Welcome to the North American Subaru Impreza Owners Club Sunday March 24, 2019
Go Back   NASIOC > NASIOC Reviews > Vendor Reviews
Old 02-28-2014, 08:43 PM   #576
mygreenbird007
Member Sales Rating: (15)
Member#: 154767
Originally Posted by 07wrxstage2 View Post
^^Nice numbers! About 100whp gain over stock without e-85 is pretty decent for those mods. Especially since Jorge is usually on the conservative side but I assume since your using this for autox he probably wasn't as conservative. It's ashame your not allowed to upgrade the turbo.
Thanks! It's a blast so far. The rules can be frustrating but it's also kind of fun to see what we can get out of the car within SCCA specs.
mygreenbird007 is offline   Reply With Quote
Old 03-28-2014, 03:21 PM   #577
user1029
Member Sales Rating: (8)
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
My previous thread (http://forums.nasioc.com/forums/show....php?t=2594791) and now I only added the Cosworth Intake Manifold!
Performance shops can always put out big powered builds however they later turn out to be only mercurial and volatile setups that flicker and die away. What speaks resoundingly to a shop's expertise is churning out crazy builds that last and with a warranty that they stand by. IAG FTW!
IAG V-band rotated turbo kit
- Cosworth Intake Manifold
- HTA86 0.82 Tial V-band housing
- IAG FMIC kit with Spearco core and front bumper beam
- IAG 4" Intake
- IAG V-band Uppipe
- IAG V-band Catless Downpipe
- Tial 44mm External Wastegate with open dump
- GT Spec Equal Length Headers V-band with Uppipe
- Harman Motive Catback Exhaust
- Aquamist HFS-6 running Boost Juice (50% methanol/50% water)
- Injector Dynamics 2000cc injectors
- Aeromotive 340lph Fuel Pump
- Aeromotive Fuel Pressure Regulator
- IAG Fuel Rails
- IAG TGV Deletes
- Cosworth Phenolic Spacers
- Grimmspeed Electronic Boost Control Solenoid
- Grimmspeed Thermostat
- Mishimoto Radiator
- Tial Q BOV
- LFR7AIX Spark Plugs
- IAG Catchcan
- Stock Air Pump deleted
- IAT sensor and 4 Bar MAP sensor
- Cobb Accessport Speed Density protuned by Jorge
IAG Stage 2 Bottom End
- Manley Platinum Series 99.5mm Piston Set
- Manley H-Beam Rods
- ACL Main and Rod Bearings
- OEM Nitrided Crank, OEM headgasket
- Killer B Oil Pickup with Baffle
- Gates Racing Timing Belt Kit
- 12,000mile/1year warranty
IAG Stage V Heads
- ARP2000 Head Studs
- Manley Extreme Duty 33mm Exhaust Valve Set
- Manley Race Flow 37mm Intake Valve Set
- Manley Valve Spring and Retainer Kit
- IAG Stage V headwork with Multi Angle Valve Job/Port&Polish
- Kelford Dual AVCS 272/268 11.30/10.50mm Lift Street Cams
user1029 is offline   Reply With Quote
Old 07-26-2014, 12:27 PM   #578
user1029
Member#: 57064
2008 STi IAG built
Big thanks to Evan @ IAG for doing flawless work on my car
1. 90K maintenance
2. New Tires/Brake Pads
3. IAG AOS install
4. Corsa Exhaust install
5. New IAT sensor/relocation due to recent CEL
Old 10-30-2014, 06:52 PM   #579
user1029
Member#: 57064
2008 STi IAG built
Credits to Boris at IAG!
As usual big thanks to the whole IAG crew and Jim for working on my car! Fantastic matte black paint job by them as well! Lost 50lbs of unsprung weight and it made a huge difference in every category. Accelerates easier, turns easier, brakes easier! Like an athlete taking off ankle training weights :tup:
Old 05-27-2016, 12:19 PM   #580
bluemax189
Member Sales Rating: (20)
Member#: 137405
2011 WRX 6spd
GTX3076r
another great experience at IAG yesterday. I have their AOS and recently upgraded to a rotated setup. Bought the aos relocation bracket and asked if i could get the replacement hoses since i trimmed them to fit with the AOS's old location. No issues and they filled the request happily and had a box waiting for me to pickup! Great customer service.
bluemax189 is offline   Reply With Quote
Old 06-26-2017, 05:26 PM   #581
joewrx628
Member#: 296411
2011 4dr STi
Not happy with them at all. They took my money for a closed deck block almost two months ago and still no word from them.
Glad it says 3-4 weeks on the website....
Edit: spoke to my tuner who places the order. Says it should be in this week so let's see what happens
joewrx628 is offline   Reply With Quote
Old 06-26-2017, 05:58 PM   #582
jj_warhorse
Member Sales Rating: (6)
Member#: 300124
2005 STI
CGM
Did you call or email? I thnk they ship something like 5+ blocks a day. Following up on an online order is a good idea. I had zero communication issues with them when I ordered my stg 2.5 closed deck about 1.5 yrs ago, but that is before their orders went through the roof.
jj_warhorse is offline   Reply With Quote
Old 06-28-2017, 03:20 PM   #583
IAG Performance
Vendor Sales Rating: (66)
Member#: 158123
Sir,
I apologize that you are frustrated with the delay on an engine order. We sent out the following email to our customers and shops affected around 6/7 with information about the delay. It is certainly never our intention to leave someone in the dark about an open order. See below. If you would like to further discuss, best way to reach me directly is [email protected].
