Welcome to the North American Subaru Impreza Owners Club Tuesday November 28, 2023
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Closed Thread
Old 05-15-2023, 06:57 PM   #1
danverco
Member Sales Rating: (6)
Member#: 156015
2001 GM6 STi swap
Default CO Subaru Impreza 2 door coupe, GM6 "Sti WRX Race Car" swapped and built
Subaru Impreza 2 door coupe, GM6, RS Sti WRX Race Car, swap and built
Links to youtube engine cold start up and rev
Subaru Impreza 2 door coupe, JDM, GM6 (GC8) Sti WRX Race Car, swap and built
-see trade considerations below
-also willing to sell chassis alone
#1 There is no rust anywhere on the frame or body, it has always been stored in a garage and rarely sees the light of day. I have never driven it in the rain or snow. It was primer before I owned the car, looks to have had some minor body work. I have a clean title in hand and has not been in any accidents or wrecks on my watch and the unibody frame is straight.
Looks like a 1998 -2001 with the hood, headlights, grill and bumper. The CLEAN Colorado title says 1996.
actual miles on chassis are unknown, engine has ~75miles and the trans likely has 40-60k, its JDM import (I am the first US owner of the drive train) and it shifts perfect. OEM Subaru Extra-S trans fluid in it.
I have over ~25k$ in this car, I am only looking to get 17.5K$ if parted out you'd make more than that.
-Build list below-
--contact Dan, seven two zero 3944141--
Story:
Many hours labor and lots of money went into it, my loss your gain...
I would consider a part out, selling just the caged chassis alone for $3500
During a part out the caged chassis would have to go first or together before any parts are sold separately.
Certain trades will be considered. See a list of trade options at the bottom.
Currently set up for Rally dirt gravel racing or possibly Colorado hill climb CHCA or rally cross but could be reconfigured for: Autocross, tarmac racing, High Plains Raceway, drag racing or whatever you like possibly back to a street car.
I raced it in Colorado Rallycross SCCA a couple times and in the Tumbleweed Rally many years ago where I blew up the original EJ22 engine during the race. Since then I had a new engine built. I did a proper break in procedure but have not raced it at all since it was installed.
Its been sitting in my garage, due to family and work I don't have time for it anymore and I should let it go to someone that has the time.
Everything on it works but it is not currently a street car therefor it would be best to moved by trailer to your place. I can help with that since I have a truck and trailer. I can deliver it free within a reasonable distance ~60 miles. Further distance delivery for a fee can be discussed,
The bill of sale will clearly state: tow away, as is sale, for off road use only etc etc
A short test drive can be arranged if funds and real interest is established.
Build List:
Engine-
-Built Ej257 turbo short block
-MANLEY H BEEM CONNECTING RODS
-MANLEY FORGED PLATINUM SERIES PISTONS AND RINGS
-New OEM T-belt pulley and tensioner
-ARP head studs
-Gates blue racing belt
-King racing rod bearings
-Cometic MLX head gasket .051 PN H346205
-Moroso oil pickup
-GENUINE SUBARU 10MM HIGH FLOW OIL PUMP WRX STi IMPREZA
-SOHC resurfaced including valve seats with Supertech Valve Spring
-DELTA 1500 GRIND SOHC CAMS
-GRIMMSPEED PHENOLIC THERMAL MANIFOLD SPACER- 8MM
-TGV delete
-Perrin lightweight crank pulley
-engine machining and parts cost was $4300+ (see receipt for block)
Drivetrain (value $4500):
-5 speed transmission TY754VB1EA with front Helical LSD w/ DCCD (up to a 35:65 split) and a A.P Surtrac R160 rear differential (came out of a WRX - STi RA limited -MY99-00) this is rare a transmission these days.
