Welcome to the North American Subaru Impreza Owners Club Tuesday April 24, 2018
Old 04-11-2018, 06:09 PM   #151
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Originally Posted by 3mlwhly View Post
Sweet. I look forward to seeing more pics.
Just waiting to get everything reassembled back in the car to transport it back to my house and I'll set everything in it and take some snaps
Saabaru375 is offline   Reply With Quote
Old 04-16-2018, 10:06 AM   #152
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Old 04-16-2018, 10:23 AM   #153
standardtranny
Member#: 450713
2017 WRX Stage 2
world rally blue
Much wow! I'm sure it goes like stink
standardtranny is online now   Reply With Quote
Old 04-16-2018, 11:23 AM   #154
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
I wish I didn't have to post links. I can't get these pictures to work on this app.
Old 04-16-2018, 10:04 PM   #155
3mlwhly
Member#: 217648
Nice!!! Looks good.
Yeah I have to use my Imgur and my laptop to post pictures with out a link.
3mlwhly is online now   Reply With Quote
Old 04-17-2018, 07:41 AM   #156
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Old 04-17-2018, 10:31 AM   #157
3mlwhly
Member#: 217648
Yeah! That’s what I wanted to see. I was originally going to do that with my crossmember but I was worried it wouldn’t come out right. But I was wrong because yours looks good . I wound up building mine out of tubing.
Old 04-17-2018, 10:57 AM   #158
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Thanks. I wish I could have gotten a TSSFAB kit, but by doing it ourselves, and by that I mean have a local friend fabricate it, we were able to place the motor what we wanted it so we could do other things like fit it under the hood and have firewall clearance for the clutch master cylinder etc... Still probably going to need to lengthen the inner tie rods, and also shorten our shift linkage arms since we have a 07 cts v t56 instead of the typical gto or f body t56 trans.
Old 04-17-2018, 10:59 AM   #159
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Might be a odd question, but does anyone know if a 2015 wrx/ sti clutch master will work on later model 05-07 wrx/ Sti? Noticed they do not have the reservoir tank attached. Might work well. But probably will go with a Tilton
Old 04-17-2018, 02:35 PM   #160
3mlwhly
Member#: 217648
Yeah I have a gto trans and switched to a f body shifter. Ctsv with be way farther than stock subaru.
Old 04-17-2018, 02:42 PM   #161
3mlwhly
Member#: 217648
Default LS turbo Saabaru project.
You should probably look into doing a roll correction (lower tie rod pivot joint) for the tie rods instead of just getting longer ones. If you don’t you will surely wind up with bump steer.
Old 04-17-2018, 03:03 PM   #162
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
I have the Whiteline bump steer kit. Do they make different inner tie rods or something bolt on?
Old 04-17-2018, 05:57 PM   #163
3mlwhly
Member#: 217648
Yeah actually, most of us RWD guys run a mustang or a 240sx kit. They are bolt ons to a subaru. I’m planning to fabricate a drop mount on mine and relocate the mounting point at the same time for more angle which is common on drift Subaru’s.
Old 04-17-2018, 06:17 PM   #164
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Hmm. I need part #'s for those components. I hate dealing with the steering rack ****.
Old 04-17-2018, 10:43 PM   #165
3mlwhly
Member#: 217648
Haha. I’ll see if I can dig them u for you.
Old 04-17-2018, 10:47 PM   #166
3mlwhly
Member#: 217648
https://www.summitracing.com/parts/QA1-BAX104
This is the main one I know a lot of people run. Verify threads first though before you buy but I know it fits the taper of the ball joint.
Old 04-18-2018, 06:15 AM   #167
Saabaru375
Member#: 304385
2005 Saabaru Hybrid
white gator
Nice! And these are longer than the whiteline kit?
Old 04-18-2018, 11:44 AM   #168
3mlwhly
Member#: 217648
I don’t want to give you bad advice if there not, so..... me no know. Haha. They do have more room for correction though and are adjustable to tune for your set up.
