09-07-2003, 03:17 PM | #1 |
Member#: 34028
Vehicle:2000 Legacy GT Titanium |
Changing oil, different readings!! bahhhhhhh
This might be stupid question, but here it comes. I been chaning oil on my RS for 2 years now, so I have experience. Usually I put 3.7 litres and after adding up bit by bit till FULL mark. But it takes too long, and also I get different readings all the time during that. Today i was doing that and ended up dumping whole 4 litres in there and it was just very little over NOTCH. Now, can I just drained it really good(30 min) and then put 4 litre(whole can)??? Will that work? That would save me so much time and hussle!! I also have Fumoto valve. Thanks guys!!!!!!
09-07-2003, 08:40 PM | #2 |
Member#: 10309
Vehicle:'02 OBS 2-tone! White |
Just leave a little behind when you pour -- guess where 3.9 or 3.8 liters would be, then you'll be OK. I wouldn't go higher than the notch.
09-07-2003, 09:27 PM | #3 |
Member#: 34
VIC
Vehicle:2005 WRX STi World Rally Blue |
yeah, I never get a full 4L into it. Did you fill the oil filter first too? My oil readings are crappy so it sucks. bleh.
09-07-2003, 10:18 PM | #4 |
Member#: 34028
Yeah prefilled filter and all.. Just checked right now after driving car for a while. It's like 6mm over the notch. Don't know if it's ok. Next time Must put in 3.8 or 3.9 litres.
09-07-2003, 10:25 PM | #5 |
Member#: 13110
I don't think you have to that accurate. As long as you have proper lubrication (not too little and not too much), you should be fine.
Similar Threads | ||||
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! | Unabomber | Service & Maintenance | 1079 | 08-29-2022 08:29 PM |
Change oil first or start than change oil | carpfish | Service & Maintenance | 5 | 03-23-2010 04:32 PM |
Oil Temp & Pressure Changes w/Different Oil Brand? | alpentalic | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 06-02-2009 05:28 PM |
change oil filter with every oil change? | BlackBeastie | Service & Maintenance | 1 | 03-15-2003 07:29 PM |
Warning to those who change their own oil. Pls. Read. | Snoopy | General Forum Archive | 37 | 01-24-2001 10:37 AM |