-New ACT 4 puck clutch installed
-filled with Extra S Subaru OEM transmission fluid
-Final drive 4.44
-Spiider dccdpro controller with thumb knob controller
-Suspension (Cost $3000 see receipt):
~7" travel
-Bilstein 46MM (pn 35-212850) motor sport suspension custom built by Streetwise (streetwiseparts.com)
-Bilstein Universal Motorsports Strut 46mm
with Swift springs
-Group N front and rear strut top hats
-Whiteline adjustable rear lateral links
-JDM GC8 RA Aluminum front lower control arms with Group N end mounts
-Adjustable trailing arms
-New NTN wheel bearings installed and repacked with NEO H800 heavy duty grease
Brakes:
-DBA 4000 rotors
-4/2 pot red subaru calipers
-Hawk brake pads
-Super blue brake fluid
-Upgraded master brake cylinder (was 7/8") now 1-1/6" diameter to support 4 wheel calipers
Additional component list:
-Blouch Dominator 1.5 Ball Bearing Turbo
-Cobb ID 1000 injectors
-Cobb EBCS - Boost controller
-V3 COBB access port
-Ngk (one step colder) spark plugs I gaped them at .026 for higher boost application
-Walbro 255 fuel pump
-Larger top mount intercooler
-APS BOV - blow off valve
-Agency power 3" hard turbo inlet large
-Agency power fuel rails
-Apexi gauges: fuel pressure, EGT and boost
-ATI gauge pod
-Sparco steering wheel with NRG quick disconnect
-02/03 Wrx ecu (USDM)
-Catless bell mouth down pipe turbo back exhaust with unequal header heat wrapped
-Kartboy 15mm Exhaust Hangers
-Gimmick Motorsports V-Band 3in Catback Exhaust Subaru WRX / STI 2002-2007
-Mishimoto all aluminum radiator
-Aeromotive fuel pressure Regulator, EFI Bypass, Adjustable
-Aluminum rear diff skid plate
-JDM rear wing
-Enkie rally wheels 15"
-BFGoodrich GZE gravel tires lots of tread left
-old sparco racing seats with 1x 5 point seat belts out of date.
-07 STI Steering Rack PN: 34110FE600, 15.1:1 ratio
-AEM wide band A/F gauge
-Moroso air oil catch can
I have way too much $ in the car to give it away. I am not desperate to sell and it can sit for another 5 years. I start it at least every 3-4 months and it currently has sta-bil stabilizer in the fuel.
Call or text only please, emails will not be seen.
Dan
Trade considerations, with or without cash in either direction, including land:
Interested in these vehicles: Subaru Impreza, STI, 2007 STI limited, WRX, Forester, Legacy, Porsche 997, 911 any year, BMW , BMW M3, Audi A6 TDI, Datsun 510, Scout II, Jeep, Cummins 12v, Ram, diesel, Hilux, Toyota Supra, Toyota 4runner, Muscle cars, Mustang, Camaro, LS swapped vehicles, Polaris, Ski-do snowmobile, atv, side by side UTV, motorcycles. Let me know what else you have to trade and I will consider.
again the only reason I am selling is I don't have the time to race it.
danverco is offline
Old 05-15-2023, 09:14 PM   #2
Jack
Add Lightness
Member Sales Rating: (7)
Member#: 13699
2021 Building
It Better
Note from PM from the seller, this is a USDM car, so it's good in the ads here.
Jack is offline
Old 05-18-2023, 11:59 PM   #3
danverco
Member#: 156015
2001 GM6 STi swap
Default to the top
to the top
danverco is offline
Old 05-30-2023, 11:41 PM   #4
danverco
Member#: 156015
2001 GM6 STi swap
to the top again
danverco is offline
Old 05-30-2023, 11:51 PM   #5
19std
Member#: 510366
Post some eye candy with the bumps, according to somebody, posts with pics have a 39.8987% increased chance of selling.
19std is offline
Old 05-31-2023, 11:13 PM   #6
danverco
Member#: 156015
2001 GM6 STi swap
Use link to see pictures
denver.craigslist.org/cto/d/morrison-subaru-impreza-door-coupe-jdm/7624309015.html
danverco is offline
Old 05-31-2023, 11:13 PM   #7
danverco
Member#: 156015
2001 GM6 STi swap
danverco is offline
Old 06-13-2023, 12:31 AM   #8
danverco
Member#: 156015
2001 GM6 STi swap
danverco is offline
Old 06-13-2023, 12:31 AM   #9
danverco
Member#: 156015
2001 GM6 STi swap
danverco is offline
Old 08-13-2023, 11:01 AM   #10
danverco
Member#: 156015
2001 GM6 STi swap
Car is still for sale I need to make space in the garage. Paint it and all the sudden this is a ~30k$ race car.
danverco is offline
Old 08-30-2023, 06:41 PM   #11
danverco
Member#: 156015
2001 GM6 STi swap
top of the list for your consideration
danverco is offline
Closed Thread
