11-29-2005, 09:44 PM | #1 |
Member#: 19808
Vehicle:2005 WRX STI Obsidian Black Pearl |
BIG problems... check my logs..
Well it's only november and it looks like I'm really going to have to turn down boost as i'm maxing my injectors VERY easily now
However it seems like I won't be able to as I'll just creep back up... I'm running around 15psi at redline and my injectors are just maxed right out... Isn't this stock boost levels? how can this be safe with canadian winters... these logs were taken in -8 degree celcius... in Far. that's about 10 degrees i think. Here are 3 logs... Code:
Load Knock Mod Mod Mod RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF psia V % deg duty deg % (CL) V 3603 -9.4 3.2 90 10 0 37.7 31.5 24 0.5 310 3.2 3627 -6.5 3.5 98 10 0 27.8 42.2 24 0.5 310 3.6 3766 -2 3.9 97 20 0 14.7 59.6 20.2 0.3 310 4 3796 4.1 4.1 97 60 0 14.6 76.5 18.5 2.9 310 4.2 3963 9.2 4.2 97 80 0 19.1 74.2 17.7 2.6 350 4.2 4166 13.5 4.2 97 90 0 20.4 78.4 17.9 2.7 350 4.2 4251 16.4 4.3 97 100 0 20.7 87 18.4 3.2 350 4.4 4380 17.2 4.3 97 100 0 20.5 91.3 18.9 3.1 350 4.4 4486 17.4 4.3 97 90 0 20.8 92.6 19.5 2.6 350 4.4 4610 17.4 4.4 97 90 0 21.6 94.4 19.9 2.3 350 4.5 4734 17.4 4.4 97 90 0 22 95 20.4 1.7 350 4.5 4844 17.6 4.5 97 100 0 22.3 ---.- 20.5 1 330 4.5 5027 18 4.4 97 100 0 22.4 98.5 20.5 0.1 330 4.5 5042 17.6 4.5 97 90 0 22.2 97.3 21.2 -0.3 315 4.5 5216 17 4.5 97 80 0 22.6 ---.- 22 -0.3 315 4.5 5167 16.4 4.5 97 80 0 22.1 ---.- 22.2 0 290 4.5 5473 15.7 4.5 97 90 0 22.1 ---.- 22.7 0 290 4.5 5411 15.5 4.6 97 80 0 21.7 ---.- 23.1 0.5 250 4.6 5611 15.9 4.6 97 90 0 21.9 ---.- 23.2 0.2 250 4.5 5717 15.3 4.6 97 80 0 22.3 ---.- 23.4 0.3 210 4.6 5868 15.3 4.6 97 80 0 22.7 ---.- 23.6 0.3 210 4.6 5910 14.9 4.6 97 80 0 22.9 ---.- 23.8 0.3 210 4.6 6071 14.7 4.6 97 80 0 23.2 ---.- 24 0.2 180 4.6 6150 15.1 4.5 96 80 0 24.3 ---.- 25.2 0.2 180 4.6 6195 14.9 4.6 97 80 0 24.5 ---.- 25.8 0.2 180 4.6 6289 15.3 4.6 97 80 0 25.1 ---.- 26.2 0 165 4.6 6373 15.1 4.6 97 80 0 25.7 ---.- 26.5 -0.1 165 4.6 6422 15.1 4.6 97 80 0 26.6 ---.- 26.5 -0.2 165 4.6 6574 14.9 4.5 96 80 0 27.6 ---.- 27 -0.2 150 4.6 6640 14.5 4.6 97 80 0 28.6 ---.- 27.1 0 150 4.6 6720 13.9 4.6 97 70 0 29.3 ---.- 27.3 -0.6 150 4.6 6535 13.5 4.5 0 0 0 25.6 43.7 ECU. 0.4 150 2.6
11-29-2005, 09:45 PM | #2 |
Member#: 19808
Code:
