05-05-2005, 09:00 PM | #1 |
Member#: 78699
Funny Smell, Oil? or gas or something else?
hey bro's i just had an invidia DP installed this past week and noticed that my car smells a lot after i go WOT, didnt give it much thought because going catless will do that to you but today a plume of white smoke came through my A/C vent in the center console and it smelled funny, not like unburned gasoline, almost like an oil smell. I checked my oil and it was fine, also my oil pressure doesnt drop below 1.5 bar on the defi's. Any thoughts?? Also i dont think this will help but i am able to hit 1.3 bar on boost with my setup....
Car info: -2005 USDM STi, 7800miles -conventional 5w-30 oil -Injen limited intake converted to shortram(its now exactly the same as a typhoon i compared the 2) -Grounding kit -Invidia DP (just installed last weekend) -ported wastegate -Defi Link gauges - boost, oil pressure, egt. Thanks in advance....my first post is a problem hahaha
05-05-2005, 09:45 PM | #2 |
Member#: 51537
Vehicle:2004 WRB WRX STI 62 Corvette/11 Cherokee L |
dude, haha, that's what happens when you replace your cat with a catless downpipe, kind of a mild sulfur smell.
05-05-2005, 10:09 PM | #3 |
Member#: 78699
i can understand that smoke maybe coming from the exhaust pipe itself, but directly through the A/C vent that doesnt sound right. It only happened today, the smell i expected tho. Ill check my coolant now, but i dont think thats it........just had it topped of during the winter.
05-05-2005, 10:10 PM | #4 |
Member#: 64787
Vehicle:just got worse |
clutch?
nothing warms the heart like melted clutch and a Camaro in your rear view |
05-06-2005, 09:05 AM | #5 |
Member#: 78699
hahaha nah the clutch feels great, no slippage, grindage or any other bad dendancies a burnt out clutch would have. checked the coolant level and that is fine, also no white smoke from the exhaust pipe so i can rule out a coolant leak can i also rule out a blown/leaking head gasket?
05-06-2005, 12:21 PM | #6 |
Member#: 86576
Vehicle:2004 STi aspen white baby!!!!! |
did you check to see if anything is touching the DP? mine burnt the cowling drain tube and burned it enough to waft some smoke in through the A/C vents.
05-06-2005, 01:13 PM | #7 |
Member#: 78699
ahhhh i will check that now!!! that is a likely cause should have thought of that!
05-06-2005, 01:28 PM | #8 |
Member#: 51537
lol, yeah, mine has been cauterized...
05-06-2005, 04:48 PM | #9 |
Member#: 78699
yup thats it!! how do i fix it?
05-06-2005, 05:41 PM | #10 |
Member#: 51537
cut the rest of it off, drainage to downpipe.
05-06-2005, 06:02 PM | #11 |
Member#: 86576
damn big down pipes, i cut mine drain tube off about an inch above the DP. but then i wrapped it in some copper heat wrap.
05-12-2005, 07:18 PM | #12 |
Member#: 86417
subaru service bullitin
i have read in some forums that underneath the IC and above the passenger side fuel injectors is a type of fuel line half metal and half rubber that can go bad causeing a fuel smell in the cabin through the vents. i have tha problem and am waiting to get it fixed.
280zx? or spend on something else | Ruben_guy07 | Off-Topic | 18 | 03-25-2010 04:01 AM |
Is my power steering pump bad? or is it something else? | psychoskip | Brakes, Steering & Suspension | 11 | 01-25-2010 02:46 AM |
Is my alternator dead or is it something else? | Jus Blaze | Electrical & Lighting | 4 | 09-22-2008 10:09 AM |
Time for a VF39, or VF34 0r something else? I need opinions | NRTmotorsports | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 02-22-2007 10:08 PM |
Redline Oil or something else | WReX_rated | Bay Area Impreza Club Forum -- BAIC | 22 | 11-20-2002 11:18 AM |
