Welcome to the North American Subaru Impreza Owners Club Monday January 20, 2025
Old 11-19-2002, 08:09 PM   #1
Davenow
Member#: 23676
Default Go from 19lb 17s to 18ln 18s, Will I still lose power?
I have 17inch P1s they weigh 19lbs.
I am looking at getting 18inch Rota SubZeros, they should weigh around 18 lbs
I know youUSUSLLY lose power with bigger wheels, but since these wont weigh as much, I shouldnt lose anything correct?
Davenow is offline   Reply With Quote
Old 11-19-2002, 09:21 PM   #2
Kean
Member#: 25187
2020 Forester
2010 Challenger R/T
Default Re: Go from 19lb 17s to 18ln 18s, Will I still lose power?
4 lbs is not going to make a difference (wouldn't be noticeable at least). However, the diameter change is a different issue. I'll leave that question with someone who has made a similar change.
Old 11-19-2002, 11:57 PM   #3
Bionic
Member#: 9992
2002 WRX Wagon
WR Blue
A taller wheel/tire combo (with a greater circumference) will result in "taller" effective gearing. It is easy enough to calculate the total rolling diameter of your combo For example: a 225/40 18 is a total of 637.2 mm tall, a 225/35 19 is 640.1 mm tall. A difference that small won't kill you at all, it is less than 1% off. Now if you run some other size (I am making these up here to make a point) like a 225/45 19 the total diameter is 685.1 mm, or 7% off.
Note: Stock diameter is 631.9 mm. A 225/35 19 is 1% off.
This means your gearing is taller (as if you started out in second, instead of first, an exageration, but I'm trying to get this across), revs at a given speed on the highway are slightly lower, acceleration GENERALLY will be slower, mileage GENERALLY will be higher.
As long as the wieght is lower, and overall rolling diameter the same, you will not 'lose' performance.
I hope this helps.
Bionic is offline   Reply With Quote
Old 11-20-2002, 12:02 AM   #4
Davenow
Member#: 23676
Default Great
That is exactly what I thought.
According to Tire rack, a 225/40/18 is the same size as a 225/45/17, so if I can manage to keep the tires the same weight, and I know the 18inch rotas are at least a lb lighter, I will actually GAIN power(ok lol not like I would feel 1lb, but knowing its there is nice)
Old 11-20-2002, 06:54 AM   #5
STX_REX
Member#: 25255
MBP (I washed It)
Dont forget about torque.
Where the weight is positioned is nearly as important as how much there is.
All else being equal the 18" combo will shift the weight farther out from the center of the wheel making it harder to spin, turn and stop.
Later,
Andy
STX_REX is offline   Reply With Quote
Anybody forced to go from a WRX to a Scion Tc? Heavy Fuji Off-Topic 70 09-06-2005 04:07 PM
Looking to go from Stage 0 to Stage 2.5...Need Expert Advice jsavage Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-19-2005 04:00 PM
planning to replace with bigger dia. catback, lose power? yeng Normally Aspirated Powertrain 12 08-26-2004 03:42 PM
Going from VS 1 to VS 2, how to tune MikeWRX-NJ Engine Management & Tuning 2 09-17-2003 11:33 AM
What is the conversion factor to go from Wheel HP to Crank HP? makofoto Proven Power Bragging 11 06-11-2003 04:19 AM