Load Knock Mod Mod Mod RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF psia V % deg duty deg % (CL) V 2820 -8.9 2.9 64 10 0 15.9 22.6 25.4 1.8 256 3 2815 -5.9 3 96 10 0 25.6 26.7 25.1 1.7 340 3.1 2921 -2 3.2 98 20 0 19.6 30.8 19 1.3 340 3.4 3030 2.1 3.5 99 30 0 13.9 42.1 18 1.9 290 3.6 3138 5.1 3.7 99 50 0 12.5 49.2 17 2.5 290 3.8 3293 8.6 3.7 98 70 0 11.7 64.4 15.6 3.4 280 3.8 3415 11.3 3.8 98 80 0 11.7 63.3 15.1 3.8 280 3.9 3447 13.5 3.9 98 80 0 11.5 62.4 15.5 3.1 280 4 3667 14.3 4 99 80 0 11.6 67.4 15.5 2.7 310 4.1 3745 14.3 4 100 80 0 14 72.6 15.5 2.5 310 4.1 3818 14.7 4 98 80 0 16.2 74.7 16.7 2.5 310 4.1 3958 14.5 4.2 98 80 0 18.7 73.7 17.7 2.6 310 4.1 4120 15.1 4.1 98 80 0 20.5 77.4 18.3 2.6 350 4.2 4235 15.1 4.3 98 80 0 20.6 79.1 18.7 2.5 350 4.4 4351 15.3 4.3 97 90 0 20.8 86.8 18.9 2.6 350 4.4 4492 16.4 4.3 98 90 0 20.9 91.7 19.3 2.5 350 4.4 4591 17 4.3 97 100 0 21.4 95.8 19.9 2.7 350 4.5 4721 17.2 4.4 97 90 0 22 94.1 20.4 1.8 350 4.4 4830 17.6 4.4 99 90 0 22.5 100 20.7 0.5 330 4.5 4990 17.2 4.5 98 90 0 22.4 96.6 20.8 -0.1 315 4.4 5112 16.8 4.5 98 90 0 22.3 99.2 21.3 -0.3 315 4.5 5224 16.4 4.5 98 80 0 22.4 98.9 22 -0.5 315 4.5 5324 16.1 4.5 97 90 0 22.2 ---.- 22.2 0 290 4.5 5437 16.1 4.5 98 90 0 22.1 ---.- 22.7 -0.1 290 4.5 5537 16.1 4.5 97 90 0 21.7 ---.- 23 0.1 250 4.5 5621 15.9 4.5 90 80 0 21.9 ---.- 23.2 0.4 250 4.6 5868 15.5 4.6 96 80 0 22.1 ---.- 23.5 0.3 250 4.6 5920 15.5 4.6 96 80 0 22.8 ---.- 23.7 0.3 210 4.6 5899 15.1 4.6 97 80 0 23.1 ---.- 24.2 0.3 210 4.6 5973 14.9 4.6 97 80 0 23.3 ---.- 23.9 0.3 180 4.6 6127 14.9 4.6 97 80 0 24.2 ---.- 24.8 0.2 180 4.6 6150 14.3 4.6 97 80 0 24.7 ---.- 25.6 0.2 180 4.6 6265 13.9 4.6 96 70 0 25.3 ---.- 26 -0.7 165 4.6 6459 14.1 4.6 96 80 0 25.9 ---.- 26.7 -0.1 165 4.6 6472 13.9 4.6 97 80 0 26.6 ---.- 26.7 0 165 4.6 6720 14.1 4.6 96 80 0 27.5 ---.- 27.2 -0.2 150 4.6 6587 14.9 4.6 97 80 0 28.5 ---.- 27.3 -0.1 150 4.6 6872 15.3 4.6 97 90 1 29.3 ---.- 26.5 0.2 150 4.6 6844 15.1 4.6 97 80 1 30.8 ---.- 27.5 0.1 150 4.6 7032 15.1 4.6 97 80 0 31 ---.- 27.5 0.2 150 4.6 6973 14.5 4.5 41 80 0 31.1 ---.- 27.5 0.1 70 4.6 |
11-29-2005, 09:47 PM | #3 |
Member#: 19808
5th gear pull... EGT's were nearing 900 (about 890 or so) so I backed off before 7000
Also my winter tires were starting to make a pretty loud noise, lol... I'm very glad I did too... my injectors were static forever Code:
Load Knock Mod Mod Mod RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF psia V % deg duty deg % (CL) V 2683 -9.8 3 75 10 0 34 21.8 26 2.4 355 3 2761 -6.9 3 97 10 0 25.2 24 25.7 1.5 340 3 2812 -3.4 3.2 98 10 0 19.5 30.2 25.4 1.8 340 3.3 2810 0.8 3.4 99 30 0 15.5 37.7 18 2.5 340 3.5 2853 4.5 3.5 98 40 0 12 43.9 18 2.8 340 3.8 2973 7.6 3.7 98 60 0 11.2 54.1 16.5 3.7 340 3.9 3041 11 3.6 98 80 0 11.2 59.3 14.5 4.3 290 3.9 3095 13.9 3.6 97 90 0 11.4 54.4 14 4.4 