06-18-2008, 08:02 PM | #51 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
I have driven enough high powered cars at the drags to understand that you don't make 10MPH just by improving your 60'
And THIS is my point - I don't see where in the first post that he said he screwed up his run and made such a mistake
06-18-2008, 08:09 PM | #52 | |
Member#: 101691
Vehicle:97 Supra TT SOLD - 35r bug/hawkeye |
maybe i didnt mention anything because maybe i DONT know what i did wrong ..i know that one of the runs i rode out 4th gear too long instead of shifting into 5th...and another run i shifted into 5th too early..there ARE probably other things i did wrong too..it was my FIRST TIME AT ANY track drag racing..and it was my second time driving the car after getting it finished AND it was my FIRST** time all out beating on the car everrrr..i dont even drive this car enough to get to know it and get used to it.....i KNOW it has alot left in it(even if i have to let a "pro" drive it sooner or later to prove some of you wrong) |
06-18-2008, 08:46 PM | #53 |
Member#: 96452
Vehicle:So, what to play with next ? |
Stop defending yourself. One guy half read one of DEF's posts and shot his mouth off in the wrong direction. Now you are being used as a shied to defend his mistake. Your car sounds awesome. You have a set up a lot of us would love to have. Keep driving it , ignore the negative element and enjoy your car. I bet you hit 11's your next time out. It ain't rocket science. It is an art though. Not a particularly difficult one like say sculpting but an art nonetheless. LOL !
06-19-2008, 09:28 AM | #54 |
Member#: 4568
Vehicle:10.7 @ 136, '02 WRX 12.8 @ 112, '09 spec.B |
With 2.0-2.1 sixty foots... your gonna pick up a TON of mph once you get down into the 1.6-1.7 range. Heck even with a low 1.8. End of story.
Good luck and keep practicing. Keep us updated... def |
06-19-2008, 10:20 AM | #55 | |
Member#: 103343
Vehicle:2004 2.5 Hybrid 6spd Rotated Manifold/35R |
Also, it does improve trap speed when 60's are improved. Not a ton, but it will. He might need to shift faster. I see a mid to high 120's. Let us see what the guy is capable of doing on his next track day! Good luck to the OP. You got a hell of a car! |
07-12-2008, 01:15 AM | #56 |
Member#: 101691
ok....today was my 2ND time at the track.... still having only driven the car 1-2 times per week since, i decided to go to the track..still with no launch practice... i hit 12.1 at 121 (: and that was still with a lousy 2.0 60"...........so my conclusion is my LC is set too low because i somewhat bog and dont take off fast or i need practice..
07-12-2008, 01:49 AM | #57 | |
Member#: 169119
07-12-2008, 07:38 AM | #58 |
Member#: 99321
Vehicle:2014 Forester Red |
well, keep practicing and your times will drop, and don't let all these haters say otherwise cause I am sure none of them have a 35r built motor bugeye!!
Are you still running your stock axles?? -Cramer |
07-12-2008, 07:57 AM | #59 |
Member#: 156973
International
121mph = 415whp, better then your 119mph, but still nowhere near 520whp
07-12-2008, 09:27 AM | #60 |
Member#: 79859
South East
Vehicle:2002 384 whp 332.5 lbs |
I have a quick question. Why would you do all that engine work and leave the rods stock? This is a usdm 2.5 right? I didn't think the stock Sti rods were that strong. Or at least since the engine was apart change em out anyway. I just don't understand the logic. Sorry op not tryin to be an a**.
07-12-2008, 09:36 AM | #61 |
Member#: 59871
TXIC
Vehicle:2004 STi - Silver FPGreen,FMIC,Wisecos,MSPT |
OP, I've heard some suby drivers get better runs out of Atco.
07-12-2008, 10:37 AM | #62 |
Member#: 101691
07-12-2008, 10:43 AM | #63 | |
Member#: 101691
thats a long story...i been through alot with this setup ..time was killing me..i had a chance to get a brand new motor quick so i tossed pistons in it and put it in...the rods werent readily available at the moment and there wasnt any time available at the shop at the time to tear it down at least for a few weeks and i was very impatient. and after all the money that was spent around that time, i didnt want to waste anymore time and money...but yes...now i do regret not taking the extra time and money and putting the rods in /: but ill be ok...everything is working out good right now..my tune was close to maxing out my injectors/pump...but thats as far as i want to go on the stock rods so im not going to change the injectors/pump..i probably can def. get some more power out of it but ive been through too much with it and so much time lost that i will just enjoy it as is instead of having any problems. id def. like to try to go to atco...ive never been in that area yet. |
07-12-2008, 10:48 AM | #64 | |
Member#: 4568
def |
07-12-2008, 11:34 AM | #65 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
07-12-2008, 11:40 AM | #66 |
Member#: 101691
i did actually get a 1.9 one out of my 3 attempts...but i shifted into 2nd wayy too early because i felt a small hiccup/pop...1 out of ten times it tends to do that at exactly the same rpm..i think it was around 61-6200..my tuner says to stay in it if that happens but i shifted because thats the first time it happened to me at the track...there is another car whose dynosheet i was looking at shows the same drop BUT doesnt show up in logs...weird.....and so far no one knows who to solve that issue?! i think that run wouldve been my best yet..i ran a 121 that time as well.
07-12-2008, 11:50 AM | #67 | |
Member#: 4568
def |
07-12-2008, 11:56 AM | #68 |
Member#: 101691
wheres that?
07-12-2008, 12:20 PM | #69 |
Member#: 99614
Vehicle:12 STi Limited Black |
Was gonna say the same thing... a certain trap speed doesnt equate exactly to a certain power level. Elevation/temp would negate that for starters...
07-12-2008, 12:59 PM | #70 | |
Member#: 79859
South East
Oh and I "think" AZSCOOBIE had a rod get bent at around 550. |
07-12-2008, 01:29 PM | #71 |
Member#: 4568
www.cecilcountydragway.com
Top north-eastern part of Maryland, not far from Jersey or Delaware or Pa. def |
07-13-2008, 08:05 AM | #72 |
Top Scoob 019
Member#: 43630
Vehicle:2004 GT40R-built 2.5 604 whp @1.8 BAR on VP109 |
Pratice makes perfect, its fairly hard to launch these larger turbos.. However Terminal speed (mph) imo will give you an indication of the potential of the car..
07-13-2008, 08:14 AM | #73 |
Top Scoob 019
Member#: 43630
07-13-2008, 02:06 PM | #74 |
Member#: 77810
Vehicle:2006 Evo IX SE Tarmac Black |
the traps seem really low... but the only thing to do is keep practicing.
07-13-2008, 04:59 PM | #75 |
Member#: 104200
TXIC
Vehicle:000 WHP BUGEYE Street Proven Performance |
hey i was there at the track, im the one who asked you what size rims you had on. if i remeber correctly, you were shifting pretty slow and the car sounded like it was falling out of boost when you were shifting it. nice run tho, you deff need some practice to get that beast moving! but the car looks sick and sounds sick too
