Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 04-18-2004, 11:21 PM   #1
chaddeus
Member#: 56624
2004 Subaru WRX STi
Default Steering Wheel Not Straight = Normal
I find a little problem with the Steering wheel and when I bring it for service, they say this is normal.
Let me explain the problem and I hope you guys would be able to understand. My current STi steering wheel "face" is tilted slightly to the right like \=
The steering wheel face should face me straight and when I hold it. The distance from my shoulder to the steering wheel should be equal BUT for my case, the distance from my left shoulder to the steering wheel is further than right shoulder.
I hope you guys get what i Mean..
- Charles
chaddeus is offline   Reply With Quote
Old 04-18-2004, 11:26 PM   #2
sonicsuby
Member#: 34162
2005 WRX wgn, 01 RS
White, White
so wait...
the steering wheel is TURNED..like, when you're going straight the wheel is turned a little bit, looking like the car should be going either left or right?
or the wheel is actually tilted - like if you're facing the wheel from the drivers seat, one side of the wheel is sloping in towards the dash?
This is hard to describe/understand.
If it's the first one, you're probably getting memory steer. This is common on the WRX (not sure 'bout the STi..I know my car has it)and is fixable by replacing the bushings in the steering rack with a better, stiffer set. If the problem is the second one..that **** ain't normal. Which dealer are you taking your car to?
sonicsuby is offline   Reply With Quote
Old 04-18-2004, 11:42 PM   #3
chaddeus
Member#: 56624
2004 Subaru WRX STi
This above is CORRECT.
The problem is, I check out other STi and it seems to be the same and that wonders me.
Anyone with an STI can verify this? The tilting is not extremely bad but enough to see with your eyes.
- Charles
Old 04-19-2004, 12:23 AM   #4
Thumper23
Member#: 11571
it happened in my WRX after an alignment
hadn't had that problem in my STi yet
Thumper23 is offline   Reply With Quote
Old 04-19-2004, 01:01 AM   #5
Poor boy/fast car
Member#: 41990
03 WRX
Are you sure your dashboard just isn't closer to the steering wheel on one side making it appear that it is tilted?
Poor boy/fast car is offline   Reply With Quote
Old 04-19-2004, 02:04 AM   #6
Roy Lin
Member#: 38890
It's been like that with me too... It got a little better after an alignment, but it now goes in the opposite direction slightly.
my camber in the rear is slightly out of spec due to lowering springs/struts... but th epull existed even on stock settings
Roy Lin is offline   Reply With Quote
Old 04-19-2004, 03:52 AM   #7
chaddeus
Member#: 56624
2004 Subaru WRX STi
Wait wait.. This got nothing to do with the wheel alignment or camber angle. This is just purely the STEERING WHEEL
- Charles
Old 04-19-2004, 03:53 AM   #8
chaddeus
Member#: 56624
2004 Subaru WRX STi
But got nothing to do with wheel alignment
Old 04-19-2004, 04:07 AM   #9
bomber991
Member#: 52539
2003 Impreza WRX
BLUE
Maybe your left arm is shorter than your right arm and you just think the steering wheel looks angeled alittle?
bomber991 is offline   Reply With Quote
Old 04-19-2004, 04:21 AM   #10
chaddeus
Member#: 56624
2004 Subaru WRX STi
Hahha.. Well, my eyes certainly dont make that same mistake
- Charles
Old 04-19-2004, 05:17 AM   #11
sonicsuby
Member#: 34162
2005 WRX wgn, 01 RS
White, White
do you have a digitial camera you could use to take pics and illustrate?
if not I'd love to look at it on Tuesday night. Check the BAIC forum for directions to UCKK (Union City)
Old 04-19-2004, 05:26 AM   #12
Roy Lin
Member#: 38890
Chaddeus, it has everything to do with your alignment! If your wheels are off, then your steering wheel is going to get pulled to the right or left.
Also, i remember reading somewhere that from the factory they only use the driver side bolts to align the car, hence the fairly common problem of the steering wheel not being perfectly centered. Do a quick search, and i think you'll find other people's take on this problem. n00b!!!
(yay! that was my first time!)
Old 04-19-2004, 08:32 AM   #13
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I THINK the OP is saying, either the wheel is not 'square' with the column and therefore would appear to 'wobble' if spun freely somehow, OR the steering column's axis is not parallel with the front/back plane of the car.
btw, I had a '69 Datsun SRL311 once and it's column was distinctly pointed toward the nose of the car. making the left side of the wheel farther forward thatn the right. Seems like yours is the other way.