290 3.7 3121 15.1 3.7 98 80 0 11.4 52.2 14.5 4.3 290 3.9 3159 15.5 3.9 98 80 0 11.5 59.5 14.5 4.3 290 4 3186 15.1 3.8 98 80 0 11.6 57.7 14.5 4.3 280 4 3271 14.3 3.8 98 80 0 11.6 60.1 14.7 3.9 280 4.1 3323 14.5 3.8 97 80 0 11.6 63.4 15 3.8 280 4 3384 14.3 3.9 99 80 0 11.6 59 15.2 3.6 280 3.9 3401 14.1 3.8 98 80 0 11.6 64 15.5 3.4 280 4 3475 14.3 3.9 97 80 0 11.5 67.7 15.5 2.5 310 4 3615 14.5 4 99 80 0 11.6 66.2 15.5 2.8 310 4.2 3663 14.9 4.1 98 80 0 11.7 68.8 15.5 2.7 310 4.2 3687 14.9 4.1 98 80 0 13 68.7 15.5 2.7 310 4.1 3766 15.3 4 98 80 0 14.2 68.2 15.5 2.4 310 4.2 3805 15.3 4 97 90 0 14.9 79.5 17 2.3 310 4.2 3880 15.5 4.2 99 80 0 16.6 73.4 16.5 2.4 310 4.1 3987 15.5 4 98 80 0 18.1 72.7 17.2 2.5 310 4.3 3982 15.3 4 100 80 0 18.9 73.9 17.7 2.6 350 4.2 4011 15.1 4.2 98 80 0 20.3 77.9 18.1 2.6 350 4.2 4079 15.7 4.2 98 90 0 20.4 78.6 17.9 2.7 350 4.3 4120 16.1 4.3 98 90 0 20.4 79.8 18 2.7 350 4.4 4240 16.6 4.2 97 90 0 20.5 82.4 18.2 2.7 350 4.3 4182 17 4.2 97 90 0 20.6 82.8 18.5 2.6 350 4.4 4351 16.8 4.3 98 90 0 20.7 88.1 18.6 2.6 350 4.4 4374 17.4 4.3 98 100 0 20.7 88.5 19 3.1 350 4.4 4409 17.4 4.3 98 100 0 20.7 90.8 19.2 3.1 350 4.4 4415 17.8 4.3 98 90 0 20.9 91.1 19.2 2.6 350 4.5 4510 18 4.3 97 100 0 21.1 97.7 19.7 2.9 350 4.5 4559 18.4 4.4 97 100 0 21.4 96.5 19.6 3.1 350 4.5 4675 18 4.4 97 100 0 21.7 96.3 20 2.5 350 4.5 4694 18.2 4.4 99 90 0 21.8 94.9 20.2 1.9 350 4.4 4662 17.8 4.4 98 100 0 22.1 ---.- 20.5 0.1 330 4.5 4816 17.2 4.4 97 90 0 22.4 99.8 20.5 1.5 330 4.4 4887 17.4 4.4 98 90 0 22.5 99.4 20.6 0.5 330 4.5 4873 16.8 4.5 97 90 0 19.1 ---.- 20.8 0.3 330 4.5 4909 16.6 4.5 97 90 0 19.1 98.4 20.9 -0.1 330 4.4 5073 15.9 4.5 97 80 0 19.1 97.6 22 -0.3 315 4.5 5058 15.9 4.5 97 80 0 19.2 98.7 22 -0.5 315 4.4 5112 15.9 4.5 98 90 0 19.2 ---.- 21.6 -0.3 315 4.5 5144 15.5 4.5 98 80 0 19.1 ---.- 22 -0.4 315 4.5 5208 15.9 4.5 97 80 0 19.1 ---.- 22 -0.4 315 4.5 5299 16.4 4.5 98 90 0 19.1 ---.- 22.2 0 290 4.5 5324 16.6 4.6 98 90 0 19.1 ---.- 22.2 -0.1 290 4.5 5367 17 4.6 99 90 0 19 ---.- 22.5 -0.1 290 4.5 5385 17 4.6 98 90 0 19.6 ---.- 22.6 -0.2 290 4.5 5420 15.9 4.5 97 80 0 19.6 ---.- 22.6 0.5 290 4.5 5583 15.9 4.6 98 80 0 19.6 ---.- 22.8 0.5 250 4.6 5574 15.5 4.5 98 90 0 19.6 ---.- 23.1 0.1 250 4.6 5574 15.9 4.6 98 90 0 19.6 ---.- 23.1 0.1 250 4.5 5659 16.6 4.6 98 90 0 19.6 ---.- 23.3 0.1 250 4.5 5583 16.6 4.6 97 90 0 20.2 ---.- 23.3 0.2 250 4.6 5678 16.1 4.6 98 80 0 19.6 ---.- 23.4 0.4 250 4.6 5688 15.3 4.6 98 80 0 20.1 ---.- 23.4 0.3 250 4.6 5787 14.7 4.6 98 80 0 20.7 ---.- 23.6 0.3 210 4.6 5889 14.7 4.6 99 80 0 21.6 ---.