Welcome to the North American Subaru Impreza Owners Club Monday September 28, 2020
Old 08-14-2019, 09:02 PM   #1
Steve Gingras
Member#: 18695
1994 2.5RS
Electric Yellow
Default Delicious Tuning / Lambda Tuning OBD2 Tuners
Does anyone have experience with either the Project Lambda OBD2 Tuner or the Delicious Tuning SSM? I am building a 94 Impreza NA Rally car and using a 2000 Forester Engine, Trans, Wiring Harness and ECU. We are looking to reflash the ECU to take advantage of the mods we have done. These 2 solutions look to be good options but I have not seen anyone talking about them so I am looking for any type of feedback. Do they work, are they easy to use, what kind of issues have been seen really anything?
Also, the Delicious Tuning is a fixed stage map while the Lambda needs to be tuned specifically for the car which will require about 10 data runs and downloads. The Lambda tune is probably a little better but the 2 weeks to do 10 runs/reloads could be an issue. So what is the difference between the two?
Any feedback or guidance would be welcomed.
Steve
Steve Gingras is offline   Reply With Quote
Old 08-19-2019, 11:12 PM   #2
Steve Gingras
Member#: 18695
1994 2.5RS
Electric Yellow
Wow hasn't anyone used either of these ECU Reflash methods?
Old 08-20-2019, 12:14 PM   #3
eustacer
Member#: 416465
2009 Impreza 2.5i
Not sure if you have looked into opensource tuning with a tactrix. There may be maps available for that engine on romraiders forums. That is all the experience i have with tuning
eustacer is offline   Reply With Quote
Old 08-20-2019, 12:52 PM   #4
tipsymechanic
Member#: 505361
2008 Legacy 2.5i
Romraider starts with 2005 for NA cars, unfortunately..
OP.. you may have better luck on rs25 forums
tipsymechanic is offline   Reply With Quote
Old 08-20-2019, 07:04 PM   #5
nvmylh
Member#: 243490
I'm using project lambda and with the live tuning feature it shouldn't take longer than any other ecu system to tune. I don't know anything about how the delicious system works though.
I just changed from stock 280cc to 560cc injectors in my ej251, and so far it has handled the change really well. Also running a 3bar map sensor, delta 1500 cams can about to turbo it.
The only thing i wish project lambda did was provide more info on what each feature really does (or how the software really works). Even if they sold some sort of write up on how it all works, I'd be happy to pay for it!
Some more updates or news would be good too, something like big round gauges that can easily be red on screen would be nice while datalogging.
https://www.rs25.com/forums/f105/t22...ce-thread.html
nvmylh is offline   Reply With Quote
