #8
08SpecB_DE
Member#: 470981
2008 Legacy GT spec
Bump...
Old 06-17-2019, 08:15 PM   #9
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Always, always, stay OEM with MAF sensors.
