05-15-2003, 01:03 AM | #1 |
Member#: 20413
Vehicle:2002 WRX+HKS Sliver |
avc-r not wrking~~~
aiite... I check everything for my wiring, the technician who help me to install the avc-r even call apexi tech. support to make sure those wire hook up rite! is it possible to hook everything up rite and the head unit couldn't read the speed signal?????
pls help, I m really frustrated! Ed
05-15-2003, 09:30 AM | #2 |
Member#: 7922
Vehicle:04 CTS-V b/b/b 99 GMC Highrider |
Are you sure you used the right pinout from the ECU for the speed signal? Also is your speed signal calibrated for 4 pulses?
Oh, and don't cross post, it's just bad form. |
Directions how to install AVCS heads in a non AVCS car and not use AVCS | sgiord86 | Built Motor Discussion | 1 | 11-19-2009 04:31 PM |
AVCS or Not??? | kappathirteen | Built Motor Discussion | 1 | 03-25-2009 10:53 PM |
AVCS not hooked up causes rough idle? | Need4Boost | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 02-09-2004 01:44 PM |
AVC-R is not working rite!!!! | Heel&Toe | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 05-15-2003 10:23 AM |
Unhooking the battery to reset ECU will not lose your APEXi S-AFC or AVC-R settings | kenshiro | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 05-23-2002 02:41 AM |
