Welcome to the North American Subaru Impreza Owners Club Monday March 18, 2019
Old 02-15-2019, 07:54 PM   #1
konaid
Member#: 497833
2006 FX
Exclamation 2006 n/a data interpretation for P0420
Hey guys. I have some questions about the usual P0420 error.
Most likely i just need new cats, BUT i wanted to see if anyone could look at some numbers i got from my blue driver, to see if it makes sense, or if i should be looking into other problems.
A little history on the car:
Car: 2006 FX n/a
Mileage: 178k
Condition: Good, just did TB, WP, bearings, and some other stuff.
MPG: Normal for winter and driving style- about 22 hwy at 75.
Daily driver, but sometimes i step on it.
Any info would be great and appreciated.
Cheers
konaid is offline   Reply With Quote
Old 02-16-2019, 09:32 AM   #2
Jack
Add Lightness
Member#: 13699
not my president
(From General)
When we had a P0420 in our 04 Outback, I did all the "usual" attempts to solve it without replacing the cats. Spark plug defouler, RC, diode. None worked and as we never planned to keep the car long, I would reset the code, wait until all but 1 monitor was ready and get the inspection sticker (my state passes with 1 monitor not ready). The "right" way to go about this is to analyze what the O2 sensor signals are, then repair based on these. I don't have the equipment to do this.
Old 02-19-2019, 03:52 PM   #3
konaid
Member#: 497833
2006 FX
Question
Anyone know how to interpret data? I have some logged. I will post a link. Well, if i can figure out how to share it...
Old 02-20-2019, 09:01 AM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Typical things I do....
Plugs and wires (if not cop ignition)
Check for exhaust leaks near the O2 sensor and forward.
Then look at O2 activity, at your miles, I would likely just replace it.
Check LTFT's, should be within +/- 8% or less. Too far from "0" could be other issues like front O2.
Old 02-20-2019, 01:48 PM   #5
konaid
Member#: 497833
2006 FX
Ok, that is good to hear. I think the LTFT is -5.5%-0. occasionally +2%. Seems reasonable then. So then would i change out the big front ugly monstrosity, or the rear cats? It blows my mind how there are so many in this car!
Old 02-20-2019, 02:36 PM   #6
Jack
Add Lightness
Member#: 13699
not my president
(From General)
Does this have the 2 pipes going through brass sections then joining? I know the 08 Outback N/A very well and those brass sections will wiggle enough to open holes. If you have a lift, look with the car running and see if there's a leak. Like Charlie mentioned, a leak can throw this code.
Old 02-20-2019, 03:11 PM   #7
konaid
Member#: 497833
2006 FX
Hmm... I will have to look at that. I do not know the answer to that yet. Good point though.
Old 02-20-2019, 04:00 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
My "go to leak test" is......car up a bit, engine running, have a helper block off tailpipe/pipes and you listen to and feel around for exhaust leaks. Could be a rotted pipe, rusted off bolts, old gaskets. Especially the "spring bolt" connection undermthe front passengers feet.
We will all assume that exhaust is only pushing out, but I have seen leaks within a foot or so of an O2 pop this CEL.
Old 02-20-2019, 04:36 PM   #9
konaid
Member#: 497833
2006 FX
Thanks... I am having some muffler work done very soon. I will try to have them help me look, while it is on the lift.
thanks
Old 02-20-2019, 08:20 PM   #10
CaptainSlowbaru
Member#: 445600
2002 Outback Sport
Green
There is only one monitored cat. Here's the diagram:
Red: catalytic converter
green: A/F sensor
blue: O2 sensor
pink: clean-up cat
Here's a rundown on sensor data in regards to diagnosing the cat. With your car warmed up and idling, the a/f sensor should hover around 1.00, the MAF should read about 2.5 g/s, and fuel trims should be less than 10% (positive or negative). If all of those are reading correctly, then look at the rear O2 sensor (also known as Bank 1 sensor 2). If it's reading steady (usually in the .700 range) the cat is good. If it's switching back and forth from low to high (example: .135 and .875), the cat is no good.
The "clean-up" cat is irrelevant as far as the P0420 code is concerned. The rear O2 sensor's job is to monitor the cat, and the clean-up cat is down stream of that sensor. You could theoretically hollow it out and the car would never know. Don't waste your money replacing that one.
If it is the cat, you would have to replace the entire "catifold" (as we call it). Unfortunately, they are not cheap. And swapping over all of the heat shields is a major PITA if all the bolts are rusted.
CaptainSlowbaru is offline   Reply With Quote
Old 02-21-2019, 02:57 PM   #11
konaid
Member#: 497833
2006 FX
Thank you. That is exactly what i needed to now. I will look at my data sets. I suspect it is just the damn catifold. That will be fun. Sounds like a project for spring...
Old 02-21-2019, 03:12 PM   #12
konaid
Member#: 497833
2006 FX
Looks like my B1S2 is from like -3 to +2, and often at zero. That is cruise and city. So... i think i may have found the problem.
