Welcome to the North American Subaru Impreza Owners Club Friday March 22, 2019
Old 01-31-2019, 02:20 PM   #1
Cyanide7
Member#: 487294
2005 Impreza WRX SED
WR blue
Default 05 STI front LSD into a 05 WRX
Is it possible to dissemble a 05 sti front lsd so its just the diff and swap it over to a 05 wrx with a 5MT using the gearing off of the front diff in the wrx?
I'm not sure if this would work being the sti is a 6MT that uses different axles than the wrx, but it'd be interesting to know if its possible.
Thanks
Cyanide7 is offline   Reply With Quote
Old 01-31-2019, 04:34 PM   #2
fartbox420
Member#: 483915
2004 wrx
6 speed diff wont work with 5 speed.
fartbox420 is offline   Reply With Quote
Old 02-01-2019, 04:23 AM   #3
Cyanide7
Member#: 487294
WR blue
Dang, kinda figured though. It's because of the different bigger axles right?
Could you swap in sti axles and hubs and then still fit an sti axle into a 5MT with the swapped diff or would the axle be too big around to fit into the holes of the 5MT even with a swapped sti diff? Or would nothing end up fitting because the sti diff itself is too big to fit in a 5MT case?
Old 02-01-2019, 10:36 AM   #4
fartbox420
Member#: 483915
2004 wrx
the diff itself is too big for one, 180mm vs 160mm. not sure about everything else.
Old 02-01-2019, 11:53 AM   #5
jamal
Member#: 71875
That's the rear diff, not the front. The ring gear on the front diffs is the same size, but I still don't think it will fit.
jamal is offline   Reply With Quote
Old 02-01-2019, 03:23 PM   #6
fartbox420
Member#: 483915
2004 wrx
you are right, it is the height of the diff thats the biggest difference, by looking at the differential sticky thread the 6 speed differential looks 3 to 4 inches taller than the 5 speed diff.
Old 02-01-2019, 06:03 PM   #7
Cyanide7
Member#: 487294
WR blue
Gotcha, thanks for the replies guys! I'd be sweet if I could find a torsen or suretac front diff for a decent price, but I'll probably get a 6MT if I was to put over $1K into just the front diff.