- 23.6 0.3 210 4.6 5807 14.7 4.6 98 80 0 21.9 ---.- 23.5 0.3 180 4.6 5910 15.1 4.6 97 80 0 22.4 ---.- 23.7 0.3 210 4.6 5910 15.1 4.6 98 80 0 22.4 ---.- 23.8 0.3 210 4.6 5995 14.9 4.6 98 80 0 22.7 ---.- 24 0.2 180 4.6 5910 15.9 4.6 98 90 0 22.8 ---.- 24.4 0.3 180 4.6 6038 16.4 4.6 98 100 0 22.9 ---.- 23.7 0.3 180 4.6 6093 17.2 4.6 98 100 0 23.7 ---.- 24.3 0.3 180 4.6 6105 17 4.6 97 90 0 24 ---.- 25.2 0.3 180 4.6 6116 16.1 4.6 99 80 0 24 ---.- 25.2 0.3 180 4.6 6253 15.7 4.6 98 80 0 24.4 ---.- 25 0.2 180 4.6 6138 14.9 4.6 97 80 0 24.8 ---.- 25.2 0.2 180 4.6 6195 14.9 4.6 99 80 0 24.9 ---.- 26 0 180 4.6 6422 15.1 4.6 99 80 0 25.1 ---.- 26.1 -0.1 165 4.6 6337 14.5 4.6 98 80 0 25.3 ---.- 26.1 0.1 165 4.6 6497 14.3 4.6 98 80 0 25.4 ---.- 26.2 0 165 4.6 6253 14.3 4.6 97 80 0 25.5 ---.- 26.3 0 165 4.6 6373 14.1 4.6 98 80 0 25.8 ---.- 26.4 0 165 4.6 6447 14.5 4.6 98 80 0 25.8 ---.- 26.6 0 165 4.6 6385 14.7 4.6 97 80 0 26.5 ---.- 26.8 0 165 4.6 6485 14.7 4.6 98 80 0 26.8 ---.- 26.6 0 150 4.6 6313 14.3 4.1 0 0 0 24.9 23.9 ECU. 0.4 80 2.3 |
11-29-2005, 09:54 PM | #4 |
Member#: 19808
I'm going to try and pull 50 more points from my boost map and hope boost will drop... but I have a feeling it won't
Would adding just a fuel pump win me back some IDC's? I think the only real problem here is fueling... running 11psi isn't possible due to creep and is just unreasonably low IMHO. Also boost creep or no? based on my boost map values. Last edited by RossWRX; 11-29-2005 at 10:52 PM. |
11-29-2005, 10:20 PM | #5 |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
Holy cow, you're pulling a LOT of voltage! I wish it got that cold here. It was 87F here today.
I'm amazed that you're maxing your injectors at 4.xK rpms! wow. I wonder what your AFR is, perhaps you have more room if you're running overly rich. |
11-29-2005, 10:40 PM | #6 |
Member#: 19808
yeah, car is FAST!!!
but no fun when you're worrying about if the engine is going to go boom. When I dyno'd it this summer... all A/F's were between 11.1:1 and 10.8:1 The crazy thing is that the above wasn't even on that cold of a day... once we get into december and january I don't know what I'll do. My boost numbers aren't obscene either... infact already lower than what I run in the summer without maxing my injectors. I expect to hit 4.7's, lol. |
11-30-2005, 01:10 AM | #7 |
Member#: 87446
NWIC
Vehicle:2005 STI 3 second start club |
Yea I started maxing mine out at 15-16 psi when the temp dropped to about 50* F here - w/ a walbro... Granted I was running pretty rich w/ the tXs stage 0 sti map at 10.4:1 range...
