Welcome to the North American Subaru Impreza Owners Club Wednesday October 17, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 07-14-2018, 08:17 PM   #1
Subie_Jake
Member#: 479006
Default 2015 WRX Stage 2 Exaust Pop
Hope everyone is having a fine Saturday I have a question. While decelerating and revmatching under higher loads the exaust will pop. My best guess is I'm injecting fuel that is not fully ignited but getting compressed and then igniting... I'm still learning. Searched around on google/YouTube but the searches just refer to this as a issue not something that can be recreated like my case.
Is this something that is bad? Sould I stop doing it? Just looking for some guidance really.
Subie_Jake is offline   Reply With Quote
Old 07-14-2018, 08:23 PM   #2
Subie_Jake
Member#: 479006
Exhaust*
Old 07-14-2018, 08:40 PM   #3
Straight6
Member#: 419593
Depends on a tune. Some do it more than others. Nothing to worry about really. Ever heard of a crackle tune, lol ? People have this implemented on purpose, although I have no slightest idea as to why.
Straight6 is offline   Reply With Quote
Old 07-14-2018, 09:01 PM   #4
Subie_Jake
Member#: 479006
Hmmmm alright I appreciate the input.
Old 07-15-2018, 09:22 AM   #5
Perscitus
Member#: 378214
This pops-n-bangs, crackles, etc. fad is just as retarded as it is indeed damaging on anything but a racecar (actually even there it can be damaging).
All its doing is allowing a portion of uncombusted air/fuel mixture (or just the fuel if you will) to make it past the cylinder, out the exhaust valve and into the exhaust piping. Given the temperatures in the exhaust track, the fuel spontaneously self-ignites in little explosions along the exhaust pulses. This is whay causes the sound and in extreme cases (or t00ns) also flames out the tips.
All it takes to implement this is heavy negative timing at very low loads and below idle RPM. This way off throttle, in between shifts, etc, timing will be retarded enough to allow the fuel to flow past the cylinder and do its thing in the exhaust track.
Zero benefits to doing this. On a catted setup its simply asking for a failure as the cat/s clog, melt if the explosions happen close enough to them. On a catless setup, any inline mufflers and poor welds wont hold up to it for too long... the turbo itself wont be too thrilled either.
In extreme cases, turbine components, exhaust ports and exhaust valves can be damaged.
But hey, more power to the BMW, Chevy, Chrysler, Ford, Mercedes crowds that seem particularly fond of these retarded (literally and figuratively speaking) tunes.
Perscitus is offline   Reply With Quote
Old 07-15-2018, 10:00 AM   #6
Straight6
Member#: 419593
Because racecar. How about this gem:
https://forums.nasioc.com/forums/sho....php?t=2829216
Old 07-15-2018, 11:15 AM   #7
Perscitus
Member#: 378214
Yup, saw that thread take off last year and like most things on here, decided to ignore it.
eBay flamer kits are all the rage with kids like its 1997 all over again.
Darwin awards to any who place additional spark plugs, injectors, etc in their exhaust track south of the actual engine.
http://www.akamoto.co.uk/flaming-exhaust.asp
https://m.ebay.co.uk/itm/NKE-Exhaust-Flamer-Kit-Flame-Kit-/263611524651?_mwBanner=1&_rdt=1
Old 07-15-2018, 03:33 PM   #8
GlarryHoodDIT
Member#: 460907
2016 WRX
How does one decelerate and rev match at high loads? If you're decelerating you're definitely not putting load on the engine, and rev matching, if you know what you're doing, again shouldn't be placing additional load on the engine..........
Guys, I don't think he's referring to the burple tunes with constant popping/backfiring/whatever, he's talking (I think) about the random one off pops you'll hear occasionally from injectors turning on/off and a really open exhaust. It gets exasperated by a really free flowing catback and double being catless.
GlarryHoodDIT is online now   Reply With Quote
Old 07-15-2018, 06:19 PM   #9
Perscitus
Member#: 378214
Good point. If thats the case, then there is little that can be done short of a. moving the primary cat (if still present) further upstream, as far up as the AF sensor location will allow b. replacing said cat with a higher cell count better substrate one (say at least 400 cell, metal core, 6" long or more) or adding such a cat if catless c. stepping down to smaller ID piping
d. further AVCS tweaks to minimize it.
If all else fails, and it becomes unbearable - back to stock, sell or trade-in.
Old 07-16-2018, 10:56 PM   #10
Schoat333
Member#: 452248
2017 Base WRX
It's normal. I have a catted Cobb jpipe and the Cobb stage 2 OTS tune. I get it when rev matching sometimes. If you don't want it to happen, wait until the rpms will be a little lower to rev match. The more throttle you have to give, the more chance you will get the crackle.
Schoat333 is offline   Reply With Quote
Old 07-18-2018, 09:35 AM   #11
Subie_Jake
Member#: 479006
A video would probably explain better but if I were to give it a little juice in 3rd and let off to slow down and its sitting at 4 or 5 k rpm then down shift to 2nd putting the engine at around 5 with a blip in the throttle the exhaust will pop. This is even easier to do downhill. When I say load I meant higher rpms hope that explains it better.
Old 07-19-2018, 12:07 PM   #12
vlad11591
Member#: 295970
2018 WRX
ISM
This happens all the time when I rev match downshift, it doesn't do it if I don't rev match. Not so much on stock tune, but with MAP tune it happens quite frequently.
Nothing to worry about man.
vlad11591 is offline   Reply With Quote
Old 07-20-2018, 10:43 PM   #13
RakumiAzuri
Member#: 472102
2018 WRX
Gunmetal
I get turbo farts when I'm at high RPMs and I disengage the clutch. From what I can see it's pretty normal with 3in pipes.
RakumiAzuri is offline   Reply With Quote
Old 07-21-2018, 01:54 PM   #14
Dazzo
Member#: 484560
Haha, yep! I have a pro tune from Snail and it only does it when shifting from high RPM like over 6500 or so.
Dazzo is offline   Reply With Quote
Old 07-23-2018, 07:19 PM   #15
nine5raptor
Member#: 473534
15 WRX Prem. w/ HK
CWP
Stock tune. Muffler deletes. Run up to ~6500 under wot and shift. 3-6 pops and bangs about Everytime.
Same with map 91 tune. Both on 93 octane.
nine5raptor is offline   Reply With Quote
Old 07-23-2018, 08:38 PM   #16
cyralax
Member#: 425154
2016 WRX Sport
Lapis Blue Pearl
I get it on stock tune with stock mufflers, typically when doing rev matches.
cyralax is offline   Reply With Quote
