06-21-2018, 11:58 AM | #1 |
Member#: 479833
Catch Can Routing Confirmation
Quite a few ways to route this, but anyone confirm if this is correct catch can config or at least the most "popular?" Dont mind the crude drawing I had to do in paint lol. Just wanted to double check some things. Intake is capped off.
06-21-2018, 12:19 PM | #2 |
Member#: 215109
South East
Vehicle:2014 WRX-STi 5-Door Plasma Blue |
That's about right, except for the Drain.
All of the AOS diagrams have the drain T'd into the "Deleted PCV on crank case" So that it blows oil out of the vent into the can, then when you're off the throttle and there is a vacuum on this line it literally sucks the oil out of the AOS\catchcan and back into the crankcase. Instead of having the vent to atmosphere you can run that back around to the turbo inlet if you wanted to be exactly correct per the instructions. |
06-21-2018, 12:24 PM | #3 | |
Member#: 479833
06-21-2018, 12:34 PM | #4 |
Member#: 215109
South East
So... I tried doing something like this...
If you are doing any sort of motorsports, track day, mountain run, etc. I would discourage using a catch can period on a Subaru. Here's why... So apparently if you are changing directions a lot, causing a lot of G-Force that oil is going to slush right into the head in which the force is pushing it toward. That's then going to get blown right into the catch can... The can is then going to fill up almost instantly. I filled up a small can in 1 60 second autox run. If you are vent to atmosphere you're going to cause a huge oil spill and possibly a fire depending on where you have your can mounted. If its vented to the turbo inlet... *queue james bond theme* huge oil smoke fest. (this is what happened to me, I was referred to as the mosquito fogger all weekend). I am still trying to get all the oil out of my damn exhaust... Went through a healthy amount of oil as well... My adventure started when my PCV valve took a crap on me and caused a vacuum leak \ oil blow through fest because of the bum PCV. This bought gave me a heart attack... I would wait till you can install install the IAG as long as your PCV valve is working right. |
06-21-2018, 01:34 PM | #5 | |||
Member#: 375462
Vehicle:2006 Impreza WRX STI WR Blue |
Also, your design should use an effective baffle system within the catch can, use fairly long hoses, and the can itself should be positioned high on the firewall, if you can manage it. All of these details will lessen the amount of oil that gets blown through the filter and all over your engine bay. An even better solution is to run the filter at the end of a hose down a rocker panel - very easy to do with a small grommet on the firewall (into the wiper motor area). Quote:
06-21-2018, 01:37 PM | #6 | |
Member#: 479833
Except that I have a forged motor so I expect blowby being trapped in the can. |
06-21-2018, 01:39 PM | #7 | |
Member#: 215109
South East
If they were truly baffled fresh air ports then there wouldn't be a need for a catch can or AOS system... Do you have a picture for reference? |
06-21-2018, 01:42 PM | #8 | |
Member#: 479833
They are there but not entirely efficient at doing its job hence why even stock, thesr motors produce larger amounts of blowby than other turbo 4 cylinder cars. |
06-21-2018, 01:55 PM | #9 | |
Member#: 215109
South East
I know 2 different cars that overpowered the Crawford AOS by filling the sucker up in a single autox run... Hoosiers = lots of force throwing the oil to the heads = more oil than there is supposed to be coming through the crankcase vents -> catch can fills up. |
06-21-2018, 06:49 PM | #10 | ||
Member#: 375462
The PCV (fresh air) ports are internally baffled - the unbaffled ports are balance ports. Balance ports are most common on motors with a large distance between heads, such as a boxer motor. PCV ports being baffled is common to literally every motor made since the closed venting requirement laws were enacted... so literally decades. Look at the underside of any rocker cover on any motor made in the last 20 years or so. This is why I think it's funny that people think Subaru just 'forgot' to put an air-oil-separation system... it's in there, and it works quite well. What do you think that labyrinthian plate is behind the clutch? That's also part of the separation system. The purpose of a catch can is to collect condensed oil vapor when the (legally required) sealed system is changed to a vented system by the end user rather than just venting it freely. For what it's worth, venting freely works GREAT as well, but it's certainly not the most environmentally friendly solution, and it is completely illegal in many racing regulations. The purpose of an AOS (for most people) is to sell you a catch can