Welcome to the North American Subaru Impreza Owners Club Thursday September 19, 2019
Old 03-16-2015, 01:28 PM   #1
kaos200
Member#: 2692
Default DBW Swap Pedal Adapter
Hey guys, wanted to share something with you. Swapped one of my cars (well, made it more of a factory swap I should say) and I know there are limited options for properly mounting the Drive by Wire pedals onto a GC/GF chassis. So we came up with this!
It's quite nice if I say so myself. Mounts solid, and heel/toe action is great with the placement we have. It is made to fit either version of the drive-by-wire pedals, the metal bracket version (shown) or the plastic one found on later models.
Printed proto on the left, final aluminum model on the right.
What are your thoughts? (other than the obvious, "hey should have done this years ago!" )
I can't discuss pricing/etc. since I am not a vendor, but these are now being sold by a VERY reputable swap-related shop here in Southern California. I'll let them advertise in the appropriate manner.
kaos200 is offline   Reply With Quote
Old 03-16-2015, 02:19 PM   #2
vicious_fishes
Member#: 158864
2003 SOHC destroker
i'd be interested in one of these if my legacy pedal doesn't fit my GD. how much would you be selling them for?
Old 03-16-2015, 02:33 PM   #3
kaos200
Member#: 2692
If I am reading your post correctly, you have a GD chassis and are putting another pedal into it? These ones were made for GC/GF chassis with GD pedals.
PM for vendor/payment info. I don't want to turn this into a FS post per forum rules
Old 03-25-2015, 04:31 PM   #4
kaos200
Member#: 2692
bump! Hope this can come in handy for some swap folks. I know it's a lot safer than what I've seen people running, and a lot easier than other options like cutting/welding brackets and firewall pieces.
Old 04-01-2015, 12:08 PM   #5
yebokmj
Member#: 2213
1995 Impreza w/EJ257
Brilliant Red
If the vehicle is cable throttle fore example MY02-MY05 WRX then an adapter is still needed. Subaru makes one bracket from a Baja, Subaru P/N: 36020AE130. It would be interesting to see how fitment differed.
yebokmj is offline   Reply With Quote
Old 04-01-2015, 12:28 PM   #6
kaos200
Member#: 2692
Actually part of the reason we made these was because apparently the factory one is no longer available.
The other, being that pedal placement wasn't the best. This one really does feel great (heel/toe spacing). But we'll leave that to the end users to judge.
The number of swaps I've seen where the owner was driving around with some make shift setup or just one bolt being used.... is scary. I wouldn't want my pedals going anywhere!
Old 04-01-2015, 05:59 PM   #7
yebokmj
Member#: 2213
Brilliant Red
That's good info, that's why I wondered how the fitment would differ.
Old 04-13-2015, 02:05 PM   #8
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
These guys make one also:
www.eastcoastswappers.com
Old 04-13-2015, 02:27 PM   #9
kaos200
Member#: 2692
Yes, thank you for sharing.
There is pepsi and there is coke, to each their own
The one I have shown above is also considerably cheaper, and again was designed with pedal placement in mind as well as adapting the pedal over.
Old 04-13-2015, 09:49 PM   #10
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
I meant no disrespect. Just spreading the word. Its been a hard road trying to find a solution for a small niche. But as you bring out the popularity will grow because the 2.0 is only becoming less and less available.
Old 04-14-2015, 11:35 PM   #11
kaos200
Member#: 2692
Haha it's fine
And, there could be more niche goodies to come
Old 04-15-2015, 07:08 AM   #12
25rsti
Member#: 166324
I wish something was around for me a couple years ago.
I swapped my entire car (dbc bugeye) into an 04 STi (dbw) and ran into the pedal issue.
I ended up drilling out the spot welds on both pedal brackets and welded in the dbc one on the STi.
25rsti is offline   Reply With Quote
Old 04-20-2015, 03:41 PM   #13
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
Which shop/vendor is selling these?
MannyMohawk#5 is offline   Reply With Quote
Old 04-21-2015, 02:44 AM   #14
kaos200
Member#: 2692
Exactly what this piece would make people avoid having to do!
contact Brian at iWire!
Old 04-23-2015, 04:45 PM   #15
MannyMohawk#5
Member#: 98807
1999 RSTi
RHD BF5 & BJ6
Old 04-23-2015, 05:23 PM   #16
kaos200
Member#: 2692
No problem
I have a couple extra pieces from overrun (just in case) but once those are gone iWire will be the only place that has these in stock. Brian is the guy everyone should trust with their swap needs anyway!
Old 01-01-2018, 01:48 PM   #17
SubieMonster69
Member#: 475282
Originally Posted by kaos200 View Post
No problem
bumping an old thread, got my bracket from iWire and it fits perfect!
https://www.iwireservices.com/produc...dapter-bracket
SubieMonster69 is offline   Reply With Quote
Old 07-15-2019, 09:03 PM   #18
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I want to adapt mine, but want to maintain the original position. An "improved" position for "heel to toe" action is not required on my car. I may attempt building one from some steel plate, similar to the unavailable oem type.