Good Afternoon!
First off, thanks so much again for your order with IAG Performance. We sincerely appreciate you trusting us with your build.
I am writing to inform you of a brief delay on your IAG Staged Short Block. Unfortunately several weeks ago, one of our hones experienced an electrical issue causing a bottleneck in our engine assembly workflow. We have worked closely with Sunnen to fix this issue as quickly as possible, but obviously this set-back has caused delays in engine production. Many unfulfilled/open short block orders are running approximately 1-2 weeks (or slightly more) behind our anticipated ETA when the order was placed.
We apologize sincerely for missing our timeline projection that appeared on our website when you ordered. We are back on track and moving forward with your order, but wanted to reach out to make you aware of the delay. Thanks so much for your patience and understanding. Feel free to reply directly to this email with any questions or comments about your specific order.
Thanks again and have a great week.
Kind Regards,
Rick Arbogast
__________________
[LEFT]
[/LEFT]
[LEFT][FONT=Tahoma][COLOR=black][B]See our 100% positive vendor review thread [/B][/COLOR][/FONT]
[/LEFT]
[LEFT][SIZE=1][B][I]
[/I][/B][B][I][COLOR=red] / 410-840-3555 /
[/COLOR][/I][/B][/SIZE][/LEFT]
IAG Performance is offline   Reply With Quote
Old 07-01-2017, 08:32 PM   #584
subarumod
Member#: 468745
06 wrx
black as your girls soul.
anyone on here buy the $15k motor IAG has?
subarumod is offline   Reply With Quote
Old 07-14-2017, 04:44 PM   #585
Inizes
Member Sales Rating: (1)
Member#: 432770
2017 WRX Limited
Crystal White Pearl
I believe a user named "Boost Junkie" might be getting one. He has a 2010 Racecar with IAG livery, check out his thread. https://forums.nasioc.com/forums/sho....php?t=1921025
Inizes is offline   Reply With Quote
Old 07-22-2017, 11:28 PM   #586
PlanB17
Member#: 304037
2007 STI
UGM
Currently i'm sitting at 11th week of placing my order for a CD stage 2.5 block and still no word of it making it in. Considering that I had everything planned and ready to go with their 3-4 week eta. This just really irritating.
Hoping ricks post saying that i'll see my block soon.. Racing season is almost done
EDIT: My Vendor is taking care of the situation, Looks like things are moving at a pace I was expecting from the beginning.
PlanB17 is offline   Reply With Quote
Old 07-23-2017, 12:21 AM   #587
Eggman's-STI
Member#: 66512
Frustrating I'm sure, but it is worth the wait. Love my 2.5 CD. Hang in there, smiles will prevail once its done.
For what its worth, im waiting on backordered stickers apparently, going on a month now. LOL
Eggman's-STI is offline   Reply With Quote
Old 07-24-2017, 10:29 AM   #588
IAG Performance
Member#: 158123
We do not have any engine orders this old pending completion.
Is it possible you purchased an IAG engine from one of our dealers?
Could you please PM us your contact information and we'll look into this further for you.
Thanks, Keith
__________________
[LEFT]
[/LEFT]
[/LEFT]
Old 07-29-2017, 11:08 PM   #589
PlanB17
Member#: 304037
2007 STI
UGM
Thanks, Keith
PM you thanks for getting back at me.
Old 03-06-2018, 06:56 PM   #590
GingyTheDevil
Member#: 434389
2016 WRX limited cvt
Late review on my experience with iag. Got tuned by them middle of last year and up until I traded my vehicle in, it was a phenomenal tune they put on my car. Really got me in last minute with minimal notice and was just a super easy experience, could not recommend them more if your in the area.
I drove 2 1/2hrs to them and would do it again.
GingyTheDevil is offline   Reply With Quote
Old 03-06-2019, 11:17 AM   #591
Dillonbugeye420
Member#: 426102
2002 Wrx hybrid.
Psm
Default Iag performance 5 stars.
Recently orderd a few parts for my bugeye build. Fuel rails, TGV deletes, and fuel line kit all ordered from iag. One of the fuel rails was scratched when I opened up the box. Iag sent me a shipping label and swapped those fuel rails right out, at no cost to me. Awesome customer service. Other companies should take notes.
Thank you; IAG and josh at iag. -Dillon.
Dillonbugeye420 is offline   Reply With Quote
Z1 Performance (merged thread) nmyeti Vendor Reviews 24 07-21-2015 09:46 PM
World One Performance (merged thread) tt_ttf Vendor Reviews 569 11-20-2009 04:20 PM
Renick Motorsports/ISR Performance (merged thread) Star*Child Vendor Reviews 82 01-16-2009 10:50 PM
Vishnu Performance (merged thread) VallejoWRX Vendor Reviews 248 09-17-2006 11:10 PM