1 Lucky Texan is online now   Reply With Quote
Old 04-19-2004, 02:24 PM   #14
chaddeus
Member#: 56624
2004 Subaru WRX STi
Just to clarify. On the freeway, my car would go straight even if i dont hold on the steering wheel. I am not sure if you are refering to this issue when you talk about pulling to the left or right.
- Charles
Old 04-19-2004, 02:25 PM   #15
chaddeus
Member#: 56624
2004 Subaru WRX STi
I'll try to borrow a digital camera and post it here.
- Charles
Old 04-19-2004, 02:53 PM   #16
chaddeus
Member#: 56624
2004 Subaru WRX STi
Ok guys. I got the pictures.
The big picture. As you can see, the gap on the right is more than the left side.
This is a close up for you to see.
This two pictures should describe my problem with the steering wheel.
- Charles
Old 04-19-2004, 03:20 PM   #17
Shikamaru
Member#: 49238
2004 WRX
WR Blue
when I was at the dealer they said lots of STi owners have had alignment problems and steering issues, which is probably why the 2005 STi gets a new Steering Rack
Shikamaru is offline   Reply With Quote
Old 04-19-2004, 03:23 PM   #18
Sublime5260
Member#: 30488
2006 Acura TL
Gray
I have a 2002 WRX and the steering wheel has always tilted a little bit to the right. I brought it BRAND NEW, and its been like that since Day 1.
Sublime5260 is offline   Reply With Quote
Old 04-19-2004, 05:45 PM   #19
chaddeus
Member#: 56624
2004 Subaru WRX STi
Mine is brand new also when i bought it. Now, is this a defective problem issue? Should I persuit this issue?
- Charles
Old 04-19-2004, 08:30 PM   #20
catass
Member#: 31976
2004 WRX STi
World Rally Blue
I used to think mine was tilted, but it's the tires. The roads around here are all curved upwards, and the tires on the sti stick into every little groove and pull the steering wheel. But when I find a flat road (rare in pa!) it goes straight and the wheel is straight when I let go.
catass is offline   Reply With Quote
Old 04-19-2004, 10:10 PM   #21
sonicsuby
Member#: 34162
2005 WRX wgn, 01 RS
White, White
look at his pictures..he's not saying the wheel is turned, he's saying the column is not straight. It's pointing toward the drivers side as it comes out of the column.
That doesn't seem normal to me. Good luck fighting with a dealer though - I had a problem with my drivers seat where it would move while driving. They said that was normal too until I met with the service department foreman. Maybe that's something you could do - or check other members cars. Try posting at www.imprezawrxsti.com
Old 04-19-2004, 11:47 PM   #22
Turbo9000
Member#: 35004
88 __/ ] \_/
. -o-----o- ///M5
chaddeus...I believe I have the same problem too. The steering wheel is slightly turned to the right when the car is moving perfectly straight. When I put the steering wheel straight the car will turn sightly to the left...and this is on a perfectly flat road. Any way to fix it?
Turbo9000 is offline   Reply With Quote
Old 04-20-2004, 12:12 AM   #23
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
That is PRECISELY what my old datsun looked like as in my post above. Only probably a little worse. Actually, the entire seating position was biased a little - how to describe it?- um - feet 'inboard' (to the right) of where the they 'should' be. I'd bet they are all like this.
Old 04-20-2004, 12:16 AM   #24
STi Boy
Member#: 3401
2013 BRZ
WORLD RALLY BLUE
damn...that must be annoying as hell driving with a steering wheel not being centered while going straight....uughh
is the 05 wrx gettin a new steering rack?
STi Boy is offline   Reply With Quote
Old 04-20-2004, 12:28 AM   #25
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
never kept me from cornering like a freight train or doing 125 down the highway. But it is kinda one of those things that bothers you a little bit AFTER it pointed out to you. Like "what were they thinking? couldn't they build it right?" I remember the story of a tennis player psyching out his opponent right before a game by asking "Show me the grip you use on the racket. " then "WOW! I bet THAT feels weird!" and walking off. He won.
"Besides, ALL of us sit off to one side right? Brits on the left, us on the right - it works OK. Humans are adaptable, specialization is for insects.
Steering Wheel Not Straight iyzmi Interior & Exterior Modification 21 03-17-2009 02:11 PM
Steering wheel never straight? 02REX4LIFE South West Impreza Club Forum -- SWIC 11 03-26-2008 11:38 AM
steering wheel not centering after left turns? happasaiyan Tire & Wheel 4 11-27-2005 03:57 AM
Steering wheel not straight Lantec Vancouver Impreza Club Forum -- VIC 15 07-20-2004 05:31 PM
Steering wheel not straight after alignment? powerlabs Service & Maintenance 4 04-20-2004 10:26 PM
