Welcome to the North American Subaru Impreza Owners Club Thursday March 21, 2019
Old 09-18-2005, 03:58 PM   #1
sickmint79
Member#: 54385
Default 05 sti wrx jack points
people on the board made several references to the manual stating to jack on the rear diff or some front jack plate. i can't find either in the manual so maybe i'm just being dumb again. anyway where is this front jack plate? was hoping to find a picture.
also do you guys put the stands at the factory jack points? or put them on frame rails?
does anyone go longer than 3k with suby oem oil filters?
sickmint79 is offline   Reply With Quote
Old 09-18-2005, 04:04 PM   #2
sdogg3kgt
Member#: 38397
2002 Lovemachine
There is a picture in your manual if you keep looking. I don't know what page. I have gone longer than 3k with my filter although it is not recommended.
sdogg3kgt is offline   Reply With Quote
Old 09-18-2005, 04:10 PM   #3
kcook
Member#: 78074
2005 STi
look underneath ur side skirt in the front.. its a black area.. u can do it on both sides
kcook is offline   Reply With Quote
Old 09-18-2005, 04:25 PM   #4
sickmint79
Member#: 54385
i thought it was a central jacking point/1 spot ?
Old 09-18-2005, 07:26 PM   #5
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
I think some people use the rear diff and the front jack plate or whatever it is so they can jack the entire front and rear, and place jackstands at the four locations for the tire jack without having to have two separate jacks.
As for the oil filter, I've been changing the oil every 4k, and I'm using the OEM filter. Speaking of which, I'm coming up on time for another oil change.
-Michael
f4phantomii is offline   Reply With Quote
Old 09-18-2005, 07:34 PM   #6
sickmint79
Member#: 54385
yah it's that front jack plack location i'm kinda sketchy on
Old 09-18-2005, 11:05 PM   #7
OrlandoSTi
Member#: 70566
2005 Impreza STi
Team Rptr
You can jack the car up by the pinch welds that run down the entire length of the car on both sides, as well..... No biggie......
OrlandoSTi is offline   Reply With Quote
Old 09-18-2005, 11:28 PM   #8
Lethargic1
Member#: 20998
That's where I've always put them.
Lethargic1 is offline   Reply With Quote
Old 09-18-2005, 11:35 PM   #9
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
jack plate in the front (it connects to the crossmembers - easy to see) and the rear differential in the back
Old 09-19-2005, 11:15 AM   #10
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
Is that front jack plate any different in newer cars (vs. your '02)? I've seen pictures of it, & the one on my '05 Saabaru looks like it has more cut-outs, & it doesn't look as strong as the one in pictures of older WRX's.
JimBlake is offline   Reply With Quote
Old 10-06-2005, 04:44 PM   #11
athakur999
Member#: 88307
2017 Subaru Impreza
Someone take this pic:
http://www.gtspec.com/products/images/New-Image.jpg
And Photoshop in where this front jacking plate is Is it the square black plate directly below the oil pan?
athakur999 is offline   Reply With Quote
Old 10-06-2005, 06:23 PM   #12
woody77
Member#: 94498
2004 WRX - Sold...
My service manual would indicate that that is it (the plate between the lateral links, connecting both front crossmembers).
Pretty much it's the only thing under there to lift with, aside from the front subframe or the body pinch welds.
woody77 is offline   Reply With Quote
Old 10-06-2005, 06:45 PM   #13
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Impreza jacking points:
AndyH is offline   Reply With Quote
Old 10-07-2005, 01:36 AM   #14
jmolaver
Member#: 19130
'01 TTE Miata
www.awesom-oracing.com
^^ exactly
depending on your jack saddle you may want to use a piece of wood (or something) to buffer it against the rear diff / front crossmember..
jmolaver is offline   Reply With Quote
Old 10-07-2005, 03:46 AM   #15
SubieRX
Member#: 16611
05' STi w/ meth inj
Tuned By Harman Motive
Anyone ever use the tow hook to jack up the car? A few of my integra buddies wanted to use that, I just looked at them as if they were crazy. I guess cause they don't have a rear diff??
SubieRX is offline   Reply With Quote
Old 10-07-2005, 07:55 AM   #16
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
The jake plate is the plate where two bolts holding up the under cover attach. Like others have said, it is really the only thing there. I just used it last night to change my oil/filter and swap out tires.
conker69 is offline   Reply With Quote
Old 02-06-2006, 10:09 PM   #17
sndc5
Member#: 87665
2005 FLAT RED STI
Import Tuner May '08
i have used the tow hook before it works fine just doesnt jack up as high
sndc5 is offline   Reply With Quote
Old 02-06-2006, 10:12 PM   #18
05wrxmatt
Member#: 87169
2007 STI Limited
http://www.scoobymods.com/forums/sho...ht=jack+points
I think that it is the same for the STi.
05wrxmatt is offline   Reply With Quote
Old 02-15-2019, 04:44 PM   #19
MikeBru
Member#: 169680
Re-opening this thread with a related question.
I want to install a lift and don't have access to my car to measure this myself. What is the distance, side to side, between the pinch welds on a 2005 STI?
MikeBru is offline   Reply With Quote
Old 02-17-2019, 11:52 PM   #20
Exit 37
Member#: 475618
2006 WRX
World Rally Blue
^This. It's hard to miss once you're underneath the car with the cover bolted up or removed. If the car is too low or the jack is too short, it won't reach so it's safe to drive up on some wood or use the pinch welds on the sides of the car. The rear jack point is the differential. I've been doing it this way in my 06 since the first time it was up on jacks. I've also been using similar jack points on my E36, E83, CX-3, S2000, and Jeep XJ, except that I use the front axle on the Jeep but it's so high up that I don't need to jack it up
Exit 37 is offline   Reply With Quote
02 wrx jack points? flstffxe Service & Maintenance 24 04-16-2009 11:35 AM
2008 STI front jack point? Where is it? Help! scoobbee Service & Maintenance 0 09-01-2008 05:28 PM
STi/WRX jack points Haakon Alaskan Impreza Club Forum -- AKIC 7 07-17-2007 12:58 PM