PE 850s took me back down to a reasonable mid 50% idcs tho so problem solved |
11-30-2005, 01:33 AM | #8 | |
Member#: 7327
NWIC
Vehicle:2008 Mazdaspeed3 2006 Wrangler Sport |
11-30-2005, 09:02 AM | #9 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
bump up fuel pressure.
one bar extra got me -10 on the IDCs. |
12-10-2005, 02:03 PM | #10 |
Member#: 19808
Do you think just changing the fuel pump will help?
I've heard rumours of this... in theory it shouldn't... but I've heard that pressure starts to fall near 100% IDC since the stock pump can't keep up. I just think that changing injectors and having to retune etc. is crazy with a stock turbo. Bah well guess i'll have to go 20g sooner than expected :P |
12-10-2005, 02:23 PM | #11 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
To see a difference worth it you need to bump the pressure. It might be a valid idea to try with just a pump...I'd be very interested in the results. Do you have a wideband?
12-10-2005, 05:09 PM | #12 |
Member#: 43151
South East
Vehicle:04 STI Kinda Silver-ish |
Dude, I'm runnin' 19psi on the stock injectors, and I'm only seeing high 80's IDC's at around 5.5k rpms. I shift then so I won't push it. I have a lot of fuel pulled since I'm running 100 octane, and I've increased the stock fuel pressure by 5psi. Your maf voltages are really high. Too high for 15psi. I only see 4.2 I would see 4.4-4.5 when I was running 23psi and stock modded injectors at 6.5k rpms. But it's not that cold here.
12-10-2005, 08:50 PM | #13 |
Member#: 7194
Vehicle:2011 997.2 Turbo Black |
I don't know if this makes you feel any better but I think what you are experiencing is the norm. (at least from the "stage 2" sti's ive seen)
I maxed out the injectors on the stock map. Even after heavy fuel tunning and bringing the AFR's into the mid 11's I still maxed out my injectors when I had a vf39. What made me less concerned about it was reading a bunch of threads on iwsti from Subaru of Gwinnett about his experiences and seeing the STI running reliably at 105%, 106%, etc.. duty cycle. The Utec stops reporting duty cycles at 100% and just report ---.--. Does that mean that it can't push anymore fuel? Well, I just don't know for a fact if that is the case but to me is seems like it can. I maxed out my injectors for nearly a year with very similar logs. (maybe not as early as you)... here is a sample: Code:
2099, -1.8,2.5, 21, 10, 00, +23.7, 13.3,ECU. , +0.0,ECU. ,2.5, 14.37 2143, -1.4,2.5, 20, 00, 00, +29.8, 11.5,ECU. , +0.0,ECU. ,2.5, 13.59 2145, -1.6,2.5, 20, 00, 00, +31.3, 11.6,ECU. , +0.0,ECU. ,2.5, 13.36 2203, -1.6,2.5, 20, 00, 00, +31.1, 12.7,ECU. , +0.0,ECU. ,2.6, 13.95 2213, -1.8,2.6, 20, 00, 00, +31.1, 14.6,ECU. , +0.0,ECU. ,2.6, 14.15 2259, -1.6,2.7, 27, 10, 00, +30.7, ---.