Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 10-08-2018, 06:51 PM   #1
strikerca
Member#: 164755
Default MY02 need SMOG
Hello... I have a MY02 that's COBB stage 1 (No catalytic converters) and I need to smog it... My question is, which CATTED down pipe I can install that would make my car pass smog? also would I have to flash the ECU back to factory map?
Any info would be appreciated.
thanks.
strikerca is offline   Reply With Quote
Old 10-08-2018, 11:16 PM   #2
SlammedSix
Member#: 419926
thanks.
Technically no performance catted downpipe other than the OEM catted downpipe should pass smog. If its anything other than stock is would have a CARB# on the cat, like Magnalow's OEM replacement downpipe with cat.
Technically you do not have to change the map back to stock, It shouldn't be there but they can't tell. So remove your AP and don't say anything about it
SlammedSix is offline   Reply With Quote
Old 10-09-2018, 01:45 PM   #3
strikerca
Member#: 164755
Thank you for the info, just to be clear, if I replace the down pipe I have now with the stock catted down pipe, drive around for a bit then go get it SMOGed it should pass... correct?
Old 10-09-2018, 02:08 PM   #4
subiedrewbie
Member#: 190168
2013 WRX
ISM
Its all about your readiness monitors now... so If you are not throwing a code then potentially you could pass as is on the computer... but visual is where they would/should fail you. If you put stock DP back on and reflash you would need to drive for a bit since the ECU reset
subiedrewbie is offline   Reply With Quote
Old 10-09-2018, 02:10 PM   #5
SlammedSix
Member#: 419926
Put the stock downpipe on is a yes.
The only thing to pass smog is visually all the smog equipment is there and nothing looks modified. I had a buddy get failed because of a boost gauge. So depends on the tech how much of an ass he wants to be. But other than visual is all your monitors. If you plug in a code reader you should have an option that says readiness monitors, these all need to say completed. If you don't have them all say completed then there is specific drive cycles for certain monitors to run.
Hope that makes sense
Old 10-09-2018, 02:20 PM   #6
strikerca
Member#: 164755
Got it, thanks again.
Old 01-08-2019, 02:45 PM   #7
WRXkapa
Member#: 414328
2013 WRX
Question about getting failed for visual. Does that part get sent to the DMV? Does it also depend on the person working and could they fail you visually and say to fix that and come back and not tell the dmv?
WRXkapa is offline   Reply With Quote
Old 01-08-2019, 11:35 PM   #8
SlammedSix
Member#: 419926
If they start the smog test and then fail the car on a visual thing its submitted to the DMV. Remember it looks good to the state that they fail you, especially if it passes the electronic part and they "Catch" a visual problem. Once the test starts they can not abort it, if they do it looks very sketchy to the state.
There are some shops that will look over the car before they start the test and give you a heads up that something is an issue and you should correct that and bring it back. This would be the only way that the DMV does not know about you "Failing" a visual
Old 01-09-2019, 12:23 PM   #9
Gallo2011
Member#: 268310
2011 SSM STI saloon
Church!
This is the example (from my experience) I shared with you, WRXkapa. The very first thing the guy testing my car did was pop the hood of my car and start poking around. He noted the CARB sticker for the Cobb SF intake and looked at the downpipe to assure it was stock. Had either of those things been aftermarket and non-CARB exempt, he would have told me to install the stock part and come back. As Slammed said, this is not how ALL testers operate. Some plug all the car's information into the computer as the first step, to prepare for the test. Once that's done, if the visual fails, the DMV's gonna find out about it.
Gallo2011 is offline   Reply With Quote
Old 01-15-2019, 02:30 PM   #10
subaru_gc8
Member#: 29292
2004 WRX wagon
the biggest problem is not the 2 after the turbo, but the one before. if you changed that one to a no catted up pipe like alot of do, you could ahve some problems with passsing. according to the book it says we have 3 cats but most of us take the first one off.
subaru_gc8 is offline   Reply With Quote
Old 01-30-2019, 01:10 PM   #11
cartwheels4amile
Member#: 190405
2002 Impreza WRX
FWIW, Iíve never had issues passing with my Grimmspeed uppipe.
cartwheels4amile is offline   Reply With Quote
Old 01-30-2019, 05:51 PM   #12
Hagbeard
Member#: 40286
'04 WRX Sedan
Platinum Silver
Yeah, too hard to see the uppipe. I've passed several times with a catless uppipe.
Hagbeard is offline   Reply With Quote
Old 01-30-2019, 11:41 PM   #13
subarumod
Member#: 468745
06 wrx
black as your girls soul.
If you put the stock heat shields over the aftermarket downpipe. like magic...
most smog places just use a mirror to look under the car, if you hide up everything with heatshields and the stock weather protection.. Unless you havent had your car tuned and youre just throwing randoms parts on.. Your car will/should pass
subarumod is offline   Reply With Quote
