Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 07-15-2013, 01:57 PM   #101
gdoggmoney
Member#: 158150
2007 Impreza 2.5i
Newport Blue pearl
Thank you, thank you, THANK YOU.
ARP case bolts coming. ACL bearings coming. Mitutoyo dial bore gauge kit accurate to .0001 coming and capable of doing every bore on an EJ or VW I own.
gdoggmoney is offline   Reply With Quote
Old 07-16-2013, 09:56 AM   #102
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
I hadnt seen this thread before. Great read thank you!
rexworx is offline   Reply With Quote
Old 07-16-2013, 11:14 AM   #103
gdoggmoney
Member#: 158150
2007 Impreza 2.5i
Newport Blue pearl
Can someone sticky this? It has great info and should be stickied :x
Old 06-08-2017, 11:27 AM   #104
tooR
Member#: 468989
Default TooR
Hello
i have WRX 2.0 L new buid engine block ej20 last version strong, oem bolt case torque suggest by turner i Italy Rally first step 15N/m second Goniometer degrees 60 from center to out bolt, not torque metod, piston coswort Acl HX crank, Acl coswort for con Rod same step first 15N/m second Goniometer 60 degrees, for head use Cosworth bolt not ARP, torque metod NOT Goniometer degrees but use Trimetal head gasket Cosworth 1.1mm 3 step, first 40N/m second 80N/m and last step 115N/m.
My engine have turbo VF22 1.6 bar and output HP 423 and Torque 399 N/m on Dyno, now my car have 150,000 Km road and the engine very fine responce never leak oil or water.
The first brake in Engine use oil mineral 15w 35w and change 1600 Km road, later use Motul V300.
tooR is offline   Reply With Quote
Old 06-08-2017, 12:48 PM   #105
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Is there a question in there somewhere?
I realize that English is probably not your best language, but could you clean up your post so it reads better with punctuation? It would make it a lot easier for people to follow
Samurai Jack is offline   Reply With Quote
Old 02-12-2019, 10:07 AM   #106
luis4685
Member#: 120155
subscribed
luis4685 is online now   Reply With Quote
THE REAL STORY OF WHAT HAPPENED LAST NIGHT TO MY BUDDYS 06 STi with the Pink wheels get sydwayz Mid West Subaru Owners Club Forum -- MWSOC 52 03-14-2007 05:28 PM
lord of the rings, the real story samagon Texas Impreza Club Forum -- TXIC 21 01-27-2005 01:47 PM
Review: S.W.A.T. - The Real Story eurojax Off-Topic 5 05-03-2004 05:28 PM
Thanksgiving - the real story Outraged Off-Topic 82 12-01-2002 10:19 PM
The REAL story of the STi rabbit and P1 Necromancer General Forum Archive 4 08-22-2000 07:11 PM
