Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Mid Atlantic Impreza Club
Old 08-01-2017, 02:57 PM   #1
messinger
Member#: 331311
2008 wrx sedan
psm
Default 08 wrx random start
I have a 2008 wrx manual and randomly it won't start. Sometimes it runs fine but randomly at any time of day and cold or warm engine it will crank but not start. No CEL
Things I've replaced
Starter
Battery
Imobilizer and reflash
Spark plugs
Diagnostic test ran and found no faults
messinger is offline   Reply With Quote
Old 08-02-2017, 11:33 PM   #2
onsit
Member#: 292225
08 WRX (16g)
Seems you have ruled out the mechanical aspect of cranking, along with the spark aspect, next would be fuel related.
Put your keys in the igniton, and cycle them to the position II. You will need to lift off the back seats, have someone put their ear to the passenger side seat metal.
You should hear/feel vibrations of the fuel pump priming the system. Might be on it's way out if maybe it isn't priming the lines enough to get the car started.
Another option would be to pull the feed line off the rail, and hook it up to a pressure tester and see how consistent your pressure is going into the rails. Stock fuel pump should be around ~40psi.
onsit is offline   Reply With Quote
Old 08-03-2017, 10:44 PM   #3
messinger
Member#: 331311
2008 wrx sedan
psm
So I've done the listening thing and it hums every time but maybe I'll try testing it
Old 08-06-2017, 10:03 PM   #4
messinger
Member#: 331311
2008 wrx sedan
psm
Bump started this morning now won't restart again
Old 08-06-2017, 10:10 PM   #5
kmfdm86
Member#: 470116
2018 WRX
World Rally Blue
Sorry if I'm missing something obvious here (not exactly a mechanic, personally lol). Did you check the alternator?
kmfdm86 is offline   Reply With Quote
Old 08-06-2017, 10:17 PM   #6
onsit
Member#: 292225
08 WRX (16g)
Sounds like it's not fuel related if you have to bump start it.
You got some gremlins in there.
Old 08-10-2017, 10:12 PM   #7
messinger
Member#: 331311
2008 wrx sedan
psm
Still no start as of today but still have power
Old 08-11-2017, 10:41 AM   #8
dr4zz
Member#: 426326
2008 Impreza WRX
Dark Grey Metallic
Just a shot in the dark here but did you replace/check the basics before replacing the starter? Starter relay? Check positive cable from battery to starter for possible corrosion and clean connections?
dr4zz is offline   Reply With Quote
Old 08-11-2017, 10:45 AM   #9
dr4zz
Member#: 426326
2008 Impreza WRX
Dark Grey Metallic
You could monitor fuel pressure. I had some bad issues with my positive cables corroding on my 08 though when I first got it. If there isn't a strong enough current the rod may not be pushing out far enough to turn it over.
Old 08-12-2017, 09:01 AM   #10
KAT_Ayanami
Member#: 155017
2000 2.5RS
Blue Ridge Pearl
He said crank but no start..... So the starter sounds fine....
I do not know if a single coil giving you issues would not allow the car to at least start. But I would check that route. Check the coil pack system.
KAT_Ayanami is offline   Reply With Quote
Old 08-12-2017, 01:35 PM   #11
onsit
Member#: 292225
08 WRX (16g)
MAF might have been damaged while cleaning?
Unplug the MAF from the intake, and trying turning it over. It should allow the car to be in a limp state - it should turn over almost immediately and start doing fueling calculations based on the MAP.
Old 08-12-2017, 07:23 PM   #12
messinger
Member#: 331311
2008 wrx sedan
psm
Car started today drove it 15 miles not one problem at all
Old 08-13-2017, 10:22 AM   #13
DavC825
Member#: 201736
12 IS-F..its white
Slowest 07 STi
Part out.
DavC825 is offline   Reply With Quote
Old 09-10-2017, 03:14 PM   #14
messinger
Member#: 331311
2008 wrx sedan
psm
Alright I've change fuel pump, new battery (I got a bad battery that wouldn't hold a charge), and new Alternator. Drove the car multiple days, most was 150 yesterday, stopping and restarting the car multiple times. This morning I go out and same problem again will crank but no start.
Old 09-12-2017, 02:46 PM   #15
messinger
Member#: 331311
2008 wrx sedan
psm
Replaced crank sensor problem still occurs