for 5 times more money. Any catch can that promotes the condensation of oil vapor can technically be considered an air-oil separator and even an empty 1 liter soda bottle causes the vapor to travel some distance, giving the oil particles more time to fall out of suspension. See where I'm going here? Catch cans and AOS are one in the same. The product name 'air-oil separators' originated from people buying air compressor water traps (also called air-oil separators) and installing them inline between motors and catch cans to enhance oil separation. Honda guys did a lot of this in the early-90's. For the small minority that have outpaced the OEM PCV and oil separation system, the purpose of the AOS (i.e. catch can with genuine oil separation features) is to enhance the venting and oil separation capacity of the motor. Raise your redline? You almost certainly need one. Raise your boost? You *might* need one. Run an excessively loose motor? Find a better builder next time (also, you might need an AOS). A drain-back system is a feature of either a catch can or AOS - it does not define either. To me, this is a band-aid for poor decisions - if you are losing so much oil you need to recirculate the lost oil to the motor for what you're using it for, you're either running a racing motor on the street or you have worn parts or terrible clearances. Given a normal ~0.5-1.0 qt. drop between changes, a drain-back system also encourages you to be lazy with oil changes. This is particularly bad news on a turbocharged Subaru as the geometry requires extra fuel for charge cooling under boost. Richer charges = faster oil dilution and diluted oil = ineffective lubrication. If there's one thing that Subaru owners enjoy more than complaining about bearing failures in EJ motors it would probably be neglecting normal maintenance schedules. Draw your own conclusions there. As a side note, any time you're racing, you're running pig rich the entire time. This is why an oil change after a track day is always a GREAT idea. Second side note - if you're one of the few who think you need to run racing oils on the street (Motul 300V, etc.) you've also introduced time as a big factor in oil change scheduling. Racing oils only last a few months in a motor before they break down. Quote:
There is nothing magical about Subaru motors - they're subject to the same emissions laws as everyone else. Now, what 'The Duke' is likely seeing is an oil pan that does not have effective baffling for the driving he is doing (the Hoosier comment changed my thinking here - it's hard to tell how serious someone is about AutoX until you start talking tires). The PCV ports are baffled to promote the condensation of oil vapor... not to stop liquid oil. In his case, improved pan baffling with one-way doors will be a BIG help. You don't need to go and buy a $1000 pan - most of those are overkill (do you *really* think you need to jack up your entire car by the oil pan? Yeah, me neither). Search out some baffling designs online and find a good welder - you could probably fab up about 20 designs using the OEM pan and sheet metal before the cost added up to the price of aftermarket cast or welded pans. Now you mention someone 'overpowered' an AOS... well, no... they didn't. Sounds like they had a stock oil pan. Maybe you can comment on this? Last edited by mrsaturn7085; 06-21-2018 at 06:54 PM. |
06-21-2018, 05:03 PM | #11 | |
Member#: 479833
06-22-2018, 12:37 AM | #12 |
Member#: 468393
Vehicle:2017 STI |
I learned the hard way that inadequate line size off the heads combined into a T going to one VTA filter is not large enough to handle long sweeping turns at high speeds. VTA or or catch can, make sure you use large enough hose to handle a the possible oil loss. This was with only the high load head lines..... The low load pcv was connected as normal.
06-22-2018, 07:48 PM | #13 |
Member#: 479833
I got it all set up. Instead of the Y for the front most valve cover ports, I used a T meeting in the middle and routed to the top port of the can with equal length lines at all 3 junctions. The original PCV location crankcase breather needed another 90 straight off the port to clear the compressor turbo inlet, but other than those two changes it's set up. Did a few hard pulls and drove to/from work (~80 miles total) and drained it when I got home which was less than .5 ounce. Will keep an eye on it. My hesitation is with the T junction is restricting flow vs a Y but for crankcase I don't think it matters (I may be overthinking this one because OEM uses a T). May run a line and put the breather on the line on top breather port so it doesn't make a mess in the engine bay and just route it somewhere towards the ground or something.