-,+23.8, +4.9,ECU. ,3.0, 13.97 2331, -0.6,2.9, 31, 10, 00, +16.6, 21.7,+23.2, +4.9,300.00,3.0, 13.87 2387, +0.8,3.0,102, 20, 00, +13.0, 24.1,+17.2, +4.9,375.00,3.2, 13.23 2442, +2.9,3.2,103, 30, 00, +12.2, 27.7,+16.6, +4.9,375.00,3.3, 12.59 2540, +5.1,3.2,104, 40, 00, +11.2, 32.8,+16.0, +5.3,375.00,3.5, 12.45 2637, +7.0,3.4,104, 50, 00, +10.8, 36.4,+15.0, +4.0,375.00,3.6, 12.25 2670, +9.0,3.6,105, 60, 00, +10.3, 41.7,+15.0, +3.7,375.00,3.7, 11.96 2757,+11.5,3.8,103, 80, 00, +10.5, 46.4,+13.0, +3.9,375.00,4.0, 11.71 2911,+14.1,3.8,104, 90, 00, +10.5, 46.7,+12.5, +4.5,375.00,4.0, 11.48 3000,+16.6,4.1,104,100, 00, +10.8, 56.8,+11.5, +4.3,335.00,4.2, 11.05 3186,+17.8,3.8,104,100, 00, +11.3, 42.7,+11.5, +4.1,335.00,4.1, 10.89 3290,+18.0,3.9,104, 90, 00, +11.4, 61.6,+12.6, +3.5,335.00,4.2, 10.90 3404,+18.2,4.0,104, 90, 00, +11.4, 61.8,+13.2, +2.8,335.00,4.2, 10.65 3527,+17.8,4.0,104,100, 00, +11.4, 63.5,+12.5, +1.6,335.00,4.1, 10.52 3572,+17.6,4.0,103, 90, 00, +11.6, 69.7,+13.7, +1.7,335.00,4.0, 10.64 3736,+18.2,4.1,104,100, 00, +13.1, 68.7,+12.5, +0.8,335.00,4.1, 10.71 3809,+18.2,4.0,103,100, 00, +14.9, 71.0,+13.1, +0.7,335.00,4.2, 10.80 3972,+18.2,4.2,104,100, 00, +17.3, 70.8,+14.1, +0.7,335.00,4.1, 10.76 4035,+18.4,4.1,104,100, 00, +19.0, 75.1,+14.7, +0.9,335.00,4.2, 10.65 4140,+18.4,4.1,103,100, 00, +19.1, 75.5,+14.9, +1.2,335.00,4.2, 10.68 4235,+18.2,4.2,103,100, 00, +19.4, 79.5,+15.5, +1.7,335.00,4.3, 10.76 4357,+18.4,4.2,103,100, 00, +19.6, 84.7,+15.9, +2.1,335.00,4.4, 10.86 4450,+18.0,4.3,103, 90, 00, +19.6, 85.9,+17.2, +2.0,335.00,4.4, 10.86 4629,+17.4,4.4,103, 90, 00, +20.6, 92.2,+18.1, +1.7,335.00,4.5, 10.81 4782,+17.8,4.4,103,100, 00, +21.5, 92.1,+17.3, +1.4,335.00,4.4, 10.78 4810,+18.4,4.4,104,100, 00, +21.8, 97.3,+17.5, +0.7,335.00,4.4, 10.80 4990,+19.0,4.4,103,100, 00, +22.0, 97.2,+17.5, +0.0,335.00,4.5, 10.78 5136,+19.0,4.5,103, 90, 00, +20.4, 99.1,+21.0, +0.0,335.00,4.5, 10.90 5159,+19.4,4.5,103,100, 00, +20.7, ---.-,+18.0, +0.6,335.00,4.5, 11.08 5282,+19.2,4.5,103,100, 00, +20.8, ---.-,+18.7, +0.9,335.00,4.6, 11.12 5473,+19.0,4.5,104,100, 00, +20.5, ---.-,+19.1, +0.5,335.00,4.5, 11.20 5592,+19.4,4.5,103,100, 00, +20.3, ---.-,+19.5, +0.1,335.00,4.5, 11.30 5630,+18.0,4.5,103, 90, 00, +20.2, ---.-,+21.0, -0.7,335.00,4.5, 11.33 5688,+17.2,4.6,103, 90, 00, +20.7, ---.-,+21.0, -0.7,335.00,4.5, 11.34 5847,+16.8,4.5,103, 90, 00, +17.5, ---.-,+21.6, -0.8,335.00,4.5, 11.37 5899,+16.1,4.6,104, 90, 00, +18.4, ---.-,+21.7, -0.8,335.00,4.5, 11.45 6082,+15.9,4.6,104, 80, 00, +18.4, ---.-,+22.4, -0.8,335.00,4.6, 11.30 6093,+15.9,4.6,104, 80, 00, +19.1, ---.-,+22.6, -0.1,335.00,4.5, 11.28 6161,+15.9,4.6,104, 90, 00, +19.5, ---.-,+23.4, -0.3,335.00,4.5, 11.43 6277,+16.4,4.6,104, 90, 00, +20.4, ---.-,+24.1, +0.0,335.00,4.6, 11.43 6385,+16.6,4.6,104, 90, 00, +21.2, ---.-,+24.5, +0.0,335.00,4.6, 11.45 6485,+17.0,4.6,104, 90, 00, +22.1, ---.-,+24.7, +0.0,335.00,4.6, 11.45 6497,+17.0,4.6,104, 90, 00, +22.8, ---.-,+25.0, +0.1,335.00,4.6, 11.52 6613,+16.1,4.6,103, 80, 00, +23.7, ---.-,+25.4, +0.5,335.00,4.6, 11.52 6666,+15.7,4.6,103, 80, 00, +25.7, ---.-,+25.9, +0.7,335.00,4.6, 11.48 6802,+14.9,4.6,104, 80, 00, +26.9, ---.-,+26.2, +0.7,335.00,4.6, 11.52 6973,+14.1,4.6,103, 80, 00, +27.6, ---.-,+26.4, +0.5,335.00,4.6, 11.53 7230,+14.3,4.6, 16, 00, 00, +28.1, 79.0,ECU. , +0.5,ECU. ,3.9, 11.49 |
12-10-2005, 08:51 PM | #14 | |
Member#: 7194
12-10-2005, 09:31 PM | #15 | |
Member#: 19808
Yeah, i've heard rumours that the ECU reports static at actual 95% IDC's... since in their opinion anything above 95% is too dangerous I guess... this was based on someone who was able to tune more fuel in even when IDC's were over 100%.
Also in the summer when they'd go static I didn't have a problem A/F's would stay decently in check when I had the WB installed as would EGT and knock. Now that it's cold however I'm for sure running lean EGT's shoot up above 5750 close to 900c and I've seen the CEL flash closer to 6500 a couple times. I've tried pulling boost but I just can't get under 15.5psi or so above 5500rpm-7000rpm... creeping I guess. If I had the fuel it wouldnt be a problem... infact it would be alot of fun However I'm hesitant of running a AFPR... as i'll have to retune my entire map and will probably still be maxing my injectors (although at richer AFR) and maxing injectors at a higher than stock fuel pressure spells injector failure to me. If anything I'll go new injectors, some decently priced ones are now out for the STi, then I'll have to get a new turbo at some point since i'll have all supporting mods I need something to tune for again, lol... I enjoy tuning this car "almost" as much as driving it. Also Aaron I follow your posts alot on wrxhackers, I noticed that you bought a SZ55 turbo, congrats... I'm sure you're having a blast with it, lol. Maybe I misread your post but did you have a 20g before? If so is it for sale, I'm in the market for one after all the above, lol. Any suggestions on my map until I perform fueling mods or turbo port or upgrade? Quote:
12-11-2005, 07:15 AM | #16 | |
Member#: 43151
South East
Didn't notice this was an Sti thread. |
12-11-2005, 11:43 AM | #17 |
Member#: 79498
SWIC
Vehicle:2020 XV |
What are you using to log? I've heard of somebody hitting 113% IDC with the Tari logger on an STi. I guess 100% isn't static with the Tari.
12-11-2005, 12:39 PM | #18 |
Member#: 19808
Well i'm definately going lean based on my EGT's... also considering i'm static from 4750 on up, i'm sure my IDC's are actually more like 115%-120% since boost is staying the same right up to redline.
I'm using utec logger 4 |
12-11-2005, 10:46 PM | #19 | |
Member#: 21980
NESIC
12-12-2005, 07:07 AM | #20 |
Member#: 32792
NESIC
when in doubt, i'd trust the utec.
jm2c ken |
please check my logs! | mystilexzero | Open Source Reflashes | 22 | 11-18-2011 12:39 PM |
07 STi w/ tuned Enginuity... fuel learning / running rich? please check my logs... | TROLL | Commercial ECU Reflashes | 26 | 11-21-2007 01:51 AM |
Can someone check my logs? | CarterMarkham | Commercial ECU Reflashes | 11 | 11-12-2007 12:19 PM |
Please Check My Logs | clemsonteg | UTEC | 4 | 08-28-2007 06:30 PM |
Please check my logs from today | MidRex | UTEC | 15 | 04-14-2006 10:38 PM |
